» Jim Walker Firebaby by rdw777 Today at 5:08 pm
by Levent Suberk Today at 4:04 pm
» *Cox Engine of The Month* Submit your pictures! -June 2024-
by Davenz13 Today at 12:15 pm
by GallopingGhostler Today at 3:46 am
» S.M.A.L.L. 2024
by balogh Today at 12:21 am
by rdw777 Yesterday at 4:24 pm
» Feed Station Zebra.. Spring 2024
by roddie Yesterday at 4:10 pm
by Cox International Yesterday at 1:08 pm
» Cox Mustang repair
by getback Yesterday at 7:29 am
by batjac Thu May 30, 2024 10:52 am
» Cox water wizard
by 1/2A Nut Wed May 29, 2024 11:46 pm
» WenMac MkIII 049, Cox BabeBee, FOX 15X and 19 Prop Screw/Crank Threads
by roddie Wed May 29, 2024 7:34 pm
Cox Kenbrite brochure
Found this on Aussie ebay. I'm assuming that Kenbrite were the Aussie manufacturers/agents for Cox stuff back then.
The Electronic Sure Starter is really interesting. Never seen one before. Claims to be able to "burn off" a flooded glow head. The unit contains a 9volt battery, so I'd be a little concerned about burning a head out.
Re: Cox Kenbrite brochure
I have one of those electronic starters. Never actually tried it. I guess I should take it out and finally use it. At least once.
The Hoarder Mark
The Hoarder Mark
batjac- Diamond Member
I understand that, clear button heats the element continuosly with 1.5 Volts to burn excess fuel in engine. Three D cells are for this purpose.
One D cell is for heating element normally to start the engine. If engine flooded then clear button works as I described above.
9 V battery is for checking glow plug element electrical continuity and lighting the LED.
I don't have this starter, only I guess all of this information.
Last edited by Levent Suberk on Mon Oct 14, 2019 12:28 pm; edited 1 time in total (Reason for editing : Update)
Levent Suberk- Diamond Member
I have a Kenbrite PT-19 box
Have a decent Kenbrite PT-19 box if any of you collectors are interested, PM me with an offer.
Cox shipped molds for the PT-19 to Australia, sent packaging and completed engines w/ mount, wheels and prop. The blue plastic Kenbrite used is a shade lighter, as is the yellow. The PT-19 Boxes had stickers placed over the Cox Santa Ana address, and on the wing the mold was modified to say Kenbrite. I traded a Cox Seafire to a guy in Australia for his NIB Kenbrite PT-19.
Jay
Jay
jmendoza- Silver Member
jmendoza wrote:Have a decent Kenbrite PT-19 box if any of you collectors are interested, PM me with an offer.
Jay
Hey Jay. Thanks. It's nice to know a little bit of history about the Australian connection. I knew they were made out here. I remember the TV ads for the PT-19 and desperately wanted one, but we counldn't afford one and I ended up with a Testor P-40 instead- can't compare.
I found one used in box at a swap meet once but the guy had a couple of hundred bucks on it. Still can't afford one 40 years later.
I have one of those Electronic Sure Starters. I lifted the board out of it and took pictures. I'll have to dig those up.
As I recall, it uses 1.5v from the D cells to light the glow head, places 2 D cells in series for 3 volts to clear a flooded element, and the 9 volt battery is the rail supply for an op-amp comparator (I think it was a LM324?) used to determine when the plug is flooded. Only going off memory here.
I'll dig up those pictures and take a look at it again.
I got the PT-19 Kenbrite from a guy whose father owned a hobby shop in Sydney, and also was a distributor for Kenbrite. He told me it was a display model that his dad had at the store, it was never flown.
I still have my Cox electronic glow starter that I used in the '80s. Kraft made a glow starter equipped with an amp meter that attached to a square 1 1/2 volt square lantern style battery. When those batteries became hard to find I took the meter and installed it in my Cox starter. Worked great. It would indicate glow plug current draw. Nowadays I use a D cell powered glow driver that has an amp meter built in.
coxaddict- Gold Member
