» Jim Walkers FireBee - This is going to be funby rdw777 Today at 10:22 am
» audio-tach anyone?
by getback Today at 9:53 am
by fit90 Today at 7:34 am
by getback Today at 6:19 am
by Admin Yesterday at 1:11 pm
Need help selecting socket screws
We will be stocking some black oxided socket head screws, matching washers, blind nuts (and Tee nuts for 4-40). If I measured correctly:
2-56 is for .010 and .020
3-48 is for Babe Bee and Tee Dee .049
4-40 is for .049 with production backplates
The question is what sortiment of lenghts for each size should we stock? We would like to limit stock to what Cox modellers use and we will presumably sell.
For 2-56: 1/2" ?
For 3-48: 3/4" ?
For 4-40: 3/4" & 1" ?
Blind (self-locking) nuts for sure for all sizes?
Also regular nuts w. washers, yes/no?
Tee nuts where available?
Input / suggestions?
For 2-56: 1/2" ?
For 3-48: 3/4" ?
Re: Need help selecting socket screws
I am so used to having to cut whatever I can find so it isn't too long! If they are completely threaded 1 inch or 1 1/4 inch makes me happy, they are easy to cut.
I would like 1 1/4 inch - they are easy to cut and trim. Spring washers would be an advantage too.
My preference would be to offer correct sizes/lenghts, ready-to-use, seeing that we have a substantial amount of "newbies" to the hobby that buy from us.
The engine mounting bolts on my Baby Ringmaster (original production from more than 20 years ago) are 1/2 inch long. It has a sheet metal motor mount.
My short answer for 2-56 engine mounting bolts is:
3/4" if nuts and lock washers(or nylock nuts), and thrust plates are used to secure the engine.
1/2" if blind nuts are used (this eliminates the need for one of the metal thrust plates but may not accommodate Nylocks).
My long answer for 2-56 engine mounting bolts is:
For the Tee Dee Beam mount on a plane with a 1/4" fuselage, the screw passes through a washer, the engine mount, another 2 washers for thrust offset, and a 1/16" metal thrust plate on each side of the fuse, then another washer and nut or a self-locking nylock nut. You have to have at least 3/4" for all that. (If blind nuts are used I eliminate the extra hardware on the opposite side of the engine)
I would say the same for the 3-48 as that might be better for a uhhh... Norvel
EDIT: Tell ya what, tomorrow morning I'll go out to the shop and try to simplify the answer.
pkrankow wrote:I am so used to having to cut whatever I can find so it isn't too long! If they are completely threaded 1 inch or 1 1/4 inch makes me happy, they are easy to cut.
I can fully understand a need to provide appropriately sized screws for the newbie, but I agree with Phil on this one. There are so many different applications and needs for varying lengths, I always bulk buy a single long length and cut to size as needed. In any event, I almost always end up cutting to length anyway, even if it's an 1/8" or less.
But, I'm guess I'm not a newbie; heck, I'm even beyond oldie --- maybe an extra oldie.
I use 3/4" 3-48 bolts to mount Tee Dees and Norvels and the like on beam mounts. SIG sells round pan head ones in bulk, I bought a bag of them years ago. So I'd say 3/4" would be about right for 3-48.
Iskandar
Iskandar
iskandar taib- Bronze Member
Matching bolts and blindnuts are a good idea. I can under stand that you want to go with imperial threads but the for the rest of us a metric solution would be better.
The best match I have found for the Pee Wee are M2 bolts (allen key head) and the blind nuts (in aluminium) made by MP Jet. For larger engines there are also M3 blind nuts with too different lengths (the short ones are fine a typical plywood firewall). Here is a pee wee with an M2 screw and blindnut to show what it looks like;
Thanks for all the suggestions.
Looks as if the 3 popular sizes for all 3 bolts are:
1/2"
3/4"
1" or longer for the modellers that like to cut to length.
For the "nut" part 3 different solutions:
Regular nuts & washers
Self-locking nuts with the Nylon inserts
Blind nuts that embed themselves in the wood
I am thinking that regular nuts and washers may not be necessary if there are self-locking nuts available? Trying to keep the # of products to a minimum but still present options that will be purchased.
Personally, I am 100% Metric and struggle with the Imperial measurement system but adding all Metric equivalents doubles the fastener inventory and I am not sure if we can do this at the moment.
We will also get some #2 and #3 sheet metal screws in a couple of lenghts.
1/2"
3/4"
1/2 inch on the sheet metal screws please. That is about perfect for going through the engine back plate and through a 1/8 inch bulkhead glued to balsa. Maybe a little shorter would be nice too, but if it is too long I cut them down and don't think too hard about it.
pkrankow wrote:1/2 inch on the sheet metal screws please. That is about perfect for going through the engine back plate and through a 1/8 inch bulkhead glued to balsa. Maybe a little shorter would be nice too, but if it is too long I cut them down and don't think too hard about it.
The plan was for 1/2" and 3/4".
» Queen Bee 074... What is the size of the socket screws of the muffler ?
» Cox Piston/Rod Ball Socket Resetting
» Phillips Head Tank Screws
» 8 cc fuel tank screws
» 5-40 x 1" socket head bolts
