» Project Cox .049 r/c & Citabrian Championby rdw777 Today at 8:14 am
by rdw777 Today at 8:10 am
by sosam117 Today at 8:07 am
by getback Today at 7:31 am
» Fox .35 Modifications
by Ken Cook Today at 3:16 am
» Happy Anzac Day!
by Boats13 Yesterday at 11:03 pm
by getback Yesterday at 6:20 am
by Levent Suberk Yesterday at 12:23 am
by rdw777 Thu Apr 25, 2024 8:15 pm
by rdw777 Thu Apr 25, 2024 8:06 pm
by GallopingGhostler Thu Apr 25, 2024 5:12 pm
5 Sure Start Engine Radial
Found this interesting video of a radial engine made of 5 Sure Starts with a custom manifold choke tube throttle.
Location found: RC Groups, Discussion Vintage Glow Engines, Post# 40262839
I've run engines inside my garage with door closed during winter. Had a Castor smoke filled room that needed airing out by opening the garage door. I like the comment someone made about this.
Don't know if I'd brave doing this next to a load of unwashed laundry in a laundry room.
Re: 5 Sure Start Engine Radial
If he ain't married, that's great. If he is, he's got a bigger set than I by running it in the laundry room as you mentioned!
NEW222 wrote:If he ain't married, that's great. If he is, he's got a bigger set than I by running it in the laundry room as you mentioned!
I bet he is married. If he was single he would do his own laundry. Then, there would be no way in hell he would get the laundry and the rest of the laundry room all castor slobified. I am speaking as a single man.
fit90- Diamond Member
Personally I think he is probably a bachelor or a divorcee. Reason why I say this is that he probably figures that any whiff of glow fuel exhaust can be washed off dirty laundry. Also, he probably figures he can just open windows afterwards to clear the glow fuel exhaust fog. The laundry room is too small to run an engine in without it becoming very smoky quickly.
Even running a small engine, I find the garage filled with glow exhaust smoke. Reason is I use the same size bench run tank, a 1 ounce. Only difference is that a larger engine will burn through that 1 ounce faster than a smaller engine. End result is the same amount of glow exhaust.
Someone else posted another video on Facebook of a 5 cylinder radial Cox he created, but his layout was a single crankcase.
I think you're right NEW222. You can see the oil fog from the engine starting to cloud the living room. I'd never run an engine in a living room, let alone anywhere in the house except for the garage, and that with the cars out.
I ahve started a Enya .29 (tring to get a break in ) in my bed room when i was a teen and talking about a LOUD Noise man my dad thought i had lost it for sure that didn't last LONG !! If these guys didn't live alone they do now !
getback wrote:I have started a Enya .29 (trying to get a break in) in my bed room when i was a teen and talking about a LOUD Noise, man, my dad thought i had lost it for sure; that didn't last LONG!! If these guys didn't live alone they do now!
Yup, I'm sure you got your Dad's attention, hopefully it wasn't with a belt. I've run my Testor McCoy .35 Red Head in the garage. It was loud but I had earmuffs on. One ounce of fuel put a lot of Castor smoke in the air during winter. I then opened the garage and back door to quickly air it out. I didn't want to coat the walls and objects in the garage with Castor mist.
» Cox radial engine
» Beautiful radial engine!!!
» 1939 Plymouth truck.. with radial engine installed
» Correct procedure to start a 0.10 tee dee engine?
» Cox radial engine
