» Fox .35 Modifications by GallopingGhostler Today at 12:20 am
by GallopingGhostler Today at 12:00 am
by layback209 Yesterday at 11:48 pm
by roddie Yesterday at 6:51 pm
» Post your Older ignition books
by lla Yesterday at 6:34 pm
» S1 Ringmaster
by Onelife Yesterday at 8:40 am
» O&R 23 & Brown Jr
by MauricioB Yesterday at 2:31 am
by rdw777 Tue Apr 30, 2024 4:16 pm
» Hemostat clamp/smooth-jaws
by roddie Tue Apr 30, 2024 3:48 pm
» Black Widow Run time
by Ken Cook Tue Apr 30, 2024 3:44 pm
by roddie Tue Apr 30, 2024 3:33 pm
J.B. Weld - The quicker fixer-upper
Over the years it has saved me many times and I always keep some on hand. From repairing auto parts to model engine case's it is an acceptable repair.
When I got this last Cox chainsaw I noticed that the bottom screw attaching the starter rope assembly was missing. No big deal, I have replacements. But when I was putting it back together I found that not only was the machine screw missing but the boss that it went into was broken off and missing also. This part is under a lot of stress when used so it has to be fixed.
Found a 8/32 nut and J.B'd it in place with scotch tape backing it up on the under side. I used enough product to partially fill the boss and let it cure over-night. Dressed it up this morning with a half-round file and put it back together.
Re: J.B. Weld - The quicker fixer-upper
I always keep some on hand as well, Good stuff!!….Can be worked nearly like metal but easier…. Drilled, filed, even tapped and threaded in some instances…. Makes a good material to add back the missing piece of a part that been broken off sometimes …
rdw777- Diamond Member
Yup!! While many companies have slick advertising hype, many of their products are mostly hat and no cowboy. JB Weld, and the other associated adhesives from their company, always seem to do the job!
One of my entertainment hobbies is buying HO locomotives that are either "tore up, wore out or no count" (read that "as junk") and trying to get them running again. JB Weld makes a "Plastic Bonder" that works well in getting some of the poly frames back together. It may well have some uses in this hobby, too.
Andrew, we share an obsession. "One of my entertainment hobbies is buying HO locomotives that are either "tore up, wore out or no count""
It's what I do, or used to do. ebay, flea markets, garage sales, etc. Same as my model planes and engines, I bought the worst I could find and attempted repairs. Not always successful, but always fun.
Mostly cast - belt drive (coil spring, 3 speed pullys) Varneys. Antiques really, '30's/'40's.
but I did others too.
But....chainsaw. This one (far right) about put me in the ground. After doing three, you would think I knew what I was doing. Not so, from memory and all the fillister head screws look alike except they are of different lengths, talking 1/4" and less. Lot's of room for mistakes, and I made many. Took it all apart at least three times.
As bought
As bought
Good work Bob.
Two part epoxy is a great invention as like as cyanoacrylate glue.
Modelers use a great variety of adhesives and other chemicals and without them modeling would be very difficult. Cellulose glue, epoxy, cyanoacrylate glue, plastic cement, PVA adhesive, aliphatic glue, glue stick, dope, spray paints, acrylic paints, contact cement and so on.
Levent Suberk- Diamond Member
Levent Suberk wrote:Good work Bob.
As you know there is a whole science and industry built around them. Sticky, not so sticky. From band-aids to the space capsule.............
It's a great satisfying feeling; to fix something yourself.. that most people would discard.. because they don't know how to fix things. you know?
I was buzzing my head just the other day, with a Conair brand elec. trimmer that we've had for probably 15 years. It started acting intermittent which turned out to be a wire fracture at the stress-relief going into the casing. Disassembly was straight-forward and only required a #1 Phillips driver. I cut-back the wire and spliced it back with butt connectors and heat-shrink. A short length of vinyl tube zip-tied for a replacement stress-relief. Test---good for a few more haircuts at least...
A good JB weld tip. Using a Q-tip dipped in rubbing alcohol can neatly clean up any residual mess and make the area very smooth. Don't over do it, it takes just a little.
» Talk about a fixer-upper...
» Carb body repair
» Repairing a Gilbert .11 mount using JB Weld
» Wanted, Red prop rod upper body!
» Fixer uppers......But oh that Cox Ryan ST
» Carb body repair
