» Jim Walker Firebaby by rdw777 Today at 9:39 am
» Internet buy
by Ken Cook Today at 9:15 am
by rsv1cox Today at 8:55 am
» Artwork for Otto Kuhni
by GallopingGhostler Today at 8:26 am
» Sherline lathe wont run
by getback Today at 7:15 am
by roddie Yesterday at 7:38 pm
» Feed Station Zebra.. Spring 2022
by roddie Yesterday at 5:59 pm
by GallopingGhostler Yesterday at 11:12 am
by rsv1cox Yesterday at 7:43 am
» Baja Bug / Dune Buggy Recoil Starter
by vambrosini Mon May 13, 2024 8:57 pm
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
by vambrosini Mon May 13, 2024 8:55 pm
» cox dune buggy/ baja bug
by vambrosini Mon May 13, 2024 8:49 pm
My Dremel Tool Drll Press #212
Hi Guys and Girls , I have had this baby for a number of years and NEVER used it !! I cant find the manual but sure I can on line , I am thinking drill press , drum sanding , routing ?? I am wondering if any of my friends out there have one and what else you may would use if for and of coarse I just wanted to show this baby off . Thanks!! Eric
Re: My Dremel Tool Drll Press #212
routing flat bottom pockets would be easy.
slotting for whatever in thin or thick stock.
resawing? maybe?
Those can be handy. Last time I looked they cost more than the Dremel, so I haven't pursued the issue any.
resawing? maybe?
Well back then was not that bad I am sure my 395 dremel was pretty hi $$ with the whip that came with it , I had a friend repair it when the flex coupler went out , works fine now , here one on the bay but a lot of watching going on http://www.ebay.com/itm/DREMEL-MOTO-TOOL-Model-212-Deluxe-drill-press-stand-275-285-395-TOOLS-/301899783677 Eric
I pretty much found mine to be useless. It puts too much load on the tool when used as a drill. I found it to work ok for drum sanding attachments. What do you really need to sand though in the stand that you can't do with the tool in your hand? I find my drill press regardless of size to be very versatile . Ken
They are very useful for all the tasks mentioned. Primarily it is a drill press for reasonably accurate drilling up to the limit of the Dremel tool - about 3.4 mm. This can be quite a limitation.
If you look at this
http://www.stripersonline.com/surftalk/topic/46071-dremel-drill-press-212/
Another use is holding the Dremel tool horizontally and in this fashion you can also attach a flexible shaft.
Unfortunately, this model doesn't allow setting the press at an angle. It is either vertical or horizontal. My friend has one that does but I think it was done by adding another accessory to be able to rotate the body. I wouldn't recommend that though because it was a faff setting it accurately. It has to be adjusted using a spanner and three bolts.
I have never used a Dremel drill press but I have a similar drill press (well I have six drill presses of various sizes and capabilities). It is the Proxxon equivalent and I use it all the time.
In order to get the most out of drilling - I would recommend a machine (drill) vice or hold down clamps. Not much of a problem for balsa, plywood and engine bearers but if the drill grabs sheet metal while you are holding it - it hurts and delays your job while you clean the blood up.
A Dremel, although small, is a high speed drill and very unforgiving! As Ken says, the Dremel tool is easy to overload and I wouldn't also recommend drilling steel with it or any metal much deeper than 1/4 inch.
If you look at this
» I want to ask Santa for a mini table saw
» My Dremel tool hinge slot cutter.
» New Tool ! Magnetic Tool Holder from Matco !!
» Drill Press Question
» "Phred's Phault"
» "Phred's Phault"
