» Nostalgia alert, my 1959 Corvette revisitedby rsv1cox Today at 12:18 pm
» audio-tach anyone?
by roddie Today at 11:14 am
by rdw777 Today at 10:22 am
by fit90 Today at 7:34 am
by getback Today at 6:19 am
Strange cylinder
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Strange cylinder
Nice work, that's a really cool mod.
crankbndr- Top Poster
Very cool indeed! Wondering if you used cylinder shims to index your single (open) exhaust-port straight back toward the pipe?
oh
Admin wrote:happydad wrote:Admin wrote:
They pop up on eBay every few years and they don't sell for cheap.
Are those blank cylinders? Don't you have a smaller picture? I mean a close up of the cylinders?
happydad < (RC car emoticon)
Not my picture, it's the only picture I have from an old eBay auction years ago.
You are forgiven. oh, and +1.
happydad
happydad- Rest In Peace
Yes I bought cylinder shims from ebay to realign the exhaust port and blocked off the front port.
I then raised the timing by filing the top of the exhaust port from 140 deg stock to approx 162 deg.
I also ground down the bottom of the glow plug to recover compression from the cylinder shim.
Shims came in a pack of 4 two thin and two thick as I recall.
Profi Tuned Pipe TD RC .050 non SPI - 1st bench test
Tarno Carb, Cox buggy header pipe with half moon brass shim to block 1 exhaust port
#5 cylinder 2 bypass ports and 2 boost flutes per port -1 shim HC Cox Plug
Tad rich approx 85% to optimum break in mode with new #5 cylinder
- Idle with Tarno carb 12,116 rpm APC 4.5 x 4
- vid recorded 20,996 rpm on the pipe best noted 21,370 rpm 25% nitro
Blank cylinder
I have one of the blank cylinders and a piston and rod . The cylinder is threaded on top and bottom as normal but the inside remains to be machined ( bored but not finished or ground ) . The piston looks to be a thin wall when compared to other pistons but that it just an eye ball look on my part . I can't recall where I picked it up but some of my old friends are speed flyers and might have come from one of them .
Mike 1484
Mike 1484
Mike1484- Gold Member
I will have some Cox cylinder blanks. Please see post for info if you are not already following that thread.
https://www.coxengineforum.com/t9328-cox-part-lot#118861
jsesere- Rest In Peace
Page 2 of 2 • 1, 2
» Strange Cox Cylinder(s)
» Here's a strange one
» Strange looking Olympic. 15
» Strange but true?
» Strange but true?
Page 2 of 2
