» Older ignition booksby lla Today at 4:17 pm
» Fox .35 Modifications
by Onelife Today at 3:54 pm
by rsv1cox Today at 3:33 pm
by getback Today at 10:23 am
» S1 Ringmaster
by Onelife Today at 8:40 am
by rsv1cox Today at 7:54 am
» O&R 23 & Brown Jr
by getback Today at 7:47 am
by MauricioB Today at 2:31 am
by rdw777 Yesterday at 4:16 pm
» Hemostat clamp/smooth-jaws
by roddie Yesterday at 3:48 pm
» Black Widow Run time
by Ken Cook Yesterday at 3:44 pm
by roddie Yesterday at 3:33 pm
cox 049 throttle ring
Last edited by getback on Wed Dec 17, 2014 5:32 pm; edited 1 time in total (Reason for editing : add pic)
Re: cox 049 throttle ring
Yes, the throttle ring has to go onto a cylinder with the outside ground smooth.
Thanks Phil , I kindy figured that you (someone) would say that after I looked at the second cyl. with the throttle ring on it I found // Do they come this way or has to be done by owner? At Cox Inter. says it will fit all 049-051 but not case cases ? And it looks like the same ring to me . Eric
Eric, I believe that the earlier rings had a smaller ID and came with a cylinder that had it's OD ground to fit. (I have a set) Bernie could tell you for sure.. but I think his rings are made with a larger ID to fit the standard-common thick-walled cylinders. They won't fit engines with the die-cast cases.
» Cox .049 Throttle Ring
» 09 throttle ring
» surestart throttle ring
» Cox Pee Wee .020 & throttle ring (homemade) and something else...
» exhaust throttle ring - again
» 09 throttle ring
