» Nostalgia alert, my 1959 Corvette revisitedby rsv1cox Today at 12:18 pm
» audio-tach anyone?
by roddie Today at 11:14 am
by rdw777 Today at 10:22 am
by fit90 Today at 7:34 am
by getback Today at 6:19 am
Glow Plug temps - please explain
I have never heard a good explanation on the workings of different glow plug/insert temps, that or I can't remember it.
Could someone please explain the usage of when to use a hot/medium/cold plug? I would be most grateful.
TIA.
TIA.
VUgearhead- Gold Member
crankbndr- Top Poster
Re: Glow Plug temps - please explain
Hot plugs are generally used for low nitro applications, 0-15%. They're also used in high percentage castor fuels. This is a common heat range for control line useage. The R/c crowd would use this plug in addition especially on older baffle piston engines which required low idle and peppy transitions. If the temp was cooler, the plug would drown out so many hot plugs have a additional idle bar which supposedly shields the plugs element from an abundance of fuel getting thrown at it. Medium temp range would be used for 10%-25% nitro fuels and this is a very common plug for modern r/c engines. However, these can be substituted for hot plugs if idle transition is cooling off the plug. Medium plugs would have a better lifespan due to the element being slightly heavier over the hot versions. Cold plugs are used for low compression high nitro fuels of 25% on up. Engine type and useage have a very large deciding factor as to what type of plug is required. They also have the heaviest element and take a bit more to light them up.
In general, experimentation is important but your nitro content is a very large part of the equation. Hot is for low nitro and cold is for high. Cox engines in general work superior on high nitro fuels. This assists in maintaining cylinder heat and needling of the engine. Ken
» glow plug qs
» Cox Tee Dee high-compression glow head question
» Glow plug conversion
» Cox .09 glow plug ?
» .049 glow plug
» .049 glow plug
