» Artwork for Otto Kuhniby Mark Boesen Yesterday at 11:53 pm
» Baja Bug / Dune Buggy Recoil Starter
by vambrosini Yesterday at 8:57 pm
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
by vambrosini Yesterday at 8:55 pm
» cox dune buggy/ baja bug
by vambrosini Yesterday at 8:49 pm
by 944_Jim Yesterday at 7:46 pm
» Joe Wagners Sioux
by GallopingGhostler Yesterday at 7:37 pm
by rsv1cox Yesterday at 10:29 am
» B-25 Mitchell
by rdw777 Yesterday at 9:49 am
» Cox water wizard
by Wiggy Yesterday at 6:32 am
by 1/2A Nut Sun May 12, 2024 9:52 pm
» Roddie's water-cooled bench-run vid
by roddie Sun May 12, 2024 8:55 pm
S1 R/M ? on build
S1 R/M ? on build
I have mention before i'm scratch building a Sterling S1 RM from plans.
I have question on the wing construction. The instructions call for 1 main spar 1/4 x 1/2. I'm thinking about going with two spars, 1 across the top of the ribs and one across the lower side of the ribs. I'm thinking about doing this because of ease of construction, and I have always built my .15 size wings this way. I'm asking here for pros or cons on this decision I have come to.
Another question is. What weight should I shoot for on the S1 RM, to be a decent flyer?
oldguy- Gold Member
Re: S1 R/M ? on build
The conclusion you have come to is a wise one. The internal spar aka “rib ripper” should be avoided. What you propose will work fine, but in all actuality it’s not really needed at all. The leading edge is the strength in that wing.
Some other tips:
Use the inner hole on the 3” bellcrank. Less is more with that big elevator.
Glass over the leading and trailing edge splits with epoxy soaked cloth or any strong thin material.
1/16” ply is all that is needed for the doubler. 25-32oz and it will manouver well.
Have Fun!
Some other tips:
Have Fun!
Thanks for your thoughts Ron.
oldguy- Gold Member
I'm still working on the scratch S1 r/m. Have a question for anyone, on the control rod. What size control rod should be the minimum? And any suggestions on what can be used? And where to get?
Thanks
Thanks
oldguy- Gold Member
I personally use 3/32"/ .093" . Reason being is that I mainly use Sig Nylon Bellcranks or Brodak's versions, The holes in these are very close to this size only needing some mild chamfering to allow for a proper fit. In addition, I use Dubro solder couplings on the control horn side which are designed for 4-40 clevises. Don't use 2-56 clevises if that's something you use. Of course, there's no need for clevises and a hard bend can also be used. This something I do equally. It takes a bit more time to perfect due to being very accurate. A 3/32" rod by itself is going to bow and a fairlead must be used to stiffen the rod. I use the loop of a safety pin to do this. I slide it on the pushrod and when I find it's proper location, I push it into the fuse. I rough the ends and place some epoxy into the holes that I made upon installation to retain it. The elevator of the Ring is quite large therefore the horn by itself is not enough strength and will either crack the elevator or pull out of the elevator. You need to make a small pad to under the horn top and bottom which I do using 1/64" ply to give the horn a bit more footprint and prevent the above. The wood control horn used on the early Ringmaster's is very poor and will fail usually without warning.
Ken Cook wrote:I personally use 3/32"/ .093" . Reason being is that I mainly use Sig Nylon Bellcranks or Brodak's versions, The holes in these are very close to this size only needing some mild chamfering to allow for a proper fit. In addition, I use Dubro solder couplings on the control horn side which are designed for 4-40 clevises. Don't use 2-56 clevises if that's something you use. Of course, there's no need for clevises and a hard bend can also be used. This something I do equally. It takes a bit more time to perfect due to being very accurate. A 3/32" rod by itself is going to bow and a fairlead must be used to stiffen the rod. I use the loop of a safety pin to do this. I slide it on the pushrod and when I find it's proper location, I push it into the fuse. I rough the ends and place some epoxy into the holes that I made upon installation to retain it. The elevator of the Ring is quite large therefore the horn by itself is not enough strength and will either crack the elevator or pull out of the elevator. You need to make a small pad to under the horn top and bottom which I do using 1/64" ply to give the horn a bit more footprint and prevent the above. The wood control horn used on the early Ringmaster's is very poor and will fail usually without warning.
Ken thanks for that the comments. I will go with hard bends and the safety pin fairlead.
Thanks
oldguy- Gold Member
oldguy- Gold Member
Keep an eye on that wood control horn, that can fail due to breaking or the glue joint failing. I've seen that more than once. I do understand that's how the original was built.
Ken Cook wrote: Keep an eye on that wood control horn, that can fail due to breaking or the glue joint failing. I've seen that more than once. I do understand that's how the original was built.
Yea, I read earlier in one of your posts about that. Its just for looks there's a nylon control horn below.
oldguy- Gold Member
What engine?
I love the colors and the hind-a-way horn cool didnt even see it !
Ken Cook wrote: What engine?
Red Head McCoy .35
oldguy- Gold Member
Cribbs74 wrote:The conclusion you have come to is a wise one. The internal spar aka “rib ripper” should be avoided. What you propose will work fine, but in all actuality it’s not really needed at all. The leading edge is the strength in that wing.
Some other tips:
Have Fun!
I sure hope that weight spec is without the engine. Because she is on the heavy side. It's the first time I have used ultracote, it is pretty heavy stuff. Will see how it flys, my first real .35 size plane. It will be a learning build/ fly experience.
oldguy- Gold Member
Correct me if i'm wrong, but the correct line would be .15 x 60' correct? Could I use this? 80LB
https://www.amazon.com/Spectra-Braided-Fishing-Hi-Vis-Yellow/dp/B000ALJFSM/ref=sr_1_2?s=sporting-goods&ie=UTF8&qid=1515455581&sr=1-2&keywords=power%2Bpro%2Bspectra%2Byellow&th=1&psc=1
oldguy- Gold Member
I would say you should be good with 80 lb. That's the correct product, more importantly it's the made in the USA version. The same product is made in China and is absolutely no good. I fly .25 sized 24 oz. planes on 100 lb. This is also a requirement due to the required breaking strength of .018 steel lines. When flying a Ringmaster, your line length from eyelet to eyelet should be about 58'-6".
oldguy wrote:Cribbs74 wrote:The conclusion you have come to is a wise one. The internal spar aka “rib ripper” should be avoided. What you propose will work fine, but in all actuality it’s not really needed at all. The leading edge is the strength in that wing.
Some other tips:
Have Fun!
No that’s with engine. I doubt the ultracote added that much weight. It’s lighter than monokote. What type of glue did you use? My Ringmaster is from an original kit and with age, repairs etc. weighs in at 38oz. It gets a little sluggish in the overheads, but is still flyable.
Cribbs74 wrote:oldguy wrote:Cribbs74 wrote:The conclusion you have come to is a wise one. The internal spar aka “rib ripper” should be avoided. What you propose will work fine, but in all actuality it’s not really needed at all. The leading edge is the strength in that wing.
Some other tips:
Have Fun!
oldguy- Gold Member
oldguy wrote:Cribbs74 wrote:oldguy wrote:Cribbs74 wrote:The conclusion you have come to is a wise one. The internal spar aka “rib ripper” should be avoided. What you propose will work fine, but in all actuality it’s not really needed at all. The leading edge is the strength in that wing.
Some other tips:
Have Fun!
Used ca and epoxy on the doublers and wing.
oldguy- Gold Member
Well, I wouldn’t worry too much about it. Just fly and see what happens. Not sure where you are at in flying skill level, but it will certainly fly in circles.
Cribbs74 wrote:Well, I wouldn’t worry too much about it. Just fly and see what happens. Not sure where you are at in flying skill level, but it will certainly fly in circles.
Don't like just flying in circles.
.15 video https://www.youtube.com/watch?v=ZTGsB1j1aQQ
https://www.youtube.com/watch?v=bqYFxuVMhZI
oldguy- Gold Member
Ok, well I guess all you can do is fly it. It will probably be just fine.
» Im back...
» Looking for first RC build...
» PT 19 Build
» IAR.80 Build
» Im back...
» PT 19 Build
» IAR.80 Build
