» Jim Walker Firebaby by rdw777 Today at 3:05 am
by roddie Today at 1:48 am
» Norvel Needle Needed
by F4D Phantom II Yesterday at 11:25 pm
by MauricioB Yesterday at 8:05 am
by MauricioB Yesterday at 7:39 am
by DanMc Fri May 10, 2024 9:07 pm
by roddie Fri May 10, 2024 9:02 pm
by mike in SC Fri May 10, 2024 7:42 pm
by roddie Fri May 10, 2024 5:13 pm
by roddie Fri May 10, 2024 2:51 pm
» Fox .35 Modifications
by Onelife Fri May 10, 2024 2:07 pm
by cstatman Fri May 10, 2024 2:03 pm
Cox car engine pull start return spring
Does anyone know where to get a Cox car engine pull start return spring?
I've searched several spring manufacturers and the narrowest spring they make is 1/2 inch like a measuring tape. I think the one in the pull start engine is 1/8 inch or less.
happydad
happydad
happydad- Rest In Peace
Re: Cox car engine pull start return spring
What is this for http://www.ebay.com/itm/1-NEW-VINTAGE-COX-049-RECOIL-SPRING-/161832799269?hash=item25adfc8c25 he don't say . Eric heres another for a buggy http://www.ebay.com/itm/Cox-Baja-Bug-owners-manual-and-replacement-starter-spring-/111758088518?hash=item1a054d1946
What are they gold plated?
getback wrote:What is this for http://www.ebay.com/itm/1-NEW-VINTAGE-COX-049-RECOIL-SPRING-/161832799269?hash=item25adfc8c25 he don't say . Eric heres another for a buggy http://www.ebay.com/itm/Cox-Baja-Bug-owners-manual-and-replacement-starter-spring-/111758088518?hash=item1a054d1946
Looks like the right part, but wow a lot pricey. Thanks for finding them for me. I looked for 3 hours last night. Spring, coil spring, tape measure spring, etc. I found a company that makes the material, but the minimum width is 1/4 inch.
Thanks getback.
Happierdad
Is yours broken at the end.. or is it missing altogether? I was thinking if you had all the pieces, you might be able to fashion a new end on the band-spring by using a small file or grinding a notch(es) with a dremel. I'm guessing that it's usually one end that breaks. Is there a slot in the housing to accept a "T"-shaped end? Another possible source for those little band-springs might be in these little retractable badge fobs. They're cheap enough to try..
retractable fob
retractable fob
Good idea
roddie wrote:Is yours broken at the end.. or is it missing altogether? I was thinking if you had all the pieces, you might be able to fashion a new end on the band-spring by using a small file or grinding a notch(es) with a dremel. I'm guessing that it's usually one end that breaks. Is there a slot in the housing to accept a "T"-shaped end? Another possible source for those little band-springs might be in these little retractable badge fobs. They're cheap enough to try..
retractable fob
Well, the spring was rusted, corroded into hundreds of small pieces so your idea of the retractable fob looks better and better. I'll check out your link.
p.s. i ordered 2.
happydad
Thanks. Happierdad
Last edited by happydad on Sat Sep 26, 2015 3:59 pm; edited 1 time in total (Reason for editing : to add data)
I had a fob that I took apart. The width of the band is .159" and it's approx. 26" long.
Here's what the "hook-end" looks like.
It attaches through a slot the spool. The other end just has a bend to fit through a slot in the center post of the housing.
I expect that most of these are made the same way. Do the innards of your spring-housing look anything like this?
great
roddie wrote:I had a fob that I took apart. The width of the band is .159" and it's approx. 26" long.
yup. that's what it is. can i have it?
and i ordered 2 of the fob things from china. they take 2 weeks to get here, so i won a car engine with pull start minus gas tank.
happydad
Heres your a spring Happydude, 8 bucks shipped.
http://www.ebay.com/itm/151831223776?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
crankbndr- Top Poster
Thanks
crankbndr wrote:Heres your a spring Happydude, 8 bucks shipped.
Thanks. I put in my bid. It is an auction, so you never know.
Happydad
You got a good shot, it didn't sell so was relisted.
» wanted Cox pull start cord or pull start repair kit
» Does Old Fuel Work? Because my NEW .49 with spring start won't start.
» Can You Help Me Identify the Pull Start .049?
» Cox Stocker 0.49 / Indy Car / Nissan GTP
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
