» Older ignition booksby lla Today at 4:17 pm
» Fox .35 Modifications
by Onelife Today at 3:54 pm
by rsv1cox Today at 3:33 pm
by getback Today at 10:23 am
» S1 Ringmaster
by Onelife Today at 8:40 am
by rsv1cox Today at 7:54 am
» O&R 23 & Brown Jr
by getback Today at 7:47 am
by MauricioB Today at 2:31 am
by rdw777 Yesterday at 4:16 pm
» Hemostat clamp/smooth-jaws
by roddie Yesterday at 3:48 pm
» Black Widow Run time
by Ken Cook Yesterday at 3:44 pm
by roddie Yesterday at 3:33 pm
cox rc cars gtp 049 mod
Page 2 of 3
Page 2 of 3 • 1, 2, 3
gtp wit bee tank reed backplate
tes resulting plenty of power rpm transition bether than new run coold wit glow plug adaptor have try diferent heat range to day is cold run a n6 os plug just for info y found my adaptor is hi comprestion belive or not its bether than its hard to start oem glow head is new 1 dint start at al wil try fresh sub c dont have new d batry for now it did burn drift corner on hi speed turn sharp very good run
davidll1984- Diamond Member
not the same 1 its a 1989 gtp no egr
upgrade for al my gtp indy stocker rc cars more upgrade on ist way
Relooking...
davidll1984: I am relooking at your setup since I have an EGR valve now.
Questions: 1. What is the muffler output tube, snout, for on the engine or is it blocked and all the exhaust is going out thru the side into the blue goo into the bulb thru the black tube into the EGR valve?
2. Why not use a different muffler without the snout, tube, ?
3. Is this setup the “tuned pipe” you are referring too? So then all the exhaust goes out thru that blue goo setup to the EGR valve, or only a part of the exhaust?
I got no instructions or drawings, zero, with the EGR valve, but it was really cheap.
Thanks for any help, or explanation you can give again.
Happydad.
happydad- Rest In Peace
Re: cox rc cars gtp 049 mod
In my game an EGR valve stands for Exhaust Gas Recirculation. The only purpose of it (apart from stuffing up the performance and reliability of an engine) is to reduce toxic emissions. What is the purpose of the "EGR" valve in this instance?
Oldenginerod wrote:In my game an EGR valve stands for Exhaust Gas Recirculation. The only purpose of it (apart from stuffing up the performance and reliability of an engine) is to reduce toxic emissions. What is the purpose of the "EGR" valve in this instance?
That's exactly what it means. It's the throttle control for the GTP Nissan and looks like a white box with tubes. I haven't seen it in real life and don't know how it works.
Read the first page:
https://coxengines.ca/files/Nissangtp.pdf
OVERLORD- Diamond Member
Off-topic: EGR is the culprit in causing many BMW diesel car engines to inadvertently set fire these days, causing BMW car recalls to dealer shops around the world..diesel exhaust gas recirculation into intake air reduces the temperature of fuel burn in the cylinder, thus reducing toxic NOx contents in flue gases, AFAIK.
I think a wrongly routed recirculation duct overheats in BMW-s and this setting fire to the engine
Bei Mercedes Weggeworfen
It is below the blue part
OVERLORD wrote:Oldenginerod wrote:In my game an EGR valve stands for Exhaust Gas Recirculation. The only purpose of it (apart from stuffing up the performance and reliability of an engine) is to reduce toxic emissions. What is the purpose of the "EGR" valve in this instance?
OVERLORD: the EGR valve is just below the blue goo and the bulb. The black tube is going into one end of the valve. The other 2 ends of the EGR are not connected as yet.
Happydad
Yes the blue heatsink is on the egr valve To cool m'y is place very close To engine on the next model wil use similar part
Have some parts
davidll1984 wrote:Yes the blue heatsink is on the egr valve To cool m'y is place very close To engine on the next model wil use similar part
davidll2984: i have rear axle, only axle no gears, and a metal engine mount if you want to pay shipping.
I almost finished macbook so i still can't send photos. I broke a tiny flex cable from new keyboard to the main PCB.
Happydad.
Parts for gtp is Good y dont have pay pal m'y self now wil get it soon for buying m'y self on eBay m'y freind order for me right now if posible can send mony wit mail ? Just for info y bid right now on egr valve from mat exmodel engine y nead that part like 100 of them if posible
Strap starter how To maque them flexible like new first let the part in hot water Not boling in pot y use long heat résistent conteiner make sure strap Not bent let it sit long as posible.befor water start To cool down too mutch place part dry and aply wd40 lube
on the part let cool down place part in bag let it for night it wil penetrate in plastiques make it flexible like new
Y have 1 indy 3gtp two with egr valve 1 wit rc exaust the stocker wit its black rim one hard To Find new in its box like twice harder now is one on eBay y dont have spare mony To fight wit the Others for it very sad and it wont chip To Canada again if Not the mony its the shipping hope one day get the chance To finaly have one y can just swap body cant Find body y want the body new wit no paint To use To mold the body
I am glad you posted this , I have a car just like it and was wondering if it could bee changed over to a pull start engine without a lot of trouble ? Your engine stats and runs easily
I have a little trick to start it easily the best is to prime it with the head removed from the engine With the exhaust open fulltrotle When the engine is well primed, the gas spray when it is cranked Try not to flod Then put the head back In cold weather it's harder I remove the heat sink just for the first start
» Vintage Rc Cars - Now with Video of the Chevy Stadium Truck :) New Cars!!!
» Auto World Vega funny Car
» Mattel's Hot Wheels fans, a heads-up
» Cars, cars, and more cars
Page 2 of 3
