» Roddie's flat-bottomed boat..by roddie Today at 12:55 pm
» Tired of it all…
by Ken Cook Today at 8:04 am
by Kim Today at 7:41 am
by getback Today at 6:46 am
by balogh Today at 12:34 am
» Joe Wagners Sioux
» Happy Anzac Day!
» Fox .35 Modifications
Fox in the McCoy Hen House
Ron Cribbs gave me a Fox .35 Stunt 3-Bolt Back engine, it came in today, woohoo! This is definitely old iron but has been updated with Allen socket head screws, now prop thrust washer and nut with very good compression. Thanks Ron! I'll bench run it in a few days to get familiar with it.
Re: Fox in the McCoy Hen House
Cool deal !! can't wait to hear it run ( bee careful out there) Eric
Here's the airplane that the Fox would make a good candidate for:
https://www.coxengineforum.com/t6972-1960-berkeley-interceptor-35-stunt-cl
They are about the same vintage and most likely this would be one of the engines a modeler back then would put in it.
Very nice.
I just received a very similar if not identical Fox .35 that was included in a bunch of engines. However it's missing the thrust washer and needle valve. GG and Ron, any idea where I might locate them? I sure would like to se it run again.
Are you a member of Brotherhood of the Ring (Ringmaster CL forum), Stunt Hangar CL, or Stuka Stunt Forums? If not, join. There, you can make your needs known and a fellow CL enthusiast could help point the way or help you.rsv1cox wrote:Very nice. I just received a very similar if not identical Fox .35 that was included in a bunch of engines. However it's missing the thrust washer and needle valve. GG and Ron, any idea where I might locate them? I sure would like to se it run again.
If that doesn't work there is a very good chance you can obtain those parts direct from the Fox factory.
Worst case. Ebay, lot's of Fox engines and parts there. If I had spares I would send them for free. I imagine others would do the same, pretty common engine and lot's of spares kicking around.
Is this your first Fox, George? Ron gave me my first and only one. I had run an OS 35 lots of times, so I treated cranking the Fox like I did with them. The Fox immediately raised my level of respect when I went to flip the prop and it reached out and took the chicken stick right outta my hand! After the third time it really had my attention. I like to crank it by back slapping it. But I use an APC, you can't do that with a wood prop.
I love the thing, it took no time to warm up to it. I never had all the troubles everyone else complains about, just your standard tank trim, and I was off and flying. I'm going to get another one some day.
RknRusty wrote:Is this your first Fox, George? Ron gave me my first and only one. I had run an OS 35 lots of times, so I treated cranking the Fox like I did with them. The Fox immediately raised my level of respect when I went to flip the prop and it reached out and took the chicken stick right outta my hand! After the third time it really had my attention. I like to crank it by back slapping it. But I use an APC, you can't do that with a wood prop.
That's funny, I just use a glove these days. I was flipping bare handed, but thought maybe that one day it may turn out that bad. So I settled on the glove. At least that way I get to keep the finger.
I tried a chicken stick once and I found it very awkward to use. I guess I like a little more of a personal relationship with the engine.
I find the leather gloved hand much easier to do and saves the hand from prop nicks. I now have 3 Fox engines, 25R/C cross scavenge, 15-X CL, and now 35 Stunt. Just need to harness them for work. Overall I've heard nary a complaint from others and they seem to be fine sport engines.
Overall I've enjoyed running the Cox, OS, Thunder Tiger, Enya and Testors engines. Each has their place.
Up to 2.5cc I use fingers but I have had many a cut. Then again - I have probably run more engines, predominantly diesels, than most. Diesels are often referred to as "finger biters".
Small propellers (with small engines) are difficult to swipe with a glove (my gloves, I have a stack of them, are my discarded motor bike gloves). I have bust needle valves through wearing a glove.
Never used a "chicken stick" - like to have a more direct feel for compression. It would be different though if a was running the same engines regularly like most of the members and the engine was prepped for starting.
Larger engines, 3.5 cc plus - I always use a glove. These are quite capable of chopping to the bone and removing finger tips (I know!).
I have seen a 10cc engine remove a child's finger (this was 50 years ago) - not through starting but he poked his finger into a spinning propeller.
If I have a spinner fitted - I usually use an electric starter.
What motorbike have you, or have you had? I currently have a 2001 Kawasaki ZG1200B Voyager XII tourer and 1971 Honda CB100 in my stable, so I have a stack of gloves, too. Instead though I use general purpose leather gloves, which fit loosely and are very easy to shed if I need to adjust the needle. Glove keeps the hand skin intact from prop bite. The smaller half-A's such as the Tee Dee .020 can surely bite. I once had about 8 little slices about 7mm long spaced 3 mm apart on my index finger. I'd understand about the diesels though, because one has to both prop and adjust at the same time.ian1954 wrote:Up to 2.5cc I use fingers but I have had many a cut. Then again - I have probably run more engines, predominantly diesels, than most. Diesels are often referred to as "finger biters". Small propellers (with small engines) are difficult to swipe with a glove (my gloves, I have a stack of them, are my discarded motor bike gloves). I have bust needle valves through wearing a glove.
They are very simple devices. One can make one by drilling and installing a dowel in a handle, cover the dowel with a piece of tight fitting hose or tubing.Never used a "chicken stick" - like to have a more direct feel for compression. It would be different though if a was running the same engines regularly like most of the members and the engine was prepped for starting.
Ouch! Yes, and even YouTube has a video of a surgeon reassembling an older modeler's hand, torn apart by a prop. Lost a few fingers and tips, but saved the hand; (not for the squeemish to watch).Larger engines, 3.5 cc plus - I always use a glove. These are quite capable of chopping to the bone and removing finger tips (I know!). I have seen a 10cc engine remove a child's finger (this was 50 years ago) - not through starting but he poked his finger into a spinning propeller. If I have a spinner fitted - I usually use an electric starter.
Wow, gross. Couldn't watch the video, picture was enough for me...
I remember the time I was reaching across a well running .049 to adjust the needle valve when the prop took several swipes across my inner wrist. A little deeper and I would not be writing this now.
GallopingGhostler wrote:Are you a member of Brotherhood of the Ring (Ringmaster CL forum), Stunt Hangar CL, or Stuka Stunt Forums? If not, join. There, you can make your needs known and a fellow CL enthusiast could help point the way or help you.rsv1cox wrote:Very nice. I just received a very similar if not identical Fox .35 that was included in a bunch of engines. However it's missing the thrust washer and needle valve. GG and Ron, any idea where I might locate them? I sure would like to se it run again.
More forums? I can't keep up with this one. You people just post too much interesting stuff.
Thanks for the parts info. I will find them eventually. Got a .049 OK Cub with the same issues.
My local shop has a nice box of fox parts. I can stop in Monday and see if he has what you're looking for.rsv1cox wrote:Very nice.
JPvelo- Diamond Member
Jim,
I need a .15BB CL venturi stack and 2 .15BB needle valves with springs. Since you are already looking....
I have what is known as an "Old Man's bike" - a BMW R1200GS with all options. It is known as an "Old Man's bike" because, usually, only "Old Men" with a clean riding history can afford them and the insurance. It is big and heavy, lots of torque (no constant gear changing) and ideal for heavy London traffic. Car drivers see the crash bars and get out of the way.
It has fully adjustable push button automatic suspension, anti lock brakes, anti skid control, heated grips, computerized warning system - tyre pressure sensors, alerts when temp falls below 3 deg C, low fuel alert with miles left countdown.
It is high off the ground and you sit upright giving good view over cars and surrounding traffic. No hunch back, wrist and neck ache sports bike riding through traffic.
You are also more likely to look like a monkey on a horse rather than a gorilla on a donkey!
That's an in between. The real old man bike is a trike.
I see a lot of grey beards on trikes with trailers. At that stage it makes more sense to buy a car and roll down the window.
I met an 87 YO man, Ron Von who still rides a 2 wheeler Gold Wing. I guess you are as young as you feel.
This would be my "old man bike"
Davenz13- Platinum Member
Lol.
I had the opportunity to ride a 1975 Husqvarna WR 250 this evening. Went to pick up some CL parts and was handed the bike to ride.
I have always wanted to ride one. They are rugged beasts, no frills or comfort. A man's MX!
Even with only 250cc it has gobs of torque. Can't imagine what the 400 pulls like. Now I want one.
If I can ever get my photo manager to load the picture I will post it.
I used to ride a single cylinder 650, the Suzuki Savage. Talk about gobs of torque, it certainly had it.
I am sure it had.
2 strokes and 4 strokes are different animals. Power bands are much different. I have ridden both and for shear power out of the gate I would choose a 2 stroke any day. My first real bike was a 2 stroke Yamaha RD 350, my second was a Honda CB 550K. Even though the 550 was substantially bigger the smaller RD scared me.
I posted the picture, take a look at the size of the sprocket. MX bikes are geared low. They pull like a train, but top out quickly. I imagine the Husky would only go 50-55mph.
I rode a Honda CR 500 MX when I was 17, somewhere out there is a picture of me throwing up huge mud rooster tails with my little 150lb body laying over the tank with my legs hanging off the back fender so I could keep the front wheel down.
Apples to Oranges.
Apples to Oranges.
» JIS in the house
» The Cox O-45 is in the house
» nitroarplane in the house!
» Dope In The House.....
» feild by my house
» feild by my house
