» Stealth SB-Xby Admin Today at 8:28 pm
by TD ABUSER Today at 7:45 pm
» SUPERTIGER .15 PROJECT
by TD ABUSER Today at 7:42 pm
by sosam117 Today at 5:23 pm
by TD ABUSER Today at 4:35 pm
by sosam117 Today at 4:33 pm
by anm2 Today at 4:12 pm
» Jim Walker Bonanza etc.
by rsv1cox Today at 2:57 pm
by roddie Today at 1:37 pm
» Fuel choice
by 1975 control line guy Yesterday at 4:01 pm
» "Fall S.M.A.L.L." Video 3.
by GallopingGhostler Yesterday at 2:37 pm
» Gifted Fox
by Ken Cook Yesterday at 11:12 am
August-2024
Homemade Prop Balancer
![Homemade Prop Balancer 02253410](https://i.servimg.com/u/f39/20/31/87/29/02253410.jpg)
![Homemade Prop Balancer 3868da10](https://i.servimg.com/u/f39/20/31/87/29/3868da10.jpg)
When I ran my Tee Dee .020 a few days ago I noticed it vibrated the test mount at certain rpm’s .... I used to have a commercial balancer similar to the one I made so just needed to find the right materials to copy it.... It uses a 1/16 music wire shaft sharpened to point on both ends with a Dremel cut off wheel.... Also the correct size aluminum tubing to fit the bore and fuel tube to hold it in place...
The points of the M/W go into little dimples made with an awl.... That’s the bearing point.... The aluminum can be tweaked for best fit to reduce friction....
Turns out the prop I was using was the worst of three I have.... But at least I can find out now...
Should be easy to replicate if you need a prop balancer....
Robert
rdw777- Diamond Member
Re: Homemade Prop Balancer
Kudos...I'm impressed!
Hey there Robert. Didn't see you enter the room. WELCOME!
Big Homer Simpson "Doh" on this end. If I had known of your
balancer, I could have saved $$$ spent on balancers.
Regardless, thanks, and belated welcome to the forum.
dckrsn- Diamond Member
Nice. I have a commercial prop balancer, but it’s really meant for large props. It doesn’t work really well with 3-6” props. Looks like you may have the answer.
Great set up. Another possibility is to rest your music wire on 2 horizontal razor blades. That way, there is no need for making points that have to be well centered.
OVERLORD- Diamond Member
Hi Robert/rdw777. I like your prop-balancer. Did you "spin" the MW in a drill-chuck while forming the points with the Dremel-wheel?" I've made tapered-plungers (crude meterering-needles) in this way. Yours looks good!
Many years ago I copied (expanded-on..
) a magnetic-balancer design from a major aero-hobby Co. that debuted back in the 90's?
The principle uses magnetic-levitation to reduce friction in the balance-shaft. A pair of magnets are placed in a field where the metal (Ferrous) balance-shaft fits in-between. One shaft-point comes in contact with one magnet and the other end of the shaft levitates in an adjustable air-gap.
I bought a "Kavan" prop-balancer consisting of a 3mm (.118") diameter X 7cm long metal shaft with points ground on both ends and two tapered cones which are too big for most 1/2A prop hub-holes. Its 3mm shaft is .007" undersize.. for the .125" diameter hub-hole which the Cox .049/.051 engines use.. but it's a nice balancer for propellers having larger hub-holes.
I decided to build a simple wood frame for it.. with two upright "sticks" for lack of a better description.. and sourced a pair of tiny Samarium Cobalt/Rare-Earth magnets which I glued on the ends of a pair of 5/16" X 1-1/4" length hex-bolts which I tapped threads in the uprights for. When assembled with the base and top plywood panels, this design will accommodate a maximum balance shaft length of 3.5" a minimum length of 2" and a maximum propeller diameter of 16".
Some photos with the Kavan balance-shaft.. (I have some .125'" diameter MW and want to make another balance-shaft expressly for 1/8" diameter hub-holes.)
![Homemade Prop Balancer Prop_b12](https://i.servimg.com/u/f76/18/50/45/90/prop_b12.jpg)
... note the mag-lev/air-gap..
![Homemade Prop Balancer Prop_b13](https://i.servimg.com/u/f76/18/50/45/90/prop_b13.jpg)
I would say that it's a pretty sensitive/accurate method.. not to mention "fun and easy to make".
![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif)
Thank you all for the warm reception, I like this group
Roddie, Your balancer is awesome! That’s minimal friction as you can get! I like the calibration method with screws.... My version can be a bit fiddly with getting the aluminum tabs tweaked just right..... Taking an idea from yours, Maybe a calibration screw on one side would help.....
I just spun the MW in my fingers but checked center (and flatness ) by rolling on a piece of glass using a strong light.... Fortunately the 1/16 id tube fits the bore of the .020 prop well.... A short length of tube that fits the primary tube od fits the counter bore on the drive plate side.... The cones on yours make a lot of sense though..... When adjusted properly a gentle tap will send the prop on a dozen or so revs.... A little mark on the base lets me watch tracking....Still need to fab tubes for .049 props...
bty.... I’ve really enjoyed your scratch builds in Modeling.... Inspiring me for a 1/2 A CL one of these days.... Enjoying rehabbing engines for now,
Thank you again,
Robert
Thank you again,
Robert
Be sure to use small magnets and place the point of balancer on exactly the center of magnet. With large diameter magnets it will be inaccurate because of magnetic flux.
Levent Suberk- Diamond Member
» My homemade ski-sled
» homemade gaskets
» Weaver 1cc (Homemade)
» Homemade Tether Car
» homemade gaskets
