» WenMac 049 - Glow Plug & Head Gasket replacements?by Ken Cook Today at 3:17 pm
» audio-tach anyone?
by roddie Today at 2:58 pm
by roddie Today at 2:54 pm
by rsv1cox Today at 2:43 pm
by 1/2A Nut Today at 1:58 pm
by Admin Today at 1:11 pm
by rsv1cox Today at 10:26 am
by rsv1cox Today at 7:32 am
AMF Wen-Mac parts or help
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: AMF Wen-Mac parts or help
How do you want me to pay for it, I will take them, maybe something I can work with.Cribbs74 wrote:What does a MKIII look like? I several testors/wen mac engines that I have no use for. $20 including shipping and they are yours.
pat
goody- Moderate Poster
I will take it, if for nothing else then parts. I found the prop for the engine yesterday, surprise surprise, but no heads.Kim wrote:Hey Pat,goody wrote:Kim the Mk XIII picture you posted is the right one. The head in the far right is the one I have left. I use to buy my heads from Testors I think, don't really remember. I at one time had several heads, and a cylinder but they have been lost in 50 years. According to the 0.049 users group the Mk XII and XIII are interchangeable, mfg dates 1964-1966. The difference in the motors is Testors on the Mk XII. Heads and a needle valve or two would be good, or if you want to get rid of it I can take the whole motor. I would like to be able take a burned out plug and adapt it to use a standard short 1/4 in. plug. I have both pieces of my needle valve and can possibly silver braze it back together. I can also turn a new one from 3/16" bar but the compound taper may be a problem, very crude machinist skills, and a Unimat micro lathe.Kim wrote:Think so...but also thought Pat was going for as original as possible. We'll see when he checks in...
pat
Yeah the poor Wen Mac needles AWAYS took it on the chin, and they're the one item I have to swap around to run my engines. There are probably some in Ron's batch, so you should be in business. If you think you have a use for this engine, I got it turning easy with good compression, and the spring starter IS good! (Miracles!)
Anyway. let me know and I'll shoot it to you on the cheap !
Waking Kim
pat
You got it. Please PM me your mailing address, and I'll get it on it's way !
Engine parts, Wen-Mac
Kim,
I picked up a couple of scrappers on ebay, both seized, one testors throttle head Mk XII (broke crank), and one Wen-Mac Mk XIII, good needle valve. Haven't tested the heads to see if they will work.
Were you going to send me some parts, how much you need for the shipping??
pat
pat
Yo Pat,
You should get that core engine and it's two heads tomorrow or so. I included the notched-style head in case you could use it as-is or, as a spare practice part for your experiments in threading a plug into the thing.
I sent it on the cheap for 2 bucks and change so the money's no factor...just do a post on your progress if you get it going!
Later!
Later!
Wen Mac MkXIII
Will most certainly post progress with pictures in case someone else wants to duplicate my efforts. I want to remember the old glow heads burned out frequently, mostly when the engine started and the clip wasn't jerked off immediately. I went though a bunch of heads.
pat
pat
What voltage were you using?
1.5 volt dry cell lantern battery, I used to fight that over and over.Cribbs74 wrote:What voltage were you using?
Will be making my own fuel now for a few runs, I have the ethanol and castor oil. When I flew in college the club made fuel in a 25 gal drum, several of the guys in the club raced dragsters too, we usually flew every weekend, 3 or 4 combat sessions burns up a lot of fuel, we flew 1/2A and 1A mostly, although one of the guys had a Stearman biplane scaled for a barbie doll, somewhere around a 5-6 foot wingspan, Enya 90 was the engine, 14" prop, he flew wire control on 80# test steel shark leader with a throttle.
The club had roughly 60 flyers, we usually had 3 circles running at any given time. I still have the wing from my 1A
Zero, it didn't make it through the last battle.
I don't remember the exact mixtures but will start with 80/20 then see if I can get some nitro to add to it. I don't want to run hotter than 5% nitro or will smoke the old engines.
pat
ive got a few of those it uses the same head as the fibreglass pipe bomb wich i have several
iff interested shoot me a PM
ekitten2- Gold Member
dont forget those engines use a thin aloy gaskit outher wise the compression is to hi it mite explain the glow plugs blowing quickly
ekitten2 wrote:dont forget those engines use a thin aloy gaskit outher wise the compression is to hi it mite explain the glow plugs blowing quickly
Actually the Wen-Mac heads with the flats do not use a gasket, they have a 3mil aluminum ring turned into the base of the head and that acts as the gasket. The other style heads I will have to check to see if they have the ring. So far I have taken apart all 4 of the engines I have and none have a gasket. I plan on using a thing copper gasket on the twin and the singles.
pat
yes i knew the newerfiberglass cased engines use a mschined ridge as gaskit
Ron, Last I knew you were out of the country until Nov. 24, so I finally got around to posting you back. I have sort of started the design for the build. Let me know where to send the $20 to for the parts you have.
pat
Pat,
I sent you an email.
If anyone has any broken or worn out Wen-Mac .049s of any year I would be interested in buying them.
Happy to pay shipping etc. and can do Paypal.
gossie- Gold Member
OK, I just bought one of these that is in real bad shape,should be fun to restore.I need to fabricate a cowl canopy and elevator.one good thing , the engine stil has the needle , That seems to be a rareity in the wen mac engines.
akjgardner- Diamond Member
akjgardner wrote:OK, I just bought one of these................
One of these what? Sounds like you got a plane. What is it?
wen mac AT6Oldenginerod wrote:akjgardner wrote:OK, I just bought one of these................
Not specifically about your plane, but this is an interesting read.
https://www.coxengineforum.com/t10376-wen-mac-story
Nice plane, Wen-Mac made several different versions of this plane, SNJ (Navy) and (Army) AT-6. They fly like most model airplanes made of plastic.
» for sell, 3 parts baby bees. and other cox parts
» WTT TD .049 parts for Medallion .049 parts
» WTB: Correct Crankcase for '58 Babe Bee
» Fox 049, 07, 09 Parts Identification
» Parts Cox TD-4
» Parts Cox TD-4
Page 2 of 3
