» Cox Ryan ST 2.0by akjgardner Today at 5:37 pm
by rsv1cox Today at 3:45 pm
by GallopingGhostler Today at 2:34 pm
by rsv1cox Today at 12:41 pm
by rsv1cox Today at 12:24 pm
by duaneh Today at 11:48 am
» Internet buy
by Ken Cook Today at 9:15 am
» Artwork for Otto Kuhni
by GallopingGhostler Today at 8:26 am
» Sherline lathe wont run
by getback Today at 7:15 am
by roddie Yesterday at 7:38 pm
» Feed Station Zebra.. Spring 2022
by roddie Yesterday at 5:59 pm
by GallopingGhostler Yesterday at 11:12 am
Wen-Mac/AMF .049 FRV MK XI, running on 30+ Y.O. Sig Champ. 25
I ran two model engines this past Sunday the 24th. This Wen-Mac was one.. and a Cox Reed-valve .049 was the other. I aim to focus on the Wen-mac.. because I'd never run one before. This particular engine was given to me by my friend Robert (our CEF member rsv1cox). Robert gifted me a boxful of engines a few years ago.. and this is one of them.
I'll apologize in advance; for my lack of video-editing skills.. but you're sure to enjoy the "tone" of this engine running.. and yes; the fuel I used is ancient.. a testament to Sig fuel and packaging.
https://www.youtube.com/watch?v=HVNUYHjFEkk
The Wen-Mac/AMF/Testors .049 glow-engine has a larger (than Cox) output-shaft, having a male-threaded American Standard Machine-Screw thread-size of 6-32 as compared to Cox's 5-40 female-threaded crankshaft... to accept a prop-screw. Therefore.. if you want to use a Cox .049/.051 OEM (or spec.) propeller.. you would need to enlarge the hub-hole to fit the larger (6-32 threaded) output-shaft on the Wen-Mac/Testors .049 glow-engines.
I chose to test a 5" dia. X 4" pitch 2-blade "DAL" brand propeller.. which is designed for drone/quad-copter applications.
These propellers have a beefy "hub" cross-section; as compared to your garden-variety quad-copter replacement propellers. Always observe applicable safety-procedures when running-up model-propellers to speed. Wear eye-protection/safety-goggles-glasses.
Re: Wen-Mac/AMF .049 FRV MK XI, running on 30+ Y.O. Sig Champ. 25
Nice run video Roddie! I have a couple of Testor/McCoy Engines that really scream!
Good Fun Ma n she really screams , sorry to say i have never ran one (Wen-Mac ) engine myself
Marleysky wrote:Nice run video Roddie! I have a couple of Testor/McCoy Engines that really scream!
Thanks Rene! It was really good have that engine start and run. I'll be more apt to try running a few others that have found their way to me. Do you have any models that you run, with your Testors/McCoy engines?
getback wrote:Good Fun Ma n she really screams , sorry to say i have never ran one (Wen-Mac ) engine myself
Hey brother Eric, Yes; it was good fun.. right from that first "POP". .. you know the one. Then it's just a matter of finding that "sweet-spot".. from "POP" to "CYCLE". Yea.. that took a little time.. but I'm working on being more patient.. because patience is a virtue.. or so they say.
When my flipping-finger got bitten... I went in the house to find a glove. I never tried the engine's integral spring-starter. I guess it's because the FRV engines won't run backwards.. as the reed-valve engines can.. and do.
So... Do you have any FRV Wen-Mac or Testors .049 engines?
Kim wrote:YEAH BOY!!!!!!!!!
YaHoo!!! Hey Kim! Those "DAL" 5040 (5"d. X 4"p.) 2-blade drone props have a .1968" (5mm) hub-hole that can be "bushed" using Dubro sm. silicone glow-fuel tubing.. for mounting on most of your 1/2A engines.
Can you suggest a U-control airplane engine-mounting preference for the Wen-Mac/Testors .049 FRV engines? There is a choice between a "beam" and a "firewall" mounting.
The "beam-option" seems partially-obstructed by the rear of the crankcase casting..
The FRV engine as you state can and will run backwards. Yours won't due to the springstarter catching. Flood a front rotary engine and it will run backwards. It won't run well but it does run.
Yea man i still got a few i find now and then , Maybee get one loosened up for a run next time out witch want bee longSo... Do you have any FRV Wen-Mac or Testors .049 engines? wrote:
I always enjoy watching one of these "other" engines run.
A few months ago I ran two that sync'd up pretty well.
Thanks for sharing roddie!
roddie wrote:Kim wrote:YEAH BOY!!!!!!!!!
I have done the radial mount on these, and used the Testors/Wen-Mac tank mount for the beam. But one day I got squirrely when I was cleaning up my desk. I had a Wen-Mac engine in one hand and picked up a Brodak 1/2A engine mount in the other hand. Hmmm... So I drilled three holes in the Brodak mount and made a profile Wen-Mac/Testors mount. It works, but the lower screw pokes the fuselage. No biggie, just make sure you fuel proof the fuse there. Also, you have to shave off the offset bump on the Brodak mount or the engine is not only offset to the right, but slightly down.
The Secret Mark
batjac- Diamond Member
RE: Wen-Mac/Testors .049 running
Roddie,
Nothing like a screaming .049 to make the worries of the world melt away !!
As mentioned above, the Testors .049 Red Head had a black tank mount similar to the Red Tee Dee .049 mount that would fix you right up.
Unfortunately, I haven't seen one for sell in many years.
Thanks again for allowing us to join the fun albeit at a distance !!!
Steve.....
Steve.....
66 Malibu- Gold Member
66 Malibu wrote:As mentioned above, the Testors .049 Red Head had a black tank mount similar to the Red Tee Dee .049 mount that would fix you right up.
Steve.....
The great thing about those Testors tank mounts vs. the Cox tank mounts: The red Cox tank mount had the fuel pickup at the bottom right of the tank, so it was only good for upright flying, whereas the Testors tank mount was stunt vented so it could be flown upside down.
The Inverted Mark
Whoa......... !!! Thanks soOoOo much for the replies. I don't know bout' the rest of you; but I've got this headwind that won't quit. Tryin' to rise above it though.
Regarding that Wen-Mac/Testors .049 FRV engine mount......... I've never seen one of those aux. mounts. These engines (I think..) are heavier than any of the Cox Bee/reed-valve engines.. so if I were to design or modify a model; I'd bee inclined to mount the engine rearward a bit. This engine ran good and drew fuel well with it's cylinder in an upright attitude. I'm leaning toward mounting it that way. I can make a radial firewall thick-enough to accept the X3 wood-screws. It may be back near to the wing's leading-edge.. but that's OK. I generally build/design my airplanes to utilize landing-gear; affording some balance-options.
Here's one from Ol George Galloping Ghoster from a few threads back:
I have mine mounted on a "Big Otto" by the 3 radial mounting screws. This plane was the first model I covered with Monocote, chrome monocote to be exact. The engine vibrations set up a frequency that vibrated the monocote while flying giving the plane a real "Mean" growl while in the air.
Unfortunately these tank mounts are very thin in the beams adjacent to the rear radial mount. This causes quite a bit of flex in the beams. Care when starting and a well balanced prop should overcome these issues.
observe propeller-safety (FF to 1:41 on vid)
Same session.. (later...) Cox .049 Babe Bee reed-valve engine, modified for the same -external- #2 Perfect-brand 3/8oz. wedge/stunt tank. 5"d. X 3.5"p. L/H 3-blade Cox propeller, same Sig "Champion 25" 30+ Y.O. glow fuel. This engine was castor-locked and needed a little heat-gun treatment to free-up but minimal. My homemade muffler is installed. It has a single/full-flowing header installed. Being minimally restrictive; there isn't much noise reduction.. but it does take the "bite" out of the exhaust tone. It's possible to do an exhaust-prime via the header-pipe.. I just didn't do it.
I got a bunch of those little Tin Perfect brand wedge-tanks from Dan McEntee a few years back. I've always liked them.
url=https://www.youtube.com/watch?v=rMbnSt7u9s0]https://www.youtube.com/watch?v=rMbnSt7u9s0[/url]
Last edited by roddie on Tue Nov 02, 2021 5:57 pm; edited 2 times in total (Reason for editing : removed redundant text)
Marleysky wrote:Here's one from Ol George Galloping Ghoster from a few threads back:
I'd never seen one of those. Thanks for posting. Yea.. "Kim Stricker's" Big Otto was also the first I'd ever seen. I'll likely use the 3-screw radial mount as you did in yours. I'm OK with using Wood-screws.. as long as they're biting all the way into good firm hardwood.
testor mccoy
Here is one of mine.roddie wrote:Marleysky wrote:Nice run video Roddie! I have a couple of Testor/McCoy Engines that really scream!
chevyiron420- Gold Member
It probably was roddie. I loose track of time.
» RUNNING the Cox 140
» Cox 140 Beaver
» Running my TD
» Running TD.049 for the fun of it
» Anyone else running Mac
» Cox 140 Beaver
» Running my TD
