» Norvel Needle Neededby F4D Phantom II Today at 11:25 pm
by rsv1cox Today at 6:07 pm
by MauricioB Today at 8:05 am
by MauricioB Today at 7:39 am
by 1/2A Nut Today at 2:52 am
by DanMc Yesterday at 9:07 pm
by roddie Yesterday at 9:02 pm
by mike in SC Yesterday at 7:42 pm
by roddie Yesterday at 5:13 pm
by roddie Yesterday at 2:51 pm
» Fox .35 Modifications
by Onelife Yesterday at 2:07 pm
by cstatman Yesterday at 2:03 pm
I think I shrunk a couple cylinders.
So I got a couple 'bee engines off ebay. Gummed up and jammed. They were so gummy the crank was sealed in place too. After about 3 days in denatured alcohol I was getting impatient. So I heat the suckers up with a bit of hot air from the heat gun.
e
Everything comes apart just fine, heads come off, cylinder comes off without extra heating. I heated the head pretty hot till black gooieness came bubbling out of the threads. I, unthinkingly, dropped the cylinders back into the alcohol bath with a royal HISS.
Then I free the crank, bubbly blackness again. I get the piston off and pull the cylinders to fit the pistons back in. Well, they are TIGHT with PINCH unbelievable!
Did I shrink the cylinder?
e
Re: I think I shrunk a couple cylinders.
Probably cooked the castor to a varnish. Take some 0000 steel wool to the inside of the cylinder and see if that helps.
Jason_WI- Top Poster
» A couple more new to me.
» CG postage stamp mounts.
» The Shrike gets some work.
» A couple of things, and a story
» couple of Medallions
