» Jim Walker Firebaby by rdw777 Today at 5:08 pm
by Levent Suberk Today at 4:04 pm
» *Cox Engine of The Month* Submit your pictures! -June 2024-
by Davenz13 Today at 12:15 pm
by GallopingGhostler Today at 3:46 am
» S.M.A.L.L. 2024
by balogh Today at 12:21 am
by rdw777 Yesterday at 4:24 pm
» Feed Station Zebra.. Spring 2024
by roddie Yesterday at 4:10 pm
by Cox International Yesterday at 1:08 pm
» Cox Mustang repair
by getback Yesterday at 7:29 am
by batjac Thu May 30, 2024 10:52 am
» Cox water wizard
by 1/2A Nut Wed May 29, 2024 11:46 pm
» WenMac MkIII 049, Cox BabeBee, FOX 15X and 19 Prop Screw/Crank Threads
by roddie Wed May 29, 2024 7:34 pm
Queen Bee .074 carb?
Any one know if the spray bar in the QB .074 carb is pressed in or threaded in? I have to replace the plastic on my carb and am using all the other parts from the old carb for this.
Jason_WI- Top Poster
It almost looks as if it may have been molded into the plastic but I havn`t taken 1 that far apart to find out yet
Jaspur_x- Banned
Re: Queen Bee .074 carb?
i ended up with a spare carb after all the searchin and CEF help
i could try pullin i t apart later tonight if you like
ekitten2- Gold Member
nope mine i just griped with good plyers twist n pull...out it came easy peasy
no treads no nuffin just a pressed fit
there must be an easier way to post pics... 4 times now ive tryed an no joy
I used a soldering iron with a fine straight tip and heated the brass spraybar and pushed at the same time. Slid right out. Pressed the new one in with the arbor press. Just be sure to line up the hole in the spraybar with the hole in the fuel inlet nipple.
Now to tap the 2-56 threads as these appear to be unfinished.
» Cox .074 Queen Bee
» new 2.0 rc 1/16 049 powered bugy upgrade tee dee
» cox Queen Bee
» queen bee 074
» Queen Bee .074
» cox Queen Bee
» queen bee 074
» Queen Bee .074
