by crankbndr Today at 7:26 pm
» Enya .09 II Questions
by rdw777 Today at 11:22 am
» Testers Sprite engine swap
by roddie Today at 6:46 am
» Post edit??
by roddie Today at 5:33 am
ok cub co2 engine size
Page 2 of 2
Page 2 of 2 • 1, 2
Re: ok cub co2 engine size
I just found here: http://www.mecoa.com/museum/archive1.html that the OK CO2 first went into production in 1947. Sorry for the mis-information. I was only six years old then. My Bad.
gcb- Platinum Member
ok, according to that site my engine is actually a .0179?
mitchg95- Diamond Member
Hey, Mitch:
How's it going?
KP
How's it going?
KP
kpriddle- Bronze Member
kpriddle wrote:Hey, Mitch:
How's it going?
KP
i got 8g co2 cartriges a couple weeks ago, put one in and turned the knob all the way down to puncture the cartride and the motor will not run? wonder what is wrong here, i am kinda affraid to remove the cartridge now bbecause i do not know if it is puntured or not and if it is, could the co2 bottle be empty from leaking out?
Nope, the cartridge is charged. You just need to back the nut off a smidgen at a time. When/if you hear it start to leak, tighten it just a bit, and flip her over. She'll go...
KP
KP
The engine works by the post on top of the piston poking the ball bearing seal in the head, allowing gas to escape and push the piston down. As the piston comes down it once again allows the ball to seal the head. Use some oil on/in it. I never read the instructions but I would guess that the crankcase hole is to add a little oil. Remember... there is no oil in the CO2.
Also note that it will run backwards...just like a reedie. :-)
Hi Mitch,
There were actually three different versions of the Herkimer CO2 engine. The first version was a knock off they bought the manufacturing rights to from another company and later made some modifications, these were made from '47 thru '52 and had a displacement of .0178. The third version, a redesigned OK version made from 1961 to 1964 had a displacement of .019. The Replacement cartage holders made after '53 were anodized red, so in all likely hood its probably a later model.
kpriddle wrote:Nope, the cartridge is charged. You just need to back the nut off a smidgen at a time. When/if you hear it start to leak, tighten it just a bit, and flip her over. She'll go...
KP
thanks, ill give it a go right now
it runs now, thanks guys
wish it ran longer than 30 seconds lol
Page 2 of 2 • 1, 2
» Cox engine size?
» fox engine size, help
» What size is this engine?
» Need advice re. engine size
» Size of battery needed for Ignition Engine - O&R 60
Page 2 of 2
