» Prayers for my Wife Please by fit90 Today at 7:34 am
» audio-tach anyone?
by balogh Today at 7:04 am
by getback Today at 6:19 am
by rsv1cox Yesterday at 2:43 pm
by Admin Yesterday at 1:11 pm
hobbico nexstar mini ep
i have the opportunity to buy this at my lhs for $45 http://www.hobbiconexstar.com/nexstar-mini/index.html
what size cox engine would work best for a plane like this? it says auw should be around 25-28oz so i am thinking that a teedee or medallion .09 would work for this, if i could find a carb throttle for one of these engines (if they were ever made) that would be perfect.
Suggestions?
Thanks, MitchG95
Suggestions?
Thanks, MitchG95
mitchg95- Diamond Member
Re: hobbico nexstar mini ep
Definately a Cox TD 09 or Medallion 09 R/C. Tarno did make carburators for the TD 09. They can be found one ebay from time to time but they can go for $35 and up. You also need a muffler as the idle wont be that low since SPI allows air intake also. Using a muffler helps with the idle using a Tarno carb.
Norvel .074 R/C would be good as well. Has the throttle and muffler.
Jason_WI- Top Poster
You guys are missing the size of that plane. I can't find the prop size, but I'd fly it on a 049 or a 074.
It's very close to this
http://www.ebay.com/itm/271098328645?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
9x6E prop, got to make sure you have prop clearance.
I don't think I missed anything.
Ebay plane weighs 18oz and has a WS of 39"
Hobbico EP weighs 24oz and has a 44" WS.
Heavier and more drag with the wider wing = more power required.
Jason_WI wrote:I don't think I missed anything.
true, i dont think im going to purchase this plane because i need to save money to finish up the payments on my dirtbike
thanks for all the input
Except that fuel weighs less then batteries, which will bring the weight down to pretty close together.
NexSTAR Mini EP 25oz
- Lipo: 4.4oz
- Motor: 1.8oz
- ESC: 1.1oz
Total 17.7oz
Conversion:
17.7oz
+ RC Throttled 049: 1.9oz
+ Full 1oz fuel tank: 1.5oz
+ RX 500 lipo 1.5
+ 9g servo for throttle 0.5 oz
Total 23.1oz
Can save more weight by removing the electric engine mount, but will add some weight with dope.
I think it would be doable, I'd try it.
- Lipo: 4.4oz
- Motor: 1.8oz
- ESC: 1.1oz
Total 17.7oz
Conversion:
17.7oz
+ RX 500 lipo 1.5
Total 23.1oz
xplaneguy wrote:Cox .049 QRC Cessna 182 Skylane
Specs:
Length - 29.8 inches
Wingspan - 36.61 inches
Weight - 22oz.
Engine - Cox .049 QRC (Quiet RC) No throttle sleeve, just a muffler.
» Mini Bird-dog, mini tractor
» Hobbico fuel
» Hobbico's "Cox Super Fuel"
» Dawgies! Lookee this re: Estes!
» Hobbico Files Chapter 11
» Hobbico fuel
