» Artwork for Otto Kuhniby Mark Boesen Yesterday at 11:53 pm
» Baja Bug / Dune Buggy Recoil Starter
by vambrosini Yesterday at 8:57 pm
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
by vambrosini Yesterday at 8:55 pm
» cox dune buggy/ baja bug
by vambrosini Yesterday at 8:49 pm
by 944_Jim Yesterday at 7:46 pm
» Joe Wagners Sioux
by GallopingGhostler Yesterday at 7:37 pm
by rsv1cox Yesterday at 10:29 am
» B-25 Mitchell
by rdw777 Yesterday at 9:49 am
» Cox water wizard
by Wiggy Yesterday at 6:32 am
by 1/2A Nut Sun May 12, 2024 9:52 pm
» Roddie's water-cooled bench-run vid
by roddie Sun May 12, 2024 8:55 pm
Tee Dee .049 crank rotation question.
I bought a used TD .049 on eBay last week and got it thoroughly cleaned up. It looks to me that the port in the crank slightly off TDC. I'm assuming it's timed. Is the crank rotation CCW when looking at the front?
Cajun66- Silver Member
Re: Tee Dee .049 crank rotation question.
Yes, it's timed, and it will only run in one direction. Most are CCW viewed from the front, but Cox did make some that turned the other way. If it's flooded you may see it turn backwards, but only slowly.Cajun66 wrote:I bought a used TD .049 on eBay last week and got it thoroughly cleaned up. It looks to me that the port in the crank slightly off TDC. I'm assuming it's timed. Is the crank rotation CCW when looking at the front?
» Crank shaft rotation
» Proper Propeller Rotation Question
» General TD Crank Limit Question
» Finished cleaning the chopper engine (baby bee)
» Cox .09 direction of rotation
