» Golden Bee basic running problemby roddie Today at 10:51 pm
» Simple Gliders
by rdw777 Today at 6:25 pm
by rdw777 Today at 6:11 pm
by Kim Today at 1:44 pm
by getback Today at 7:27 am
by GallopingGhostler Today at 1:05 am
by rsv1cox Yesterday at 2:47 pm
» Jim Walker Bonanza etc.
July-2024
robot797's
robot797's
Aurora .060 rusty and unresponsive
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Aurora .060 rusty and unresponsive
Just like a new engine. I like your blueing methods. I have not done it yet like that, but I must ask. Do you blue the insides too, as I am assuming you do. If so, is there any other prep needed to run the engine again?
Bob, great job, it gives very little hint of its former neglected life, indeed a very well done transformation and restoration. I have no doubts that it will also be a good runner also. Given that it is a slightly larger displacement 0.060, I imagine that its performance ought to be quite respectable, if nothing else at least comparable to a Cox .049 Babe Bee or may be even a Golden Bee.
I managed to pick up a bluing kit in Albuquerque a few weeks ago. It will be my first, now I'll be able to restore the bluing on my steel cylinder engines and needle valves.
That looks good. What bluing kit do you use? I have a small Birchwoof Casey bluing kit I have used on the .15 cylinders that were rusty. Turned out ok if I repeated the process a second time.
Jason_WI- Top Poster
![Aurora .060 rusty and unresponsive - Page 2 Wv_cox19](https://i.servimg.com/u/f43/19/15/28/33/wv_cox19.jpg)
![Aurora .060 rusty and unresponsive - Page 2 Wv_cox18](https://i.servimg.com/u/f43/19/15/28/33/wv_cox18.jpg)
Brownell's Oxpho blue, the best and over time I have tried them all. I used to buy it by the quart.
I used to use swimming pool acid to remove the old bluing, but vinegar or even Simple Green will take it off on the small stuff associated with our hobby. I turned Eric onto it sometime ago, but I think he uses Birchwood/Casey.
Remove any rust and old blue. I have used a wire wheel on slow speed gently applied at times on really bad rust, but not time time on the .060.
Immerse in the solution for around a minute, wash off with cold water and neutralize with a light oil, then burnish, clean and do again. I haven't done a second application yet on the Aurora's engine.
Some metals take the process better than others.
![Aurora .060 rusty and unresponsive - Page 2 Mccoy_14](https://i.servimg.com/u/f43/19/15/28/33/mccoy_14.jpg)
Easy.
Yes i use the cheaper stuff at the time it made a big diff. at 10-12 $ more at Walmart
It works ok as far as i can tell does need two times in though. Engine Looks Great Bob .
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
Bob, Brownell did a really good job on that McCoy .35 Red Head, clean and consistent bluing. First time I've seen a media blasted one. Did it come that way, or did you clean it by bead blasting it?
I got Birchwood Casey Permablue kit (3 oz. bottles), was the only thing available, but paid under $20 for it. Got no idea whether its good or not, will know more when I try.
![Aurora .060 rusty and unresponsive - Page 2 82244f10](https://i.servimg.com/u/f53/18/91/97/52/82244f10.jpg)
Have noticed that some steel fin Foxes must have not been blued, or may have been "browned" using another chemical system. (Or, is it native but uniform rust?
) I've seen a few firearms that the steel was browned, they looked sharp with a twist on a slightly different finish.
That would make for an interesting engine variant by browning the cylinder instead of bluing.
Yes, aluminum oxide I think but it may have been Black Magic as I switch off.
Nasty thing when I got it, but it cleaned up well. Some I rub out with fine steel wool and a light oil. Gives a much more natural finish, but I liked this one so much I just left it. Found a prop drive washer, washer and nut so it's complete now.
And, yes, I plan on running that Aurora .060. I have never ran an Aurora engine before. Come-on warmer weather.......
Cabin fever in WV.
Cabin fever in WV.
Easy.
Beautifully done.
What is that burnishing step that you use in bluing?
I've read some people would use #0000 steel wool with oil to rub parts down after bluing. Is that the essence of it?
Then I'm guessing you clean, blue again (if needed) and finish off with that same burnishing step?
Bretherman- Moderate Poster
Hot blue (gunsmiths process) works so much better than cold blue and you can burnish (polish) with oiled fine steel wool. But if you use it on cold blue your going to remove or reduce the bluing.
Use a soft tooth brush and oil on the fins of you want a more shiny finish, polish with a cotton cloth. leave as is for a matte.
Wish I had taken a "before" picture of that McCoy. Nasty was to nice a word.
[quote="GallopingGhostler"]Bob, Brownell did a really good job on that McCoy .35 Red Head, clean and consistent bluing. First time I've seen a media blasted one. Did it come that way, or did you clean it by bead blasting it?
I've used this stuff for years, Walmart
lasts forever too
lasts forever too
Beautiful.
I've ordered a bottle of the Oxpho-Blue after seeing your initial pictures.
This YouTube video I found today shows an interesting method where you can dilute it in 9:1 water to bluing liquid, and use that to do a few coats.
(Starts at the 9:45 mark):
I think I might try this method as I'm guessing it'll use less liquid if the container is sized right.
yep, i used to have a jar of plain black oxide, worked about the same. Q-tips work good for me.
Thats a car engine?...My 48 yr. old motorcycle has a bigger engine than that! ![:blush: 😊](https://cdn.jsdelivr.net/emojione/assets/png/1f60a.png?v=2.2.7)
OhBee- Platinum Member
![Affraid or WOW!](https://2img.net/i/fa/i/smiles/affraid.gif)
![Old Bugger](/users/3015/29/34/60/smiles/2238803017.gif)
![Neutral](https://2img.net/i/fa/i/smiles/icon_neutral.gif)
davidll1984- Diamond Member
Ok let me explain wy it hi corrosive stuf its layer of oxid make the color and inside now has inside cylinder just remove the layer inside wil make engine wit lower compression the stuf inside wil make engine over heat tink use lot of oil wil change noting so in best case scénario the stuf wil wear out faster than the piston use sintec oil it may help is a way To infinit brake in To reduce wear
I have had some problems with soaking a cylinder in gun blue before. It seems to be fine if dunked in and taken out after a min or two, but if you let it sit you can say goodbye to the compression and the cylinder for that matter.
These days it’s a brush on and rinse off affair. Although I haven’t done it in a long while.
I usually dunk for a few seconds, wait for it to react, and rinse a couple of times and I've never noticed any problems with compression.
Edit: That's using Perma blue.
Interesting, I was going to try the submerging method, but I didn't think much of the cylinder walls being blued.
I'll be brushing it on the outside only.
I have to agree with Rod and Ron.
I have done many cylinders using the full emersion method, something less than 60 seconds max and never had a problem with losing compression. But I always burnish the cylinder with a brass brush and light oil which removes most if not all of the blue anyway. Cold blue just does not stand up to wear like hot blue.
But, when immersed, ensure all bubbles of air within the cylinders fins are removed by swishing it around a bit.
Either way, brush on or emersion is going to make an old abused cylinder look new again.
OhBee wrote:Thats a car engine?...My 48 yr. old motorcycle has a bigger engine than that!
Yeah, that's a whopping 1275 cc.
rsv1cox wrote:OhBee wrote:Thats a car engine?...My 48 yr. old motorcycle has a bigger engine than that!
And that's the bigger version!! When used in the Morris Minor it was 850 cc. The 1275 was seen as the "Hot Rod" engine in the Mini Cooper.
Oldenginerod wrote:rsv1cox wrote:OhBee wrote:Thats a car engine?...My 48 yr. old motorcycle has a bigger engine than that!
Yeah, I'm not ashamed of it. If it will power a tractor what's not to love.
Then there's the massive 1800 cc out of my MGB.
![Aurora .060 rusty and unresponsive - Page 2 Mgb_en13](https://i.servimg.com/u/f43/19/15/28/33/mgb_en13.jpg)
![Aurora .060 rusty and unresponsive - Page 2 Mgb_en12](https://i.servimg.com/u/f43/19/15/28/33/mgb_en12.jpg)
and............between those is the 1500 cc Spitfire engine and we all know the Spit won the battle of Britain.
![Aurora .060 rusty and unresponsive - Page 2 Midget23](https://i.servimg.com/u/f43/19/15/28/33/midget23.jpg)
Iddy bitty............... says who.
Brits forever.................................
Just keep the drip tray handy
(Even Rolls Royces leak oil)
Bretherman wrote:Interesting, I was going to try the submerging method, but I didn't think much of the cylinder walls being blued.
Clean parts with naphta, lighter fluid and a tooth brush. Use rubber gloves to avoid finger prints. Immediately blue the parts after cleaning because cleaned steel rusts quickly.
Do not blue inside of cylinder. You can use a balloon in cylinder to block inside. Oil parts after bluing.
Levent Suberk- Diamond Member
» How a rusty 1963 Corvair turned into a slightly less rusty 1977 MG Midget
» Control line Aurora SE5 - Whole again
» Aurora B-25
» Cox slot cars
» Aurora .049
» Aurora B-25
» Cox slot cars
» Aurora .049
Page 2 of 3
