by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
So, what's the trick?
I used the search but had no luck in finding an answer.
It was easy to press the crankshaft out of the crankcase on my Tee Dee .010.
My question revolves around on how to properly reattach the prop drive washer onto the crankshaft of a .010. The prop screw is a 2-56 x 5/8" long slotted head. VERY easy to bugger up the slot head when trying to tighten up the screw with propeller attached. I have had no success, for the prop, prop driver and spinner leaves very little room for the 2-56 to screw into the crankshaft. I know it's not easy to align the spline on the crank with the drive plate while trying to hold all the parts together and tighten the 2-56 bolt.
Any suggestions with this teeny tiny engine?
DrCox- Gold Member
Re: So, what's the trick?
Don't use the stock prop and screw to re install the drive washer. Source a longer 2-56 allen socket head and place the drive washer aligned on the splines. Put a 2-56 nut on the allen bolt and then place a washer after it. Screw the assembly into the crank and back the nut down onto the drive washer while using a allen wrench to hold the screw. It will press it on and it will firmly stop.
I double posted, sorry for that
Howdy Doc! Welcome to the CEF. Ive never removed or replaced a drive plate on any of my 010 engines. I would highly recommend you follow the instructions given for doing this same thing on the 049 engines. You will need to obtain a 2-56 threaded stud, with 2 washers and a nut to drive the propeller back on and press fit the drive plate back in place. Here’s a lick to Cox Internationals tool to install the 049 prop driver:
You might have to select and inlarge the instructions. :
https://coxengines.ca/assembly-tool-for-cox-.049-engines.html
Oops Ken jumped in before I could type it up. Allen head, good choice!
Some great ideas.
Now where to find a 1" long 2-56 socket head bolt. Local Hobby Town just doesn't stock small parts the way hobby shops use to do. Any suggestions?
Thank you gentlemen.
DrCox- Gold Member
http://brodak.com/2-56-x-1-1-2-mounting-bolt-sets-with-nuts-and-washers.html
Slot head screws, but you can use an exacto blade or other suitable piece of flat sheet metal as a sort of wing nut and get the control you are looking for.
Dave P.- Gold Member
Dr,
Where are you? I'm sure one of us can "pay it forward."
What's a good screw between friends?
Um, that didn't come out right.
My local home town hardware store stocks the little screws and nuts...I get them there often enough that I have plenty. 7/8" may be the longest I have.
Dave P. wrote:http://brodak.com/2-56-x-1-1-2-mounting-bolt-sets-with-nuts-and-washers.html
Slot head screws, but you can use an X-acto blade or other suitable piece of flat sheet metal as a sort of wing nut and get the control you are looking for.
Great site. Thank you Dave for the effort of listing the hotlink.
As an update, I magically found a 2-56 one inch long slotted head in the hobby drawer at home. Followed the advice form Ken Cook and aligned the spline marks from the crankshaft onto the prop drive plate. Dropped a little oil onto the drive plate prior to the alignment. Stuck a plastic pen barrel inside the crankcase to prevent crankshaft rotation. Slowly tightened up the nut onto the drive plate (slowly) and the prop drive plate was pushed onto the crankshaft. Done. No damage. Easy to bugger up.
Really sounds like no big deal, however with my old fat fingers and the tiny parts of the Cox .010, refreshed my memory as to why I avoided the profession of watch repair.
Thank you again gentleman.
DrCox- Gold Member
Here was the project. Internal tank cap screws had to be slowly worked in and back out several times with some oil. The tank back was challenging at best to properly seat with the O ring. Personally, I like the appearance.
DrCox- Gold Member
» Trick or Treat
» Whats wrong in this photo?
» Whats inside your Medallion ?
» And the guess whats hiding in there winner is..................................
» whats this gizmo then? Engine mount from toy?
