» audio-tach anyone?by 944_Jim Today at 9:53 pm
by Ken Cook Today at 7:50 pm
by akjgardner Today at 7:08 pm
by roddie Today at 2:54 pm
by rsv1cox Today at 2:43 pm
by Admin Today at 1:11 pm
by rsv1cox Today at 10:26 am
by rsv1cox Today at 7:32 am
Follow Rusty's Memorial Traveling Engines!
Page 3 of 10
Page 3 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Rusty's Engines and Me
I received Rusty's Memorial Engines just before this year's "Summer S.M.A.L.L.", and they became part of the load-out for the trip to Arkansas.
I'm currently "at war" with my editing program, but will post a video at first opportunity.
I got all three installed on their respective planes, but decided to wait to test-run them at Sky Tiger Field.
The Fox was bolted to my Uncle Wayne's Goldberg "Buster", the RR-1 went on the Q-Tee, and the .020 went on a Scientific "Kingpin", built by Breezy Hill Flyer Billy Lang. They were all then tied down in the van.
When running the Fox on the Buster, I was getting a bunch of vibration that didn't get better with two other props, so I switched the engine to my Goldberg "Shoestring" with a third prop. This worked out better, and I logged a couple flights, though the Fox still didn't like outside pulls, cutting out---then starting again---just to make me pay attention.
I was able to share a Shoestring flight with Fitz Walker III, whose podcast covers the S.M.A.L.L. Fly-Ins when he's able to attend. He hadn't flown C/L in many years, but handled the old Shoestring just fine.
The RR-1 apparently didn't care for Billy Lang's custom-carved prop, and I must have been heat fatigued, because I kept trying to fix the problem through needle adjustments. It would later fly just fine on a gray/black 5x3 prop.
Hoofing it back home, the RR-1 had it's prop swapped out for a 5x3, which the engine liked a LOT more. I got in several flights high over the hill, with good, steady runs, and smooth video and clear captures:
Then, I decided to introduce it to a couple "Children of the 60's"
The Golden Hawk had its Space Bug replaced by the RR-1 which, to put it mildly, "lit it up"! The G.H. blasted around my front yard on its 35 feet of Spiderwire like a combat wing.
I wasn't bold enough to try outsides or inverted stuff, but pulled some wingovers and tight inside loops.
While in a control line mood, I wanted to try the RR-1 on one more "photo friendly" (no cowling) type, so it was bolted to my Jim Walker "Firebrand" combat wing. It hauled the little foamy with the same authority as the Golden Hawk, though I still kept everything on the positive side.
I still wanted to get a little more flying done with the Fox .35, and hauled it and its Shoestring to Breezy Hill for some laps, and photo ops with the Flyers.
So, the 'String got loaded down with GoPros and launched. The vibration was still there, but manageable, and I got in a good long flight. The landing, however was so abrupt that the plane's flipping on it's back broke the rudder and elevator (it's an old plane!).
Still, I had my video, and the stills I could capture, so no great problem.
After our meeting, I got the Flyers to pose with Rusty's Three Traveling Engines.
And yet, I STILL wanted a chance to make amends with the Fox by trying one more prop, and bolted the engine to Wayne's Buster for another try. The final prop was a narrower chord Master Airscrew, and the Fox liked it.
All set and ready to rock, then the winds came up...and stayed up. I rolled the dice and headed over to the small Airport at Cairo, Illinois, hoping for calmer air at the end of the day...and was rewarded with a smooth light breeze.
I was rapidly losing light, and fighting off some truly majestic horseflys, but got everything set up with Go Pro's on the Buster's wingtips. I didn't want to press my luck with the engines' departure so close, and limited the Buster to loops and wingovers as it hauled it's Go Pro's around its circle.
This is the wrap-up to that beautiful evening, with what I consider some fitting images as a memorial to Rusty.
Thanks again to Jason, Jacob, and all those who helped make this happen.
And, God Speed to my ole bud, Rusty.
Re: Follow Rusty's Memorial Traveling Engines!
Superb photo of a beautiful day We would like to be there
davidll1984- Diamond Member
The Traveling Engines arrived this afternoon safely and securely. Thanks, Kim! I have already mounted the RR-1 and the .020 engines on planes. I'll mount the Fox tomorrow on a plane. I hope to be able to fly the planes on Monday or Wednesday. I won't be able to match Kim's posts, but I'll give it my best shot.
Also, just wondering what we call these .020 engines with the printed backplate. Are they still a PeeWee? A Product .020? A CEF Special?
The Unsure Mark
The Unsure Mark
batjac- Diamond Member
Kim, is that a Cox handle your flying with? I pulled mine out a little while back because I had my .020 lines on it. Mine cracked in my hand. That was a green one similar to what you look like your flying with. I have another peach colored one with swirls in it that seems intact, I just haven't got around to switching it over yet.
Very Nice Kim , you nailed a lot of flights and took the engines on a journey to top it off . Heck you were making me tired just hearing you hauling and mounting and of coarse Fling !! Looks / Sounds like you had some really good fun and that's what Rusty would have wanted
Ken Cook wrote:Kim, is that a Cox handle your flying with? I pulled mine out a little while back because I had my .020 lines on it. Mine cracked in my hand. That was a green one similar to what you look like your flying with. I have another peach colored one with swirls in it that seems intact, I just haven't got around to switching it over yet.
Yeah, I've a couple that got retired due to cracking a the top and bottom cross sections. This one must have spent most of its life tucked away from the sun, 'cause it seems to be in good shape. I've got some home made handles, cut from cheap ply and layered with old fiberglass and epoxy, but haven't put many of them to use yet.
getback wrote:Very Nice Kim , you nailed a lot of flights and took the engines on a journey to top it off . Heck you were making me tired just hearing you hauling and mounting and of coarse Fling !! Looks / Sounds like you had some really good fun and that's what Rusty would have wanted
Thanks Eric!
Yeah, it was a good time...figure Rusty might approve...or maybe shake his head at all the fuss!
Good remembering our ole bud.
Amazing pictures! I'm glad to see all the engines got some time in the air and they gave you minimal trouble. I don't know why I didn't try a 5x3 on the RR-1 as that is usually my go-to prop. It looks like everyone had a great time.
This one is my favorite. Thank you Kim for doing those engines justice. Keep that Fox running guys! It will eventually loosen up. It’s a golden goose, it just needs breaking in.
Thank You Guys.
It's nice seeing these engines loved and used. Rusty would be proud!
Great story and photos to accompany it. As stated above, Rusty was probably looking down smiling at the engines running.
Sorry to take so long to get these videos out. Been laid up with my back, but I finally got out to fly yesterday. Here is the video of Rusty’s Travelling Engines flying. My son and I went out to Walker Memorial Field at Delta Park to get some flights in. I also hoped to get a few of the other members at the field who knew Rusty through Stun Hangar to fly also, but a couple of them were clockwise flyers, one had balance issues, and one said he couldn’t fly on the uneven grass. So only a couple got to fly the engines. One was the club hotshot, Jim Cameron, who flies and evaluates most people’s planes, and one was Gary Harris, a combat flyer.
Here is the Travelling Fox:
And the Travelling PeeWee/RR-1:
I’ll post more pics soon. The engines are clean up and ready to go, and I’ll pack them up to ship off to Long Island as soon as the book and USB stick are updated.
The Slow Mark
The Slow Mark
Good stuff Mark.
First video flight, your Son's first larger than .049 flight. He did a great job. Guess that was Jim in the circle with him. Nice circle. Asphalt?
Way to spread the Love Mark , good you could get some more people to come out with you and your son to fly the engines . That Pee Wee was really hauling the mail !! To fast for me LOL All seemed to run pretty well , But i did notice the Hiccup in the Fox when overhead but just kept charging on . Look to bee a nice day for fling and ya'll had some good times and a time the think of our bud Rusty .
Excellent videos, excellent flying----getting these wonderful castor slingers doing their thing.
Yes, Rusty would highly approve!
Good Job!
Good Job!
Holy smokes that peewee rips, nice work staying vertical. Awesome flights all around, congrats on the .35 maiden. Enjoyed watching.
layback209- Gold Member
My god just to watch it's make me dizzy I know how you could have stayed up all this time me, impossible, will be collapsed on the ground like for the plane i Have a good fun to watch
Sorry to take so long for the update. I was laid out for a while. Here are the pictures of the engines mounted on planes and at the field.
I was originally going to mount the PeeWee on my L’il Gem , but then remembered that I built a PeeWee powered Ringmaster for the last Fly-A-Thon that never got flown. So that’s what the PeeWee went on.
The RR-1 went on my Ambush. Irony, that. A Cox engine on a Testors plane…
And the Fox went on a Fight streak. Fitting period plane for the engine. It started off as a Flite Streak ARF, but after a crash I rebuilt it with a solid fuselage and motor mount for a Magnum 30XLS 4-stroke engine. Obviously the Fox is MUCH lighter. So I had to add some weight…
To fly the Cox engines, I broke out my last fresh bottle of fuel. *** Sigh *** Brodak 25%. The Fox got SIG 10% nitro, 25% full castor fuel.
We flew at Walker Memorial Field, dedicated to Jim Walker, Father of control line flying.
I tried to get more people flying, but only was able to rope my son and a couple of others. Here’s Jim Cameron, long time flyer and star of the previous videos:
And this is Gary Harris, as seen in the Ambush video:
It was such a great honor (and terrible responsibility) to get to fly and share Rusty’s engines. And now I get to pass them on to Bob and other CEF members to enjoy.
The Honored Mark
The Honored Mark
Great Job Mark!!!!!!!!!!!!!!!!
Looks like you had an awesome time Mark. Great videos and pictures too.
Wanted to bump this back to the top, to make sure members get a chance to check out Mark's Excellent Expo of our immortal bud's Memorial Engines.
Stuff like this is the very fabric of Jacob's Forum!!!!!!!!!!!!!!!
Check 'em Out and throw the boy a Greenie!!!!
Kim wrote:Wanted to bump this back to the top, to make sure members get a chance to check out Mark's Excellent Expo of our immortal bud's Memorial Engines.
Done. Should have done it before.
Big hole here since we lost Rusty. Seems like things have dropped off. Even the old timers seldom contribute anymore.
» ***Rusty's Memorial Traveling Engines*** SIGN UP!
» Follow The Traveling Engine!
» Rusty’s Traveling Engines
» ***The Traveling Engine TD .049*** SIGN UP!
Page 3 of 10
