» Tired of it all…by balogh Yesterday at 11:55 pm
by MauricioB Yesterday at 11:53 pm
by MauricioB Yesterday at 11:36 pm
by 1/2A Nut Yesterday at 10:51 pm
by Kim Yesterday at 7:41 am
by balogh Yesterday at 12:34 am
» Joe Wagners Sioux
by GallopingGhostler Sat Apr 27, 2024 9:03 pm
» Happy Anzac Day!
by GallopingGhostler Sat Apr 27, 2024 4:16 pm
by getback Sat Apr 27, 2024 7:31 am
» Fox .35 Modifications
by Ken Cook Sat Apr 27, 2024 3:16 am
Medallion 049(051) RC
I just got my Medallion 049(051?)RC from an ebayer in used, but decent condition. Of course I have dismantled it into its atoms to see what it is like inside. A few surprises that I noted (also showing the engine had a previous life and was modified by the previous owner):
1. 051 cylinder (the piston has the groove on its skirt)
2. SPI cylinder porting....strange, because the SPI does not really get well with a muffler...
3. The backplate has a nipple to pressurize the external tank, but the nipple is undrilled...
Could anyone shed some light on what the original Medallion RC was like? I assume that must have come with non-SPI at least, let alone a 049 cylinder/piston size...
Re: Medallion 049(051) RC
any numbers engraved onto the case?
cox24711- Platinum Member
If it does ya got a gold mine on your hands.
(Bandit)
(Bandit)
TDbandit- Platinum Member
Unfortunately no number engraved on the case. A tiny spring clip is also missing where the spraybar connects to the throttle mechanism so I still have some homework on it.
Is the intake cutout in the crankshaft round or rectangle shaped? I bet it is rectangle shaped and someone added the throttle muffler kit to a TD .051 with a medallion carb body.
Jason_WI- Top Poster
It is rectangle so seems not original. Probably the only original part is the throttle carb and muffler combo as well as the shaft which has round cutout.
I have given it a second thought and see a chance that the TD case and Medallion shaft may not get along with each other well. If the rectangular cutout on the TD case is wider than the round cutout diameter on the shaft, chances are the fuel/air mixture suction time will be longer than intended and especially when the piston goes down and would start precompression in the crankcase, the shaft cutout is still open towards the crank cutout and may reverse some of the mixture into the carb...Just theorizing...I will tear it apart again tonight and see...
Actually the crankcase is the same with both the TD and medallion. The only difference between the medallion is the crank and PC set the crankcase, drive washer and collet are shared. The Medallion carb body will work on a TD, it just looses a little bit of it's umph from the smaller venturi, helps it pull fuel though. The medallion crank will work fine in a TD case The TD crank has the Retanglar cutout in the crank btw. (Bandit)balogh wrote:I have given it a second thought and see a chance that the TD case and Medallion shaft may not get along with each other well. If the rectangular cutout on the TD case is wider than the round cutout diameter on the shaft, chances are the fuel/air mixture suction time will be longer than intended and especially when the piston goes down and would start precompression in the crankcase, the shaft cutout is still open towards the crank cutout and may reverse some of the mixture into the carb...Just theorizing...I will tear it apart again tonight and see...
Hey Andras, who's the gorgeous Babe looking over your shoulder, is that Ms. Balogh?
RknRusty wrote:Hey Andras, who's the gorgeous Babe looking over your shoulder, is that Ms. Balogh?
Yes Rusty she is my ole lady..I showed her your question and she promised to prepare my favorite meal this weekend...thank you!
Viewer discretion advised
Viewer discretion is advised...the following video may contain graphic images of the messy corner in my garage and painfully high-pitch noise of a COX Medallion engine that some viewers may find disturbing on a lazy Saturday afternoon...
Boring winter...too much mud in the field so I decided to give this newly acquired then instantly refurbished Medallion RC O51 a garage run.
My takeaways from the run:
1. I should have cleared the mess in my garage before I shot the vid...you guys may think I am an utterly untidy man (only a bit so)
2. The throttle/RC carb combo is astonishingly well responding to the throttle movement. I guess it is more reliable than the RC carb of the more "noble" TD 050...just to make it clear, I love them both and all
3. The Muffler on a SPI 051 cylinder does not necessarily cause erratic run.
4. I may decide later to swap the Medallion crankshaft with that of a TD049, just to check the impact of the wider, rectangular cutout in the latter on the tach
5. BTW the acoustic tach on my phone showed sometimes double the actual tach..without pretending to be an acoustic expert I attribute this phenomenon to the echo in the garage where I was exiled to mess around with the engine behind a closed garage door..for the sake of the Saturday afternoon nap of our neighbors...In turn, I walked away semi-deaf after the run.
Hearing protection and a plywood sheet would have solved most of those problems.
I don't even mess about with engines without hearing protection. I feel better after the fun too.
Ha??? I cannot hear you!!!
