» Dodge Viper - What a waste but brilliant marketingby roddie Today at 6:46 pm
» COX .020 POWERED SPEEDSTER
by TD ABUSER Today at 6:32 pm
» **VOTE-ON-THE-NEXT-COX-ENGINE-OF-THE-MONTH** (November 2024)
by roddie Today at 6:13 pm
by rsv1cox Today at 4:53 pm
by rdw777 Today at 4:28 pm
by balogh Today at 4:15 pm
» L4 Grasshopper
by latole Today at 3:43 pm
» PAW 80 and possible use
by fit90 Today at 8:36 am
» Music-wire bending tools (DIY video)
by 1975 control line guy Today at 8:32 am
» Ultrasonic Cleaners??
by sosam117 Yesterday at 11:26 am
by rsv1cox Yesterday at 9:52 am
» My Pseudo killerbee.
by rsv1cox Yesterday at 7:04 am
Strange, this Spitfire engine has two holes
or is it?
I must admit, I don't drift these out, letting sleeping dogs lay. But, this latest engine arrived with a loose (falling out) NVA - tut, tut, seller you didn't mention that. And, while marking it to ensure the hole pointed down, I noticed there were two holes.
First time I have seen this. Unusual? And, if true, how should I position the holes, horizontal/right angle to the intake I would think.
For $3.36 I'm not to upset. Glow plug if good is worth that.
Thanks
Thanks
Re: Strange, this Spitfire engine has two holes
Is the engine a royal??? Just wondering. For the most part these engines make a nice shelf piece or fishing line weight. Just Say'n , You didn't do bad for what you invested..GOODLUCK!!!!!!!! Mark
Mark Diedrichs- Gold Member
I tried to see if my NIB example has two jets, but my aging vision is no longer good enough to tell.
One thing you might try is bending a very short right angle leg on a piece of copper wire, and check your other engine, by sliding it down the venture both fore and aft of the spray bar, to feel for an orifice each way.
Also, to work properly I would think the dual orifice should be drilled very slightly off center, and you may even be able to see this by viewing the loose spray bar from top and bottom, to see if the jets are out of sight one way, but barely showing with the spray bar rotated 180 degrees. In that case you need to install it with no jets showing while looking straight down the venture.
If I recall, Fox used the twin orifice spray bars on some of their engines?
Hope this helps,
Bill
Hope this helps,
Bill
smooth_bill- Gold Member
Two hole spraybars are quite common. Nothing more to add than what Bill offers in his post. The Fox .35 does indeed use them. I first examine the holes and insure that the burr is removed if present where the bit exited. This is easily done with a #11 blade in a X-acto twirling it. When you look down the venturi, you position the spraybar so that you can just see the tops of both holes.
Thanks Ken and all.
Will do just that. Also, those other intakes look rather grungy. Guess I will spray some carburetor/brake cleaner down there and give them a second chance to run. I used aerosol Remoil to ensure they were clear, but that's not much of a cleaner.
Not to downplay this engine. However the metallurgy for this mill just wasn't there back then. I know I found out the hard way back in the day!!! Live and learn, Mark
» Jim Walker Royal Spitfire, curious and a little strange
» Something strange in the progress of my engine
» Black Widow setup
» Spray bar holes positioning
» Black Widow setup
