» Fox .35 Modifications by aspeed Today at 6:29 pm
» Happy Anzac Day!
by Admin Today at 5:50 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Modified SIG Twister
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Modified SIG Twister
Ron,
I used the LA .46
I used the LA .46
JPvelo- Diamond Member
That's why you've got a .40 on it!Cribbs74 wrote:...This thing feels heavy already. I am not happy about that. I'll weigh it and see.
I waited as late in the build as I possibly could to drill the beams on the Yak. It paid off, as I had to add no weight anywhere to balance it.
Looking good.
Dang, three posts while I was writing. I need to write faster.
RknRusty wrote:That's why you've got a .40 on it!Cribbs74 wrote:...This thing feels heavy already. I am not happy about that. I'll weigh it and see.
Looking good.
Yeah, I know. I was comparing it to my other .40 powered planes and it just seems heavy already. I still have half ribs, shear webs and 3" balsa block tips to do. Not to mention all the rest of the stuff.
I always drill motor mounts last for that reason. Most times I have to slam the engines all the way back as they come out nose heavy.
I think maybe I have just been spoiled with 7oz Fox .35's
I don't know how the FP compares to LA as far as power but I was really concerned about weight untill I flew it. Definitely not under powered and floats like crazy on landings. I need to take it to the post office to get weighed but I think it's around 52oz.
JPvelo wrote:I don't know how the FP compares to LA as far as power but I was really concerned about weight untill I flew it. Definitely not under powered and floats like crazy on landings. I need to take it to the post office to get weighed but I think it's around 52oz.
Thanks Jim, I am sure the LA is more powerful and I can switch engines if needed. I have a full fuse Twister that is HEAVY and it's powered by a K&B .40 so I am thinking this one should be lighter than that.
It flys well, and floaty like you mentioned. I like the Cardinal better though
Here is the wing. Another hotel masterpiece!
I decided to pass on the half ribs and just sheet the fore section. I need to do a lot of sanding to make it right. This may negate the sheer webs as well.
Ron, I would still put the webs in. The D tube takes care of torsional twist, but it doesn't do much in terms of flex which is what the shear webs do. For the little bit of wood and time, I would reconsider. It's a simple thing to do. They only have to go out from the center a few bays and they don't need to go all the way across. Ken
Ok Ken. I will install them. Thanks for the tip
I finally have an update on this. Probably should have been painting my reed speed except it was too wet out today.
Since my last update I decided to take apart the wing and remove the warped leading edge piece. It was a pain, but worth it as it's arrow straight now. I resheeting the LE with SIG super light 1/16 sheet and installed the control assy. I was waiting on a 4" bellcrank, but as luck would have it my wrecked Cardinal had one so I dissected it and salvaged the control assy to include the adjustable leadouts.
The LE sheeting, combined with the center sheeting makes for a really stiff wing. The tip is actually a template for the block tips I plan on making. Yes, I know Ken told me not to bother, but I just want to give it a shot as I like the way they look.
I also need to make a larger stab, the one in the picture is just the stock piece that I cut to shape. The new one will be larger and taper to a point up front.
Here are a few pictures.
Looks Good !
Looks good! I had to replace the leading edge stock in mine as well. I think the name "Twister" refers to the leading edge stock. I wish I would have sheeted my leading edge. I stretched my horizontal stab to 21" and it flies great.
Wicked! I wish I was as good at making the time to devote to building/finishing a flying model, the way some of you guys do.. "You" in particular Ron. Many members here have jobs that take them away from home for extended and sometimes indeterminate lengths of time.. yet they're driven to finish and fly their models.
I like this model Ron.. it looks all business..
Thanks Roddie,
Being away from home half the year has it's challenges. Having the tools and supplies on hand make things go quicker, along with space to work. Projects may sit for a couple months, but I can do a months work in a day if I put my mind to it.
I have the ability to hyper-focus which allows me to really concentrate on things I enjoy. I am easily distracted when doing things I don't care for.
I've said this before, but I really think it works... If you start a project and can't devote much time to finishing quickly then do at least one thing a night, it can be as big as cutting out a whole model or as small as installing a screw. One thing a night adds up and very soon you will be finished.
JPvelo wrote:Looks good! I had to replace the leading edge stock in mine as well. I think the name "Twister" refers to the leading edge stock. I wish I would have sheeted my leading edge. I stretched my horizontal stab to 21" and it flies great.
Yeah Jim, the wood is questionable at best. Everything had a little bit of a warp to it and the cut pieces differ in shape and size.
Not, a show stopper, but annoying. I had built the wing in a hotel room and I thought that was what caused the twist. I didn't realize until after I got it home that the LE was warped. I now sight down all my straight pieces before gluing.
Really Looks Good there Ron, That wing has got to be strong as it looks , A lot of dedication to the hobby to carry it to work with you Is this going to be a competition plane or just for fun ? Eric
Trainer. Although if it's capable I'll have no problem flying competition with it.
Cribbs74 wrote:Trainer. Although if it's capable I'll have no problem flying competition with it.
That's a great mind-set! You're already mentally set on "wringing-it-out"!!!!!!!
Always!!!!
I don't get emotionally attached to these things. I want to have a couple planes in reserve.
My crash in Wichita, helped me to realize that you need more than one contest plane so when crap happens you are not out of the game.
I am finally working on this thing again. Final sanded the fuse and purchased wood to do the block tips. Also recut the stab/elevator to 20'
I'll have pics up soon.
Hi Ron
I'm glad to see you back on the build. So far it's a really nice looking plane. As you mentioned back in October, having a backup contest plane relieves some of the pressure. I'm really thin here, but have the best two that I have ever flown with the Oriental and the Ukey. And i know my club would give me a plane if I needed one. I hope you can get some good shop time to finish this one up. Any contests on your calendar?
So, here it is currently. I cut and installed the nacelle this afternoon. I've also resized the vertical stab.
I purposely made the horizontal stab/elevator larger, looks really big at the moment. Once I get the tips in place maybe it will look more the part.
4-40 threaded inserts.... Those little buggers really ticked me off. I drilled the holes to 11/64 like the package recommended and still managed to snap off the tabs while screwing them into the hardwood. Had to back them out using pliers so I'll have to pick up a new set. Not sure how to avoid that again. I even tried working them back and forth, still snapped off the tabs.
These 4-40 inserts are the ones i use.
http://www.ebay.com/itm/NEW-Dubro-Threaded-Insert-4-40-4-391-NIB-/331333340920?pt=LH_DefaultDomain_0&hash=item4d25018ef8
They don't have any screwdriver tabs, you just run a bolt into it with a pair of lock nuts and crank it in with a good quality allen key. It takes a lot of force to crank them into the rock maple beams. I slightly over-drill or countersink the ply bearer so it doesn't crack while I'm installing the insert. On the Osprey I screwed the inserts all the way in flush with the face of the beam. But to do that I had to sleeve the bolt with a short piece of brass tube for the lock nuts to jam against so I could sink the inserts past the hole through the doubler. Once the glue is almost cured, a quick snap will release the bolt, or use heat if necessary. The bolt keeps epoxy out of the threads too.
RknRusty wrote:These 4-40 inserts are the ones i use.
The ones with "screwdriver tabs" are not actually for a screwdriver. The tab is to provide relief so the chip formed by cutting into the wood has a place to go. These should all be installed using double nuts on a proper bolt or machine screw.
Thanks Phil,
Wish I had this info a day ago. Thing is the slot is cut into the top of the plug and not the bottom. So it has no effect on anything when they are beiing screwed into the bearers.
The bottom of the plug is tapered so I don't think I was installing them upside down.
I have used these in the past but I can't say I'm a big fan of them. In order to install them you really are sacrificing a large hole through a 3/8" x 1/2" beam. Not only can this produce vibration issues but it can also lead to the mounts breaking in case of a mishap. Mishaps don't need to be accidental control inputs. A plane like the Twister can get real floaty when the engine quits especially if your on the windy side. A nose over like that can break your engine off if the mounts give way due to removing so much material. Just my opinion. Ken
Ron a #16 drill is probably a better bet due to it being slightly larger by about .005" over a 11/64" drill bit.
» Twister on ebay
» Sig Twister, My First Big Bird
» "Fancherized" Twister build
» My Fancherized Twister build; 3 days til Huntersville
» Twister Wing - Maiden Flight Report from the Zaerodrome
Page 2 of 3
