by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
Help wit ID part on super tigre
davidll1984- Diamond Member
Re: Help wit ID part on super tigre
On m'y engine the exaust is overkil on the sound it literaly have silencer wit bafle plate inside wit tube wit lot of litle hole first 1 y have wit sutch big pipe wit silencer???? wat is that part number ???brand name ??? Upgrades parts ??
It have ring on piston tink compression is hi like it dont have run mutch prop is smal for .60 tink ??dont tink the engine was runing its full potentiels rpm
I’m pretty sure that is the correct muffler for that ST engine. I have a muffler like that on a ST 40.
https://www.ebay.com/itm/113884789663
Jason_WI- Top Poster
Is it posible mod To the engine as sale wit it ??? Super tigre .40 is saturno on casing g on Front housing tink part is extra on m'y engine Not sur it has difrent color To aluminium casting part and. Dont Find 1 wit bleu head and pipe ??
Is the Good part for it just Not oem on m'y tink is g.60 f ???? Blue head wat is the différence just color ??
It’s so hard to understand your posts. The muffler is correct for that engine. If you don’t like it then take it off. Not sure what you are asking.
Wil try bench test on super tigre wit pipe on & of tink the mufler part is correct for him engines just Not born wit that part Most blue head dont use pipe tink Not sure m'y is older than its pipe desing and it have. g mark on Front casing
Second super tigre help id
Y have that engines for so long never realy pay attention To it wel start work on couple .15 type engines modification and found noting on .19 super tigre ???? Al that time was tinking je just normal engines is spécifiques mod for Difrent clase speed contest it was cl ??? Now y fited carb without change ventury size just plug in very easy wit carb from cars .12 engine and .9 enya pipe for exaust collector want To use .15 tuned pipe from cars To now just tinking y may have spécial engine dont want To destroy engine trying To get max out of him witout nowing wat type modified engines y have it may have wort mony ??
Number look strange Not clean like 11.9???19 engine frame is .15
It´s the bigger brother of Super Tigre G.15 ,2,5cc engines .
Yours is the G.19, 3,2cc version , same stroke but bigger bore + more torque.
The bore (crankcase) next to brass nut which secures RC carb.
should be covered (JB weld) because possible fresh-gas leakage .
In french words,
combris ?.
BTW you can kill this engine in short time ,
running @ all synth. oil RC Car Racing Fuel.
In french words,
combris ?.
germanbuddy- Gold Member
Dont wory engine carburateur secur wit 3 point 1 Bolt To rear and two set screw Not instal on picturs its for air plane never use full sintetique oil 50\50 castor wit 25 nitro max y no wow To run special. Old engine
» Super Tigre G15
» Super Tigre G40 RV ABC
» Super Tigre G20 - 23
» My First Rossi and a Super Tigre run also...
» Super Tigre G90 Ringed
