» My Cox .049 Marine inboard engineby F4D Phantom II Today at 8:05 pm
by rsv1cox Today at 7:26 pm
by F4D Phantom II Today at 7:21 pm
by roddie Today at 7:04 pm
by HalfaDave Today at 6:55 pm
» Norvel Needle Needed
by Greenman38633 Today at 5:36 pm
» World's largest weathervane
by Cox International Today at 3:38 pm
» Help Pee Wee tank cap .020
by rdw777 Today at 1:30 pm
by GallopingGhostler Today at 11:34 am
by rdw777 Today at 9:17 am
by getback Today at 8:21 am
by rsv1cox Yesterday at 7:29 am
Jerobee Corvette
Page 1 of 3
Page 1 of 3 • 1, 2, 3
are you looking at the sandblaster thread?
duke.johnson wrote:Thanks Man! Now I must search the web.
Duke: Are you watching the sandblaster thread? Someone started a thread showing the RC versions of the sandblaster, VW bug, VW buggy, Jeep, and others and I have been posting ebay ads for inexpensive, relative, RC and not Cox cars in that thread. check it out if you aren't already.
happydad
happydad- Rest In Peace
or something like this
I was trying to post this picture of my proposed drive train, but the pic got stuck in never, never land for and hour. I took the pic with my iPad and sent it to myself so I could do things easier with my PC. I sent the pic at 10:00p.m. PST roughly and it just came to my email at 11:12p.m. PST. If I would have known it would take so long I would have used my camera, transfered the pics to the PC via an adapter for my camera memory card and been finished by 10:30p.m. whatever
anyway here is my second proposed drive train with the same helicopter motor, same ESC, but different wheels and axle. I couldn't get the wheels off the Corvette axle, someone had glued them on. Don't the wide blue slicks look cool on the 'vette. I think the blue wheels are too small in diameter, but it gave me a better perspective on the fitting of the motor to the axle and how it would fit into the body cavity. I used to build slot cars during the late 1960's in Japan when I was there in the USAF.
the fit looks a little better. I just need to find the right spur gear for the axle. I need to measure a couple of the spur gears for the right diameter of the Corvette, looks like 3/4 or .75 inch.
p.s. that is not a spur gear on the axle, but it is the last Cox slot car gear I have.
happydad
happydad
2nd revision of drive train
This is the 2nd revision of proposed drive train for the RC version of my Corvette. It uses a Helicopter tail rotor motor and gear for driving the rear axle, and a small ESC that can handle up to 3 amps. I figure everything should fit under the trunk except maybe the main battery. I was thinking of using a 350 mAhr battery along with a 2.4Ghz 4 channel receiver.
proposal #2 using helicopter tail rotor motor and gear to drive rear axle.
happydad
happydad
Re: Jerobee Corvette
Coming together well, HD!!! Any idea's about steering and front axle?
OVERLORD- Diamond Member
Way Cool Vette Lieven! That throttle linkage must have been a challenge to design. The bend-angles on the pushrod.. it's length.. the standoff/guide that transfers the motion 90 degrees to engage the throttle-clip.. Even the servo-wheel's range of motion and pushrod position had to be very precise. Great photos BTW.. good to have as a guide for maintenance/reassembly.
This throttle-clip ear looks like it had to be bent/tweaked so as not to bind.
You had mentioned pulling the engine to clean/inspect? Let us know if it has the larger .082" (2.08mm) air-intake/venturi. I'm wondering if the engine components were along the lines of Black Widow, as far as performance. Since Jerobee also made a Tee Dee version.. I'm very curious about the cylinders/porting used on both engines. Do the ground cylinders have sub-port induction? I know that "mufflers" augment the benefits of SPI.. but does an exhaust throttle? The cylinder would still be sucking in fresh air.. just less of it when the throttle closes. I just noticed the brass cylinder-shim.. maybe that's in place to eliminate SPI for use of the exhaust throttle?
Congratulations! It's a mechanical marvel.. and I hope you have a lot of fun with it! If it were mine.. I'd build a dyno for tuning it!
Thanks Roddie,
I think you are mixing up the throttle control rod and the brake rod. The rod for the throttle is straight. The rod for the brake has a strange shape and hinges on the chassis.
The Greenwood Corvette is a little different from the Comando (Mc Laren Mk8) and the Bandero (Porsche). It has the external tank, a brake and wider tyres. It was delivered standard with the heat sink and a lexan body, much lighter than the ABS one. Bolow a picture of the original box:
I took the head of and I could see only 1 transfer port. Although the Jerobee blog says that there are 2:
"Greenwood Corvette.
The Corvette was a mid range kit.
On the box it says " Not recommended for beginners".
The Corvette had a twin intake ports in the cylinder and a large external tank. Wider chromed wheels with foam tires was standard equipment.
The body was made out of Lexan, not the hard Cycolac plastic as the McLaren and the Challenger had.
This was the fastest Jerobee with Cox Babe Bee and pull start, only the Cox Tee Dee version was faster."
http://jerobee.blogspot.fr/
Lieven
Lieven
OVERLORD wrote:Thanks Roddie,
Lieven
Yes, I see now. Still.. even straight, it's a novel way of converting to a sweeping-motion of the rod to rotate the clip/barrel. The band-brake's pushrod is baffling me. Is there a 2nd servo-horn beneath the throttle horn? I can see how it would work.. but can't see it connected anywhere. It appears that clockwise servo movement opens the throttle and releases tension on the band using the same servo.
My Jerobee is fantastic
As it's a calm period at work, I decided to give my Jerobee Corvette a clean. With a cotton bud and alcohol, I cleaned the chassis and all corners. I removed the engine for further cleaning. The tube to which connects the fuel pipe from the tank is the standard Cox pick up tube with the spring.
I removed the heat sink and head. The cylinder has 1 bypass port. The flyweights, clutch shaft and bell house bearing were in good condition. The hexagonal rear axle turns in plastic bearings that you have to pry open for fitting around the shaft. There is a little play on the rear axle gear. No play was found on the rear wheels. They are secured to the shaft with C clips. The brake band is a tie wrap from an electrician.
After assembling everything back together, I tested the servos. The steering servo was OK but the throttle servo was totally dead without giving any noise at all. Both servos are glued with époxy to the chassis. I tried to cut around the bottom edge of the servo with a knife to remove it without success. Not wanting to damage the chassis, I left it on there and decided to cut off the plastic servo shaft and to use the servo as a bracket for the replacement servo. This new servo is a lot smaller and fixed with a tie wrap to the original one. This meant I had to make a new throttle shaft and extend the brake lever. Before, the brake lever was also fixed to the servo wheel. I decided to just make a hook: when the servo is turned the other way, it pulls the hook and brakes will be applied without significantly change idle.
IDLE
FULL THROTTLE
BRAKING
I just filled the tank with some fuel and will let it sit during the night to loosen residues. To be continued.
Lieven
IDLE
FULL THROTTLE
BRAKING
Lieven
wow nice! vettie i would love to have one of those
cox24711- Platinum Member
Regarding the "Postwoman" headline.
I always tip the local mail carriers (two ladies) at Christmas. This Christmas I used a priority mail label on the envelope and typed "To the worlds's best mail carriers" on it. I'm still getting "Thank you" cards from these ladies that deliver the mail in all kinds of weather.
These are "contract" mail carriers. In our very rural post offfice there is just one government postal employee so there is no conflict of interest in them accepting a gift.
I can't get over what a mechanical marvel this model is.. and it's luckily in the hands of a fine hobbyist!
Looks to be cleaning up good for you , that will put some pep in you step . looking good Lieven , getback
Lucky duck Overlord, what a mechanical marvel in deed and in such great shape!
Awesome find and now in the safety of a skilled hobbyist that will take care of it and bring it back for all to see and enjoy.
Cheers!
Cheers!
Nice jerobe! I've seen one of those years ago. BTW you know that you can get a gear set for that S3001 servo right?
Part number is FUTM3400 same gear set as the futaba S148 and the servo is still in production bope this helps! (Bandit)
TDbandit- Platinum Member
Thanks guys, you're all very kind.
Thanks Bandit for the info. The reason why the servo stayed on the chassis as it was, is the fact that I can't get it off in a way that wouldn't damage the chassis. And because I can't remove the servo, I can't get to the bolts underneath to take it apart. The servo doesn't have a gear problem, I think it's an electronic failure or maybe just a loose wire on the circuit board!!
I had a look at the steering today. Not exactly Akkerman!!
To get tru rolling of the front wheels in a curve, the inner wheel should be more at an angle than the outer wheel. The pics above show the opposite. It's all in the linkages and connections to the steering arms. On original factory pictures, the steering rod is fixed between the servo and the most forward hole of the steering arm. On my model, both steering linkages are fixed to the rear hole in the steering arms. This makes a big difference. I uncoupled the ball joints at each side and put the servo in both left and right end positions. I then put each end of the steering linkages on the forward hole of the steering arm and that gives a better result:
Both ball joints will be moved forward and the I'll adjust the linkages to get a slight toe in for stable driving.
Lieven
Lieven
As said above, I removed the ball joints from the steering arms to move them forward and obtain a better wheel position while steering. The left one screwed out all right, but when I was half way on the right right ball joint... oh malheur!!!!... a part of the steering arm fell off. It seems to have been broken already before just in way of the enlarged hole for the ball joint. I discovered some glue on the steering arm.
I made 2 new steering arms from a sheet of ABS to glue on the original ones for repair and to reinforce.
I stuck both steering arms on with époxy. It is still drying until tomorrow.
There was plenty of rubbish in the fuel tank so I removed the plug. The rubber gasket is "slightly dated". I'm thinking of replacing the complete tank.
Lieven. A picture that you posted earler (which I have attached) shows a different steering set-up with a rigid tie-rod joining the steering arms at the outer hole and the control rod (drag-link) coming from the servo to the inner hole on one arm. This would maintain a better geometry than the set-up you are using. The trouble with your system is that as the servo rotates the relationship between the two steering arms changes, effectivily altering the toe-in as the rods raise and lower due to the rotation of the servo.
I'll try to explain what I mean. The two ball joints attached to your servo appear to be about 20mm apart when set straight ahead. As the servo rotates, the ball joints move together in the horizontal plane. At 90° of rotation, the gap is completely gone in a horizontal sense. This is reducing the toe-in by 20mm at "full lock".
I hope I explained it ok, but I think you need to change the design to what is pictured here.
Thanks Rod, yes I know; that's the original Jerobe set up with a proper track rod between both wheels. On some pictures, the track rod is connected to the forward holes and on others, to the rear ones. On my model, a previous owner mounted the servo saver and the more recent setup with 2 linkages. I just connected the linkages and did a test but it's still not the way it should be. I'll try to make a a proper track rod with only 1 linkage from the servo saver to the left steering arm.
Swapping the track rod from the front holes to the rear will not seriously alter the steering geometry, but will alter the ratio significantly between the servo and the wheels. It depends on how sensitive you want the steering. There will probably be a little bit of difference to the "toe-out on turns" as we call it, if you use the different holes, but it would be negligible.
I have had to try to rectify a couple of vehicles (full size) which had steering geometry faults and I can tell you for sure, you will nevr make the system that you have work correctly if you continue to allow the tie-rods to have up & down movement at the servo end due to servo rotation. Some type of bellcrank arrangement may help, but I would definitely use a common track rod to join the two sides to each other.
Just throwing this out there... how about installing a linear servo and/or a small mixing tray.. if you could build one to fit? Is the steering servo glued to the chassis too?
Here's a small one..
buy it here
or this.. which fits the Futaba S3003 servo.
buy it here
buy it here
buy it here
Nice job Lieven! The fuel tank looks like it could be a Sullivan #435 1oz./29.5cc slant-type.
You can obtain a stopper kit #S482 which is for glow-fuel.
This might be nice too.. #S469
Save the old clunk! It looks like the tapered bullet/cone shaped clunk. You might want to reuse it as it will drain the tank a little more effectively.
All the same clunks can be cleaned and reused with no worries.
That's the tank. I'll buy a complete new one. They are sold by Scientific France. I'll save the tapered clunk.
Page 1 of 3
