» Hawk had breakfast and then took a bathby 706jim Today at 8:13 pm
by roddie Today at 7:38 pm
» Feed Station Zebra.. Spring 2022
by roddie Today at 5:59 pm
by rsv1cox Today at 12:26 pm
by GallopingGhostler Today at 11:12 am
by rsv1cox Today at 7:43 am
» Artwork for Otto Kuhni
by Mark Boesen Yesterday at 11:53 pm
» Baja Bug / Dune Buggy Recoil Starter
by vambrosini Yesterday at 8:57 pm
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
by vambrosini Yesterday at 8:55 pm
» cox dune buggy/ baja bug
by vambrosini Yesterday at 8:49 pm
» Joe Wagners Sioux
by GallopingGhostler Yesterday at 7:37 pm
» B-25 Mitchell
by rdw777 Yesterday at 9:49 am
Glow plug will not glow
Cox .049 glow plug will not glow with a 3 cell D battery pack, using a cox plug clip. The clip measures 1.44 volts. The glow plug works with a cad battery igniter, measuring 1.2 volts. The glow plug is 30 years old if this matters. Any help will be nice. Thanks
Cox@1943- New Member
Re: Glow plug will not glow
Hello. I noticed that myself the other day. I was using a kwik clip type connecter. But if I wiggled it around some I could see it try to lite up. I’m going to take my dremel wheel and shine up the areas of contact to get a better connection. Maybe that is your problem also
Greenman38633- Gold Member
Your test leads may be sharp/pointy enough to cut through dirt and tarnish on your glow clip. Your glow head fins and top "pin" may be too filthy to make good contact with the glow clip.
Ensure your glowplug is clean. You may need to wire brush between the fins of the head and the "tip." Also clean the contact surfaces of the glow clip.
Then try again.
Then try again.
Scrape contact points of Cox glow clip. Also use a thick cable to supply enough current.
Levent Suberk- Diamond Member
Mecoa
May even be make/break contact inside wire wire covering. Enough contact for voltage measurement but break under load.
Do you coil or wrap up your lead after use ?
Pr dictive text being a compl te pita today
Coxfledgling- Gold Member
Glow plug clip working
Bought new batteries now that Clips is working it was showing 1.6 V not sure what was going on with the other batteries.
» .049 glow plug
» The .049 glow plug ?
» Atwood 049 Plug ??
» Glow plug science - Ken, anybody?
» Fox .15 Glow Plug Question
