» Fox .35 Modifications by Onelife Today at 1:04 pm
» Happy Anzac Day!
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
by getback Today at 6:17 am
*Cox Engine of The Month* Submit your pictures! -January 2017-
submit the next
COX ENGINE of the MONTH!
and have a chance to win a Black Lynx .049 Engine from Ex Model Engines!
CLICK HERE FOR MORE INFO
Rules: You may post *one (1) picture of an engine or a group of engines that are alike (for example: a collection of Space Bug Jr.s that feature each color tank). The engine must be a Cox engine, it can be stock or parts built. Cox engines using aftermarket or handmade parts and multi-cylinder engines are allowed as long as they feature Cox made crankcase(s) and cylinder(s). Although proof isn't required, engines that are built using aftermarket or handmade parts have to be able to run. A good example of a non-running homemade engine that wouldn't qualify for this contest is found HERE. Disassembled engines are allowed as long as all parts are visible and the engine is in running condition when assembled.
If you are unsure if your picture qualifies, feel free to contact the administrator with questions.
* You may post multiple "pictures" as long as they are all joined together in one picture. (This is done in image editing software before uploading)
MAIN POINTS
•One picture
•Picture shall be of one engine or engines that are alike (a Babe Bee and a Tee Dee .049 together would NOT qualify)
•Must be a Cox Engine
•Engines using aftermarket or handmade parts must feature Cox made crankcase(s) and cylinder(s)
•Engine must be able to run
Optional Caption
Along with your picture you may include a caption that describes or explains the picture. The caption should include the name and displacement of the engine. The caption has to be short as if you picture wins, it will be posted under the picture in the sidebar. If you do not include a caption, one will be thought up for you.
After 5 days, the first 10 pictures will be moved to another topic to be voted on by other members. The winner will have their engine displayed on the sidebar of the forum and forever listed on the past winners page.
Looking forward to see what you guys come up with! Good Luck!
Re: *Cox Engine of The Month* Submit your pictures! -January 2017-
It's a brand new year and I'm looking forward to 120 great entries!
Skorch'n TD .050
TD RC .050 non SPI Profi Tuned Pipe - 1st bench test
Tarno Carb, Cox buggy header pipe with half moon brass shim to block 1 exhaust port
#5 cylinder 2 bypass ports and 2 boost flutes per port -1 shim HC Cox Plug
Tad rich approx 85% to optimum break in mode with new #5 cylinder
- Idle with Tarno carb 12,116 rpm APC 4.5 x 4
- vid recorded 20,996 rpm / best noted 21,370 rpm 25% nitro
OVERLORD- Diamond Member
dckrsn- Diamond Member
I see we can take 1 more picture (Mark posted 2 pics)! I'll be posting the poll within the day.
Admin wrote:I see we can take 1 more picture (Mark posted 2 pics)! I'll be posting the poll within the day.
sorry, it was to show what the 290 product engine likely came from.
» *Cox Engine of The Month* Submit your pictures! -May 2017-
» Cox Engine of the Month - Submit your pictures - January 2013
» *Cox Engine of The Month* Submit your pictures! -January 2023-
» *Cox Engine of The Month* Submit your pictures! -January 2022-
» *Cox Engine of The Month* Submit your pictures! -January 2015-
