» Nostalgia alert, my 1959 Corvette revisitedby rsv1cox Today at 12:18 pm
» audio-tach anyone?
by roddie Today at 11:14 am
by rdw777 Today at 10:22 am
by fit90 Today at 7:34 am
by getback Today at 6:19 am
Cox Engine Under Water
Hi all. It is a ways away from the main event, but I would like to be fully prepared when the day comes. I have built a foam version of the Lil Swamp Buggy that will be powered by a Cox .049. Anyways, back to the topic. As I have never run an rc boat before, I am planning for the worst and was wondering what the protocol would be for a submerged engine. I am thinking the worst. Airboat flips over upside down. I would be there within a couple of minutes maximum from going over. I am thinking the following:
1. Removing needle and glowhead
2. Lightly blow out the engine
3. Apply a drop or two of oil in cylinder and rotate the crankshaft
4. Reassemble and run the little bugger again.
Or... would it be best to disassemble the while engine and blow out completely with air at a low pressure. I will also add that the engine in question that will be used is a product engine with horseshoe backplate.
Thanks for any help or tips you may provide.
Re: Cox Engine Under Water
The fuel in the engine will protect the parts pretty well. If you want to run it again right away, I would suggest spraying it full of something to purge it, maybe WD40 in every hole into the engine. Or brake parts cleaner. Shake it around and flip the prop to purge it and restart immediately. If you take it home wet, I'd just submerge it in a jar of fuel and shake it up. Then remove it, dry it and bolt it back on. The solvents in the fuel will soak up the water.
The old school way was pull the glow plug off and run WD 40 thru the intake till it comes out the top using
a electric starter to spin up the engine. Quick way to remove water from the engine and cheap solution.
Of course at the end of your boating day you should use some good after run oil thru the engine till
the next trip out to the pond.
Whooop Rusty beat me to it lol..
As long as it's not salt water it's not a real big deal. If it decides to try and chase a fish and takes a drink, Disconnect the fuel system and purge all fuel and clear the fuel line, then just pop the head off (remove the shim) and then flip it upside down if it has a spring starter use it and pump out any water that might be in it (If an inboard use the starter) just flip it through good. and re-oil the engine with WD-40 and work it through then blow out the head and reinstall the shim and head. refuel and run a couple of tanks through it to purge any extra moisture in it and your good to go. If it's salt water it's best to immediately tear the engine completely down including removing the crankshaft and clean it thoroughly with solvent including the reed, backplate with spray bar. Salt water leaves behind the salt and it sticks to everything and will quickly start eating the crank, piston and cylinder. hope this helps
(Bandit)
(Bandit)
TDbandit- Platinum Member
Good point re. salt water, didn't think of that.
Thank you all for the great tips. It will be only fresh water and I did originally plan to run it again after a submersion and water removal. It kind of looks like I may have over thought what to do, and it does appear to be a relatively simple process.
Dunked engine
Learning how to fly, I used an O.S. FS20 engine on a Balsa USA "Swizzlestick", a very simple R/C plane. I strapped a block of foam underneath and flew it over the water after hand launching, every flight ending up with the engine submerged.
The procedure was simply to rock the engine back and forth until the water was cleared out, refuel and then fly again.
Afterwards, I would pump AW30 oil into the crankcase vent until oil oozed out of the front crank bearing.
No problems at all even with ball bearings in this engine.
For a Cox 0.049, I would just rock the prop back and forth until most of the water was expelled from the cylinder and crankcase and then refuel and run again.
706jim- Gold Member
yep, Water Displacement #40, with the red spray tube you can blow out the water with solvent.
Back when I was around 15, I had a Dumas L'il Swamp buggy with a Babe Bee on it. We went to the lake often, so I built it to breakup the boredom. Ran great. But one day after I started it up and put it in the water, the boat wouldn't respond to the transmitter. Wha?!? I looked down and saw I had forgot to turn on the transmitter! I switched it on and looked up just in time to see the boat a wall across the water. On impact, the firewall popped off of the motor pylon and fell into the water! But, for some reason, I had the foresight to put a wire from the firewall to the deck. I walked around to the other side of the water and pulled the boat out of the water with the engine dangling. I just shook all the water out of the engine, glued the firewall back on, and kept going. Engine ran great for a few more years.
The Soggy Mark
The Soggy Mark
batjac- Diamond Member
Great idea there. I was actually pondering doing the same to mine, as the water I will be using it in is murky and about 14 feet deep. I am glad it worked out for you.
As an aside, and not Cox related, I was at a seaplane fly-in at a lake in Massachusetts about 25 years ago. I saw a Laddie Mikulasko North Star being flown with a .40 engine on it. The pilot made a low pass a little too low, and the plane went into the water. It actually submerged then popped back up. The interesting thing was, the engine kept running! None of us could figure it out, but the plane just kept going, and the pilot took off and flew around for a few more minutes before bringing it back in to the pits.
The Perplexed Mark
The Perplexed Mark
That cowled tail must have stayed out of the water, or if it did dip, maybe an air bubble momentarily surrounded the venturi. But that's still pretty awesome.
batjac wrote:As an aside, and not Cox related, I was at a seaplane fly-in at a lake in Massachusetts about 25 years ago. I saw a Laddie Mikulasko North Star being flown with a .40 engine on it. The pilot made a low pass a little too low, and the plane went into the water. It actually submerged then popped back up. The interesting thing was, the engine kept running! None of us could figure it out, but the plane just kept going, and the pilot took off and flew around for a few more minutes before bringing it back in to the pits.
The Perplexed Mark
I have seen this happen before also where the plane went in under water and popped back out still running at a float plane fun fly. The pilot took off again with water running out of the wings. This was back in the early 90's.
Jason_WI- Top Poster
It is possible to make a cowl that protects the intake and allows it to momentarily be immersed. Think upside down glass in the sink.
My Johnson 3hp had without a doubt been COMPLETELY underwater when used for trolling and it did not stall. That was when on my parents boat.
» Making a water-cooling coil for a Cox .049 engine
» Cox restorations for the week
» Water Wizzard
» Soaking a propeller in water?
» RC water-skier......
» Water Wizzard
