» Roddie-Rigger.. a 2005 original designby roddie Yesterday at 11:21 pm
by roddie Yesterday at 10:50 pm
by roddie Yesterday at 9:36 pm
by F4D Phantom II Yesterday at 9:33 pm
by Kim Yesterday at 8:53 pm
» Help Pee Wee tank cap .020
by MauricioB Yesterday at 8:45 pm
by GTO455 Yesterday at 8:11 am
by rsv1cox Yesterday at 7:29 am
» Post your Older books
by rsv1cox Mon May 06, 2024 7:51 pm
by rsv1cox Mon May 06, 2024 6:58 pm
» I brake for Turtles....
by rsv1cox Mon May 06, 2024 6:38 pm
» Ball - Socket Joints
by Ken Cook Mon May 06, 2024 3:06 pm
Slight Issue
Slight Issue
Hey Everyone. I was running my Killer Bee today and it seems to randomly lean out. I like this engine because you definitely know when it leans out. It has a massive power surge. The setup was as follows:
1. 2 ounce tank
2. 15% Fuel
3. Tank was below venturi
Whenever it would lean out I would go to richen it up. When I did this it would go way rich. I am thinking maybe that there is crud floating around and when I richen it back up it gets pulled loose letting it go back to normal causing it to go too rich. Any other thoughts?
Rolla
1. 2 ounce tank
2. 15% Fuel
Rolla
Godsey3.0- Platinum Member
Re: Slight Issue
Make sure the fuel is on the same level as the venturi. That Killer Bee doesn't develop much vacuum inside that huge venturi and it won't fight gravity very well.
An inline filter should rule out flotsam in the fuel. Are you sure the needle isn't spinning? They need a tube and washer even more than a tanked Bee, because of the low vacuum.
Edit: with only 15% nitro it might run better with a Babe Bee head.
Re: Slight Issue
The fuel is clean. The engine was a little crudded with castor when I got it. I cleaned the outside to a nice finish. Has no scratches. It is rather random (it seems) when it does it. Needle valve is not spinning.
What washer and tube are you talking about? Prop washer? Tube on the needle valve?
Re: Slight Issue
The tube and washer to seal the NV. It's likely gravity. Or a crankcase leak.
You have bladder supplies, why not feed it with pressure.
Re: Slight Issue
That is worth a try. I had been running this engine rather rich. It felt as if it had not been run much. Same for the Hopper. Made me excited. Newest Cox engine I have owned. I need to polish the crank of the Killer Bee. That should really help it along.
Rolla
Rolla
Re: Slight Issue
Don't get too carried away with the polishing. That's one of those things for when you're trying to eek out the last bits of hidden horse power. Meticulously balance your props, hubs and all, if you want the most out of your engine.Godsey3.0 wrote:That is worth a try. I had been running this engine rather rich. It felt as if it had not been run much. Same for the Hopper. Made me excited. Newest Cox engine I have owned. I need to polish the crank of the Killer Bee. That should really help it along.
Rolla
Re: Slight Issue
Are you using an old metal tank, or using brass tubing? Sometimes brass tubing will get a crack that leaks some air. It will run with your setting until the hole is uncovered then draw both air and fuel causing it to lean out as you describe. Copper tubing is better.
Geoge
Geoge
gcb- Platinum Member
Re: Slight Issue
I'm with Matt re the self adjusting N/v
If you mark the nv (I pinched the top of mine with
A pair of pliers) you'll see it moving at v high revs.
I'd put money on it.
If you look at my tube killer bee you'll see it doing
Just that against the tacho before I realised what was occurring.
John Goddard- Diamond Member
Re: Slight Issue
It is not the Needle Valve turning. The fact that when I open it up it goes too rich disproves that. Last run I watched it and the NV is not turning. The tank was used on Space Hopper and OS Max 10. Both were fine. I soaked the engine in alcohol. The NV was a little gummy. Space Hopper's NV was frozen. Jeat and fuel barely get it loose.
Side question; on a Tee Dee, are the threads on the outside of the metal venturi or around it? I guess I l should ask does it thread into something or around it.
Thanks a Bunch,
Rolla
P.S. I will try the tubing and washer. Later. Very early right now. Sun has not risen. Chilly outside.
Thanks a Bunch,
Rolla
» Martian Invader by Walter Musciano
» Mosquito, finished
» The non-issue (to me) of engine RPM's
» A Stricker Model Airplane Weekend, Gusty Winds, and an 'Out of the Blue' Nobler
» Fox .29....issue
» Fox .29....issue
