» audio-tach anyone?by 944_Jim Today at 4:17 pm
by rsv1cox Today at 12:18 pm
by rdw777 Today at 10:22 am
by fit90 Today at 7:34 am
by getback Today at 6:19 am
Hmmm... How come?
Hmmm... How come?
How come I never thought about using a tank mount with a Medallion and this throttle setup?
http://www.ebay.com/itm/1960s-Cox-Medallion-049-Engine-for-Remote-Control-/131690742263?hash=item1ea96141f7:g:w2IAAOSwZG9Wh6S1
Note: I put this in Cox Engines instead of Off-Site Auctions because I'm referring to the concept, not the actual auction itself.
The Stickler Mark
The Stickler Mark
batjac- Diamond Member
Re: Hmmm... How come?
Three questions.. Do those tanks have a clunk pick-up? Do they come apart for servicing? Were they made by Kavan?
edit: answered question #3..
Those tank mounts are desirable by certain collectors. I really don't know why. They were suited for free flight and r/c. They don't work well for control line use due to the pickup being in the bottom middle and the fact they put the engine way out. I've also seen them allow the engine to vibrate a good bit . There's no clunk and they eventually leak not to mention get real brittle.
Got one of those tank mounts NIB (jewel-case), guess I'll keep it that way since apparently it isn't all that useful. Thanks for the heads up.
Must be the rain.
batjac wrote:How come I never thought about using a tank mount with a Medallion and this throttle setup?
The Stickler Mark
Must be the heavy rain up your way.
What is the advantage of this setup over the muffler-throttle setup used on the Cox Dragonfly? Other than it is hard to find.
Happydad
happydad- Rest In Peace
I would assume they would be for control line only with the vent tube set up. I wouldn't mind cutting up a trashed one to see how they work.
Happydad
Happydad,
These actually throttle better than the rotating ring type. I've used both, and the slide restrictor coupled with the rotating spray bar makes for a lower idle and more linear response to the throttle.
I must be lucky. I've never had a leak problem with these tank mounts. Granted, I've not flown a huge number of hours with them. I've mostly used them for RC. I've only used one a couple of times in CL when I put one in my Medallion powered Coroplast PT-19.
The Steady Mark
What Cox overlooked is that the mounting bolt pattern of the tank is not the same as a Bee backplate. The height is the same but the holes are wider apart. This means you cannot do a straight swap from TD to Bee series engines or the other way around. The tank of the Dragonfly has the same mounting bolt pattern as the Bee backplate.
OVERLORD- Diamond Member
And the Dragonfly tank want go in all bee's neither , I have come across that a few times with a bunch of parts bags with pistons cranks tanks and cases and stuff in them ...thinking your going to build a few engines out of this haul and becomes a discussting night mare . getback
maybe not the cast crankcase??
getback wrote:And the Dragonfly tank want go in all bee's neither , I have come across that a few times with a bunch of parts bags with pistons cranks tanks and cases and stuff in them ...thinking your going to build a few engines out of this haul and becomes a discussting night mare . getback
maybee not the cast crankcase, but i have used the Dragonfly tank with several extruded crankcases.
happydad
The red plastic tanks used to be used a lot. I used them for my first 1/2A Profile Proto and Speed models. They'll run quite some time and easily I was getting 15 laps on 42 foot lines. I never knew where the pickup was but I wouldn't doubt that it's on the bottom center. My first couple of Tee Dees had these, one was a CG Lil Wizard with an 051 on the red tank and a Jumping Bean with an 051 on the same type red tank. They looked cool and I have a couple of replicas sitting around that be finished.
Chris...
Chris...
stuntflyr- Gold Member
