» Happy Anzac Day!by Admin Today at 5:50 pm
» Fox .35 Modifications
by Onelife Today at 4:34 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Forum membership
Re: Forum membership
It isn't diificult. What did you try doing?
SuperDave- Rest In Peace
Thought I could have mistyped my email address or something like that.
crankbnd- Guest
If you like I will make you an account just tell me what name you want and an email you want it to be with and i will set it up.
Indra
Indra
Nitro, as a guest I cant send you a PM. Dont want to put my email address on an open forum.
crankbnd- Guest
crankbnd wrote:Nitro, as a guest I cant send you a PM. Dont want to put my email address on an open forum.
email me then
nitroarplane(at)gmail(dot)com
If not you can PM me on other forums or on youtube I am always under the same name.
I'll activate the account for you. The confirmation message probably got sent to your spam box.
Thanks for the help.
crankbndr- Top Poster
Oh boy another new member. Welcome crankbndr, join the fun.
Just damaged another crank, seized in the case. That makes three!
Usualy means to much force was being manually applied.
Try a soak gun-cleaning solvent prior to applying any force. Apply small amount of force while working the crank in small increments one way and then the other. The crank may be bound by castor oil gum; many cranks are.
While it was running?crankbndr wrote:Just damaged another crank, seized in the case. That makes three!
It was running well, one of my best yet. I saw 19K on the tach and the engine froze, stopped dead. When I broke it down there was a black streak on the crank journal.
Engine I was trying to build for the Tach Race. Stock Black Widow crankcase with a KB crank.
It sounds as though the fuel was light on lubrication.
crankbndr wrote:Engine I was trying to build for the Tach Race. Stock Black Widow crankcase with a KB crank.
I would say the fits were tighter than normal and you didn't have enough castor in it.
Third broken crank in the same crankcase?
No I stripped the threads on one, bent another polishing it in my dremmel when the crankpin snagged a wad of steel wool I was using. Steel wool explosion went everwhere lol. Hense my username. Fuel is 22% oil half castor half syn. Ready to through in the towel.
Yeah, those Killer Bee cranks are softer metal to absorb the shock of the high compression, especially in diesels. It's easier to strip the prop threads on those.
» AMA membership
» S.A.D Open for Membership
» I will be off the forum for a bit
» Cox Venom Piston Rod Reset Question
» Forum changes
» Forum changes
