» Joe Wagners Siouxby bsadonkill Today at 5:26 pm
» Happy Anzac Day!
by GallopingGhostler Today at 4:16 pm
by MauricioB Today at 3:43 pm
by rsv1cox Today at 12:27 pm
by roddie Today at 10:11 am
by rdw777 Today at 8:14 am
by getback Today at 7:31 am
» Fox .35 Modifications
by Ken Cook Today at 3:16 am
by getback Yesterday at 6:20 am
by rdw777 Thu Apr 25, 2024 8:15 pm
by rdw777 Thu Apr 25, 2024 8:06 pm
Help identifying Throttle Sleeve
Re: Help identifying Throttle Sleeve
It seems to be a COX 049/051 size throttle sleeve..If you have a COX 049 cylinder with the stepped wall, or thick wall, removed from the engine, and it fits, then it is for that engine size...a thin wall 049 cylinder is not good for testing, because of the small flange at the cylinder bottom with a diameter larger than the cylinder neck diameter, that will not allow the sleeve to slip on the cylinder neck.
It may fit a cox, I will pull a cylinder and check. However, I've never see one with openings (basically notches) like that. It's going to evenly restrict the exhaust port until it at the edge of the port. Not like other cox throttle sleeves I have or have seen. How is it going to work well?
Thanks,
Bill
Thanks,
Bill
ncpiperpilot- Moderate Poster
Even the genuine COX throttle sleeves will have a rather coarse throttling effect, where you have either full rpm or an idle, with a narrow control band between the 2..it is simple and reliable like a hammerhead, but one should not expect such a fine control by it as with carb throttling of larger engines..
Yours look like #56 in the COX Model Engine Handbook:
» Throttle sleeve and fuel tank
» WTB: 020 PeeWee Throttle Sleeve
» A TeeDee .051 cylinder that a .049/.051 throttle sleeve won`t fit
» Throttle Sleeve, ACE OR COX Setup??
» Texaco and Exhaust Throttle Sleeve
