TD .049 Carb body retainer nut. Cox_ba12
» 400ft altitude
» Unknown cylinder
by Kim Yesterday at 11:15 am
» Odd Size Machine Screws
TD .049 Carb body retainer nut. Empty
TD .049 Carb body retainer nut. Empty TD .049 Carb body retainer nut.
Post  Cribbs74 Fri Jan 17, 2014 8:09 pm
Weird thing happened to me, I was flying this evening and at the top of a F8 outside loop the engine locked up. As I was gliding down I watched fuel dumping out of the venturi so I knew it had fuel. I was thinking broken crank or rod.
Turned out the carb body retaining nut worked it's way loose and jammed up the driveplate.
A few mins later I was in the air again, but I wanted to relay the story. I never check the tightness on that thing and now maybe I will!
TD .049 Carb body retainer nut. Empty Re: TD .049 Carb body retainer nut.
Post  Jason_WI Fri Jan 17, 2014 8:13 pm
Flying in cold weather the Delrin maybe shrunk to where the retainer nut came loose. Unless you are using the aluminum carb body.
Jason
Jason_WI
Jason_WI
Post  Cribbs74 Fri Jan 17, 2014 8:18 pm
Possibly, it was in the high 40's though. I did fly in the 30's a while back so maybe it happened then and slowly loosened today. Scared the crap out of me.
Besides the tach race engine I have never broken a Cox.
Post  RknRusty Fri Jan 17, 2014 9:54 pm
Hmmm, guess I'll check mine next time I fly. I'm glad it quit in a position where it had enough momentum to glide in for a landing.
Post  Cribbs74 Fri Jan 17, 2014 10:02 pm
No doubt, timing was perfect. Landing was smooth as well. Even if fuel was dumping out of the venturi!
Post  Ken Cook Sat Jan 18, 2014 5:46 am
Ron, this happens a bit. I've had it happen several times. It certainly sounds like the engine seized. I've use Teflon tape to stop that from happening as I had one that would do it frequently. I lapped the collet down a bit so that the crank projected a few thou in front of it. I believe the phenolic washer on mine was grabbing the collet and loosening it. Ken
