» Golden Bee basic running problemby roddie Yesterday at 10:51 pm
» Simple Gliders
by Kim Yesterday at 1:44 pm
» Jim Walker Bonanza etc.
July-2024
robot797's
robot797's
Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished
Not to bad to start with.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011308](https://i.servimg.com/u/f43/19/15/28/33/p1011308.jpg)
Cut down the test mount and beveled all four sides to 33 degrees and slopped on some walnut stain.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011309](https://i.servimg.com/u/f43/19/15/28/33/p1011309.jpg)
Crock pot boil, separated front end (think very hot) and two roller bearings came out onto the micro-fiber cloth. Tiny, slightly pointed on the ends. Dropped them into the Simpler Green solution.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011310](https://i.servimg.com/u/f43/19/15/28/33/p1011310.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011311](https://i.servimg.com/u/f43/19/15/28/33/p1011311.jpg)
Later found three holes for two bearings.![Sad](https://2img.net/i/fa/i/smiles/icon_sad.gif)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011312](https://i.servimg.com/u/f43/19/15/28/33/p1011312.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011313](https://i.servimg.com/u/f43/19/15/28/33/p1011313.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011314](https://i.servimg.com/u/f43/19/15/28/33/p1011314.jpg)
Simple Green, warm water/alcohol rinse, oil.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011317](https://i.servimg.com/u/f43/19/15/28/33/p1011317.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011315](https://i.servimg.com/u/f43/19/15/28/33/p1011315.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011316](https://i.servimg.com/u/f43/19/15/28/33/p1011316.jpg)
Very distressing. Later finish with Howard Feed-N-Wax not poly. Don't want to appear I'm trying to hard. A little more engine clean-up and I'm done.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011318](https://i.servimg.com/u/f43/19/15/28/33/p1011318.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011319](https://i.servimg.com/u/f43/19/15/28/33/p1011319.jpg)
Re: Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished
Are you gonna run it with the missing roller?
Oldenginerod wrote:Are you gonna run it with the missing roller?
I ran it a couple of days ago.
I'm not sure if that roller was missing or not at the time. I was careful removing the front end and only two bearings came out on the cloth which I had wrapped around it. Just the same I checked the whole area carefully and couldn't find another bearing. There was only one square foot of area where where it could have been.
No intentions of running it again. I will just note on the bottom of the mount that it is missing a bearing. When it ran, it ran very well, I was quite surprised.
The quality built into that O&R is outstanding. The pistons crown looks machined with the baffle, not slotted and stuck in like some. The connecting rod and other intermals are nicely finished and the crankshafts weight looks balanced and is marked. I can find little fault with it.
I have an O&R case with piston & rod but I don't know what size it is. Front housing is gone.
I find it fascinating the way they designed how it comes apart. Remove front housing, turn the rod 90º, pivot it out through the front of the case and pull the piston down and out of the bottom of the cylinder.
Oldenginerod wrote:I have an O&R case with piston & rod but I don't know what size it is. Front housing is gone.
I find it fascinating the way they designed how it comes apart. Remove front housing, turn the rod 90º, pivot it out through the front of the case and pull the piston down and out of the bottom of the cylinder.![]()
Me too
I thought - I'll never get that piston out. Heck, it just fell out! Put it back in, as you said, just twist the right way so the baffle is opposite the exhaust port.
Easy to clean too. Insert and rotate.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011320](https://i.servimg.com/u/f43/19/15/28/33/p1011320.jpg)
I have found a couple on ebay, reasonable. Might be able to replace that missing bearing yet.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished Or_eba10](https://i.servimg.com/u/f43/19/15/28/33/or_eba10.jpg)
Nasty, I'm the high bidder at $11.01. All I want is that little bearing.
I did "win" that O&R, $12 but $10 shipping.
There is another for $19 in much better condition with free shipping. I think it's .23 to replace my elusive .23. Looked all over again for that missing bearing, even as a last resort took my leaf blower to the area, but I did find a tail wheel assembly for one of my Testors Fly-ems.
Finished the mount for the .29. Distressed and distressing but it fits. Found something equally distressed to photograph it with.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011321](https://i.servimg.com/u/f43/19/15/28/33/p1011321.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011323](https://i.servimg.com/u/f43/19/15/28/33/p1011323.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011322](https://i.servimg.com/u/f43/19/15/28/33/p1011322.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011324](https://i.servimg.com/u/f43/19/15/28/33/p1011324.jpg)
Funny how O&R marked some with displacement Rod and not others.
I just found this unmarked .60 and .049 among my stuff, but not that missing .23. Replaced the Enya NVA with a Testors, still not correct but more authentic. I will use the NVA from that parts O&R that I have coming along with the roller bearing. I also found the correct spark plug on ebay for the .60 to replace the glow plug.
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011327](https://i.servimg.com/u/f43/19/15/28/33/p1011327.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011329](https://i.servimg.com/u/f43/19/15/28/33/p1011329.jpg)
![Highly distressed and missing one roller bearing, the O&R .29 and it's mount are finished P1011328](https://i.servimg.com/u/f43/19/15/28/33/p1011328.jpg)
» Bar-Clamp engine mount - Finished pictures
» The Caron Bee'm mount for Cox radial mount engines
» Cox Queen Bee .09
» A simpler / cheaper .049 Tee Dee Engine suggestion
» Cox Queen Bee .09
