» Anderson Baby Spitfire - looking for the aft tank and gasketby Boats13 Today at 8:18 pm
by akjgardner Today at 7:53 pm
by roddie Today at 7:00 pm
by sosam117 Today at 5:55 pm
by roddie Today at 1:08 pm
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
Holding reed in with gasket cement?
I have an engine that has the reed valve missing. (049 of other brand) I made a reed from Mylar. Works fine by blowing/sucking. I put a dab of gasket cement on the ends to hold it in permanent.
Anyone try this? Seems like it should work. Don
dontrinko- Moderate Poster
Re: Holding reed in with gasket cement?
Well... the reed is supposed to be able to move freely and spin. Are you missing the reed retainer? Have you tried it in an engine yet?
I have not tried yet. The reed got sucked into the engine but no sign of the retainer. I tried to make a retainer but it held the reed to tight. Don
It would be best to tell us which engine. Many here have experience on different brands.
Got pictures?
Some engines use a reed that is fixed solid at one end and flex in a cantilever manner. Usually there is a heavier retainer that prevents the reed from flexing too much.
Functioning in a static manner is quite different from 10,000 times a minute or more.
It is a Testers 049. I made a retainer from music wire. I have no faith in it working. Yes! 10000 rpm is diferent. Don
Update:
Found original reed and reinstalled. Used music wire for retainer. (no gasket cement)
Ran one tank full thru successfully. Don
Excellent! Glad you got it working.
Some Testors engines had a wire clip like earlier Cox engines and some has a clip-on plastic retailer like the later Cox. I don't think either of them are interchangeable. It's not hard to pick up a Testors "pipe bomb" engine with the small "fly-em" tank for a couple of $ and use it as a source of parts.
Thanks; I have 2 Tester but they are different.(tank part mostly) I pick up cheap engines on ebay and get them working. (most of the time) Don
