» Cox Ryan ST 2.0by GallopingGhostler Today at 1:42 am
» Looking For Comet Tri-Pacer
by DanMc Yesterday at 7:25 pm
by 944_Jim Yesterday at 7:04 pm
by 944_Jim Yesterday at 4:31 pm
by balogh Yesterday at 4:08 pm
by rdw777 Yesterday at 3:58 pm
by rdw777 Yesterday at 3:46 pm
by roddie Yesterday at 3:07 pm
» Removing old decals
by latole Yesterday at 3:06 pm
by rsv1cox Yesterday at 2:29 pm
by getback Yesterday at 6:46 am
by GallopingGhostler Yesterday at 6:33 am
Engine run time?
Engine run time?
This question is for the older fox 15x slant plug engine.Can someone comment on how long a 1 .oz tank would run the engine?I'm new here and I flew some control line in the past, trying to scratch build a combat wing similar to the jr. satan and such.Need to figure out what tank i'm going to use, amount of fuel I will need.
Thanks all for your comments.
oldguy- Gold Member
Re: Engine run time?
It has been a while, but for learning a 1 oz tank was what I recall being used on the fox 15. It gave a couple minutes of flight time. The best answer is to bench the engine with the expected prop and fuel and time it.
From the sound of things you plan to enclose the tank in the build.
I have a 15x and get around two to two and a half minutes on an ounce. This depends on fuel used, temp, prop and needle setting though. As Phil said its best to bench run the engine and time it, it's best to use the prop you plan on using as well as fuel. Those factors will effect your needle setting and fuel usage. Hope this helps! (Bandit)
Last edited by TDbandit on Thu Jan 07, 2016 4:58 pm; edited 1 time in total (Reason for editing : Wrong name)
TDbandit- Platinum Member
pkrankow wrote:It has been a while, but for learning a 1 oz tank was what I recall being used on the fox 15. It gave a couple minutes of flight time. The best answer is to bench the engine with the expected prop and fuel and time it.
Phil/Bandit thanks for your responses, yes i'm going to try and enclose the tank in the build.I think i want more time than two minutes.And your right, i quess the only real way to know is to run with different amounts and see.
Thanks guys
oldguy- Gold Member
Hey, Oldguy, welcome to CEF. Glad you found us, and hope you have fun here, this is a great group of interesting and helpful hobbyists.
RknRusty wrote:Hey, Oldguy, welcome to CEF. Glad you found us, and hope you have fun here, this is a great group of interesting and helpful hobbyists.
Thanks Rusty.
oldguy- Gold Member
The Jr. Satan calls for a Veco T23C tank which is a 2oz baffle I believe.
For the 15X That would probably get you 6 or so minutes. Bench testing and actually flying will yield different run times due to the difference in loads.
Welcome to the forum.
Starting with an ounce will be a good idea, if you make it possible to change to a larger tank later. Once you get the hang of flying, an ounce is going to be disappointing, sucking air way before you're finished having fun.
Ladies and gentlemen, the Captain has extinguished the fun light!
» engine run time, Tee Dee
» Another C.T. engine rebuild completed -- this time a Cox Tee Dee .049
» TIME TO VOTE ON THE *COX ENGINE OF THE MONTH*!
» It's time for "Cox engine of the month" again.ENTRY CLOSED
» Coper Reed valve melted too mutch détergent in fuel mixture
