by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
PeeWee .020 fueling problem: ideas please?
I'm finding the fuel nipple on my PeeWee .020 very small an difficult to use without spillling a lot of fuel..
Does anyone have any ideas on how I could resolve this problem.
Thank you for any suggestions.
SuperDave- Rest In Peace
Re: PeeWee .020 fueling problem: ideas please?
SuperDave wrote:I'm finding the fuel nipple on my PeeWee .020 very small an difficult to use without spilling a lot of fuel..
i usually use a peice of "small" diameter fuel line to fuel my peewee's, but i always get a little of over spray but not very much to make a difference. Hope this helps Dave
mitchg95- Diamond Member
well, i use a small diameter rubber hose made by Lego for their pneumatic system, which goes over the nipple and makes a great seal without spilling one drop. I'm not sure if you guys have that much Lego over there, but i bet you could use any small diameter hose . oh yeah, its connected to one of those squeezy fuel bottles with the bent down nozzle.SuperDave wrote:I'm finding the fuel nipple on my PeeWee .020 very small an difficult to use without spilling a lot of fuel..
i just stuck the hose on the end and secured it with a cable binder.
GermanBeez- Platinum Member
Yes, I've tried small diamter fuel tubing but am now considering using a small hypodermic needle to "inject" the small quantity of fuel the PeeWee .020 takes.
"Oh look! SD is "shooting up again!" (I can hear it now)
, yup i used a hypo for a while when i started out with these engines, but i got tired always
having to fill up the syringe twice, so i got the squeezy bottle. i only have to press a few seconds, and i'm good to go.
SuperDave wrote:Yes, I've tried small diamter fuel tubing but am now considering using a small hypodermic needle to "inject" the small quantity of fuel the PeeWee .020 takes.
yeah that would work better, id do the same thing but i dont think 17 year olds are aloud to purchase hypodermic needles
americans are probably pretty touchy on that matter
here: one awkward look, no problemo.
You can go to the local pharmacy, pharmaceutical supply house or local vet and ask for a 100cc syringe, no needles. The 100cc will give several fills before running out. With care, you can also use it for priming.
If you explain what you're using it for, most will sell what you want. Just be sure to take the studs out of your lip and eyebrow before visiting.
yeah that would work better, id do the same thing but i dont think 17 year olds are aloud to purchase hypodermic needles[/quote]
I'm sure you must have type one diabetics over there Matt..
Dave, I use a 20cc syringe with a few inches of fuel
Tube on the end with the inner from a Biro stuck
In the end of the tube.
The tube is flexible proving movement and once the
Biro inner has been pushed over the vent once or
Thrice, it's pretty much a fiddle free operation.
John Goddard- Diamond Member
You talking to me?
Yep you said summat about 17 y.o.'s not able to buy
Syringes.
Syringes.
John Goddard wrote:Yep you said summat about 17 y.o.'s not able to buy
Syringes.
Where?
dckrsn- Diamond Member
Soz Mattmicroflitedude wrote:John Goddard wrote:Yep you said summat about 17 y.o.'s not able to buy
Syringes.
Where?
It was Mitch not you
Brodak sells dedicated syringes, there is no need to ask for methanol compatible syringes at the pharmacy...
Link; 1/2a fueler
Link; 1/2a fueler
» Any ideas for a TD 020 muffler?
» Fueling Cox Engines With A Syringe
» Davis Diesel Conversion for PeeWee and Davis Diesel Head for PeeWee
» Out of ideas - Help :(
» Sanding ideas..add yours too please
