» Fox .35 Modifications by Onelife Today at 6:47 pm
» Happy Anzac Day!
by 706jim Today at 6:44 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
springs.. many types I have O/H
Part of my job involves disassembling data-storage systems.. for AVR (Asset Value Recovery) and responsible recycling of materials. As a result (as well as a sick obsession..) I've amassed quite a quantity/variety of small-wire springs in many sizes; compression and tension.. along with specialty hinge-springs.
Maybe you need one for a needle-valve.. or a "better" one. I have several "jars-full" broken-down into 3 categories; being tension, compression and specialty. Perhaps I was a clock-maker in a past-life.. IDK but I find springs to be a marvel of engineering.. with endless modeling-applications.
I don't have a means for measuring spring-force.. but I'm open to suggestions. Not that it's crucial to an app.. but if I had a spring of the size that you needed.. I'd like to think I could provide one to spec.
I might be your go-to guy for a spring. Let me know if you need one.
Re: springs.. many types I have O/H
I'll put you on my list of resources, Thanks, Rod.
Yes, I need springs all the time. In fact I need some return springs for a set of volkswagon seats.
Cribbs74 wrote:Yes, I need springs all the time. In fact I need some return springs for a set of volkswagon seats.
I probably can't help you there Ron.. unless they look anything like these..
They're the biggest tension-springs I have.
The dark set on the bottom would work. They would have to be cut to length though. New they cost $7-8. Probably not worth the time and shipping.
Cribbs74 wrote:The dark set on the bottom would work. They would have to be cut to length though. New they cost $7-8. Probably not worth the time and shipping.
Geez.. If I'd known.. I could have given them to you when you were here last month...
» types of oil
» fuel types
» Questions about reed valves and retainers
» 6 different .020 cylinder types
» Reed types! What do you use?
» fuel types
