by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
Fox .15 Glow Plug Question
Ok. So just another little question regarding the Fox .15x. This time it is about the glow plug. The engine came to me with a short glow plug installed. However, tonight I looked and found it had I believe only one other short glow plug. So for testing purposes I tried a couple I had on hand. I tried a standard long, standard long with idle bar, and a medium such as an OS #8. I used only one gasket per plug. When installed, they all allowed the propeller to turn, and there was no contact with the piston that I could feel. Anyways with that said, what is the recommended glow plug for that engine, or can I use what I have on hand that works without contact. I am not oppowed to buying a new plug, but would like to use up what I have. As well, I am not sure they sell short plugs locally, but will call tomorrow to see. The medium length plugs like the OS #8 are readily available. Thank you again in advance for any help in this matter.
Re: Fox .15 Glow Plug Question
Instructions call for a short plug.
The Fox plugs are good for the trashbin.
If you are ising a medium or long without interference then it will be ok. I have run a long in mine. It’s not a long term solution.
I have used longs as well. Even though there's no contact, I use two copper gaskets if I need too.
Thank you for the replies. I now have what I needed for confirmation.
» Cox Glow Plug Clip Question
» Another Glow Plug CLip Question
» HELP! Glow plug adapter question...AP Wasp .061
» glow plug qs
» .049 glow plug ?
» glow plug qs
» .049 glow plug ?
