» PAW .049 CONTROL LINE MODELby TD ABUSER Today at 8:40 am
by akjgardner Today at 7:28 am
» Turbo plugs
by chevyiron420 Today at 7:06 am
by kaintuck Today at 6:34 am
by rfara Today at 6:31 am
by getback Today at 3:31 am
by balogh Yesterday at 8:29 pm
by Cox International Yesterday at 3:35 pm
by 944_Jim Yesterday at 2:50 pm
by GallopingGhostler Yesterday at 2:12 pm
» Fox 049 standard model
by chevyiron420 Yesterday at 2:01 pm
by cmulder Yesterday at 5:34 am
glow plugs
uncle al- New Member
Re: glow plugs
Yup,
Years ago, we only used a 1 cell, "D" size, alkaline (dry cell) which was 1.5 volts.
Usually went to Radio Shack and purchased a "D" size battery holder (plastic) for a few bucks and soldered on the Cox glow clip.
That "1" cell would last almost the entire year of starting my Cox engines.
THE GOOD OLD DAYS!
THE GOOD OLD DAYS!
sosam117- Platinum Member
Re: glow plugs
i use 1.5 volts on my 049 plugs. i'm sure you could go to 1.7 volts somewhat safely, but 049s have always started fine with 1.5 for me
Lukemiester- Gold Member
Re: glow plugs
i have been fighting glowplugs for a few years..
then I thought "what is the ONE COMMON thing in every Cox motor you are fighting to start"
My battery box, from 1984
this arrived this weekend:
http://www.exmodelengines.com/product.php?productid=17769&cat=259&page=1
(thanks Matt!)
after getting used to the clip? my pile of "probably dead" glow plugs? 90% functional. had 4+ motors on and off my test stand, super easy starts..
I cannot recommend this box enough
(thanks Matt!)
cstatman- Gold Member
Re: glow plugs
In high school, I accidentally connected a 6 Volt lantern battery to a Cox glow head, an expensive mistake.
(Both 1.5 V and 6 V batteries had the same form factor - looked the same except for labeling.)
Re: glow plugs
GallopingGhostler wrote:In high school, I accidentally connected a 6 Volt lantern battery to a Cox glow head, an expensive mistake.(Both 1.5 V and 6 V batteries had the same form factor - looked the same except for labeling.)
Ahhh...the ole "Flashplug"...I know your pain, Brother!!!!
Re: glow plugs
Very familiar, hmm, M3B flash bulbs, had one of these to use with my 120 twin lens box camera.Kim wrote:Ahhh...the ole "Flashplug"...I know your pain, Brother!!!!GallopingGhostler wrote:In high school, I accidentally connected a 6 Volt lantern battery to a Cox glow head, an expensive mistake.(Both 1.5 V and 6 V batteries had the same form factor - looked the same except for labeling.)
Remember the blue flash bulb image temporarily burned into the back of your eye balls for the next 10 minutes?
coxaddict- Gold Member
Re: glow plugs
coxaddict, I'd make a special short patch cord that plugged into those banana connectors, with another styled connector on it. Use 2 drilled holes about half inch apart in the aluminum panel to run a 1/8" zip tie to hold patch cord permanently in place. Then use use same styled connector on the patch cord other end for your glow head leads. Perhaps the auto style 2 pin trailer plug could be something unique enough not to be confused with all your other field connections.
Next photo shows the couple buck 2 pin trailer connector I used for a vehicle charger, available at any auto parts store. (By a 12 inch extension, cut wiring in 2, now you have both connectors.
Shumaker Charger using 2 pin trailer connectors
Re: glow plugs
Coxaddict,
I have that same panel...and popped a pile of plugs also. Since the glowplug is polarity-agnostic, I will color-code mine so the plug holes are some aweful color like puce or purple (or some other "P" color) for "P"lugs, and leave the 12V red/black in their natural colors.
PS I can't find those panels, and am looking for a spare. Do you know where you got yours? Was it recently? TIA
Re: glow plugs
Re: glow plugs
Thanks for the great ideas. I actually have those polarized trailer plugs. I'll use it on the starter side.
944_jim, I bought my PP on ebay from a seller who had a few of them. I should have bought more.
» Long glow plugs, standard plugs, couple of questions
» Fox .049 glow plugs
» Anyone ever go here for your glow plugs.....
» glow plugs
» glow plugs
