» Roddie's flat-bottomed boat..by OVERLORD Today at 10:11 am
» Tired of it all…
by Ken Cook Today at 8:04 am
by Kim Today at 7:41 am
by getback Today at 6:46 am
by balogh Today at 12:34 am
» Joe Wagners Sioux
» Happy Anzac Day!
» Fox .35 Modifications
Cox .09 direction of rotation
I searched for this answer using the search feature but did not see it. Will this engine turn either direction or is it a right hand rotation only ? Also is the engine a worthwhile engine to own and reliable ? Thanks in advance guys. You have been so helpful. Mark
Greenman38633- Gold Member
Re: Cox .09 direction of rotation
Yes one way in less you have a left hand crank shaft ??? And they are good easy start
dependable engines ! TDs will with a left hand crank , Hard to get though.
Ok thanks getback Appreciate that
Your welcome Greenman , the .049 TD ones come up now and then but never seen one for a Medallion more less a .09. You running some today ? I am thinking about it nice in the 68 F today Whowoo
Well, it will run left hand with a right hand crank. You just remove all the head shims and use high nitro fuel. It'll run backwards... for about three seconds.
The Over-Compressed Mark
batjac- Diamond Member
Hehehe Batjac. Eventually I’ll get one of these Cox planes in the air. Havent flown since 2011. So many hobbies. So little time probably within a couple of weeks. The recently acquired used Stuka will be first. Then probably the P39 Firehawk. I will report all the Drama and mayhem right here on this forum. Thanks getback and All
Greenman38633 wrote:Hehehe Batjac. Eventually I’ll get one of these Cox planes in the air. Havent flown since 2011. So many hobbies. So little time probably within a couple of weeks. The recently acquired used Stuka will be first. Then probably the P39 Firehawk. I will report all the Drama and mayhem right here on this forum. Thanks getback and All
I'm looking forward to reading about your flying adventures.
» Having trouble starting my pee wee .020 Help!!!
» Tee Dee .049 crank rotation question.
» Crank shaft rotation
» cox rc cars gtp 049 mod
