» Happy Anzac Day!by Boats13 Today at 11:03 pm
by sosam117 Today at 10:41 pm
» Fox .35 Modifications
by Ken Cook Today at 10:20 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Cox glow plug insert size?
What are the dimensions of the Cox glow plug insert? I am considering using it to repair several non Cox heads. (Testor and Gilbert) Thanks; Don
dontrinko- Moderate Poster
Re: Cox glow plug insert size?
If you are running a standard glow plug and drilling out the head for one you will need a 1/4-32 tap and the correct drill bit. (yes this is an odd size, also common on carburetor jets)
If you want to use a drop-in style then there is more work involved but the results will probably be better as a clamp ring needs made, which can be done from an old head with a lathe. I don't know the dimensions off the top of my head, but I can tell you that measuring different brands will offer slightly different results. The better inserts have a larger post diameter. The old chamber needs faced off leaving the threads, and the center drilled out. ...I suppose this could be done with lapping material (400 grit sandpaper) and a drill press with a good amount of care to retain a square face. Removing 1/8 inch of material freehand is not my idea of a good time though.
Now if you want to make a new clamp ring or plug adapter from bar stock I don't have much help...
I could measure one up for you when I get a chance later but someone will probably beat me to it. I doubt the technique will work with the Gilbert as I don't think the flange will be wide enough to seat on the step in the bore, and the Gilbert threads are very shallow. The only way to overcome that may be to recess the whole insert flange rather than face off the head which would reduce the threaded area too much. The insert would need to be sealed into the head and pinned to retain it, unless you could get a really neat press-fit.dontrinko wrote:What are the dimensions of the Cox glow plug insert? I am considering using it to repair several non Cox heads. (Testor and Gilbert) Thanks; Don
My big question would be whether a Cox insert could be machined down enough to fit into my Torpedo Junior .035. I don't have adequate equipment or skills to do that.
» Glow plug insert
» Glow Plug Insert Leaking
» Cox Tee Dee high-compression glow head question
» Cox .09 glow plug ?
» NOrvel big mig .061 RC with 5 fin insert glow head videos.
