» Happy Anzac Day!by Oldenginerod Today at 5:07 pm
» Fox .35 Modifications
by Onelife Today at 4:34 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Running one of my TD .09's
Hi all, it's been a while lol but here is another one of my Run video's. It took me a while to get this .09 going but it ran well considering how low the compression was. It did manage to pop the prop loose as you will hear a loud pop when it kicks the prop. no damage done though. Prop is an APC 7x4 and sorry no Tach at the time Hope you enjoy (Bandit)
Heres a direct link too
Sorry for me blocking the view somewhat
TDbandit- Platinum Member
Re: Running one of my TD .09's
7 mins into the vid it runs if you don't want to fall asleep waiting lol
Best steady read 16,472 rpm @ 8:44 into the vid.
Static: 29.3 oz thrust / .309hp / 231w / 62.3 mph
Cox Super Power 35% / 1 gasket.
Thank you for sharing your results.
TDbandit wrote:Hi all, it's been a while lol but here is another one of my Run video's. It took me a while to get this .09 going but it ran well considering how low the compression was. It did manage to pop the prop loose as you will hear a loud pop when it kicks the prop. no damage done though. Prop is an APC 7x4 and sorry no Tach at the time Hope you enjoy (Bandit)
Hey Bandit, I'm inviting you to put photos and videos of our engines running, I think it's good for the forum to have a place to run engines, to share information and make it easy to find!
By the way, I'm only a few laps around your own, mine at 16500 rpm, that is, we're the same!
https://www.coxengineforum.com/t11232-my-engine-running
MauricioB- Top Poster
1/2A Nut wrote:7 mins into the vid it runs if you don't want to fall asleep waiting lol
Friend you are a good supervisor! ... we have the data by sound surely, no?
Yeah i know sorry lol, the compression was rather lousy so it kinda made it difficult to get it to light off quick. In fact I was pleasantly surprised that it ran that good I figure it was near 17k from the way it sounded. Now to hunt for a P/C set. (Bandit)1/2A Nut wrote:7 mins into the vid it runs if you don't want to fall asleep waiting lol
Yes Mauricio,
I used my sound meter on it, easy enough to do then ran the results through
a thrust / power calc program to nail down the performance data. TD engines
have a nice steady tone to read from.
Lol yup and mine has really bad compression so it would of been quicker if the compression was better.MauricioB wrote:TDbandit wrote:Hi all, it's been a while lol but here is another one of my Run video's. It took me a while to get this .09 going but it ran well considering how low the compression was. It did manage to pop the prop loose as you will hear a loud pop when it kicks the prop. no damage done though. Prop is an APC 7x4 and sorry no Tach at the time Hope you enjoy (Bandit)
I do it, I have quite a few vids and pics of engines running so i'll pop a few over there.
(Bandit)
TDbandit wrote:Lol yup and mine has really bad compression so it would of been quicker if the compression was better.MauricioB wrote:TDbandit wrote:Hi all, it's been a while lol but here is another one of my Run video's. It took me a while to get this .09 going but it ran well considering how low the compression was. It did manage to pop the prop loose as you will hear a loud pop when it kicks the prop. no damage done though. Prop is an APC 7x4 and sorry no Tach at the time Hope you enjoy (Bandit)
(Bandit)
Excellent ... will be a great contribution among all the forum!
This is not the best rpm of the run..I checked again and it peaked around 16300 rpm. Pretty fast for an engine with a blow-by problem.
Maybe your vid vibrated but when you flipped the prop I saw the spinner doing some samba...Maybe just my not quite sharp eyes and the small screen of my laptop....Is the crankshaft-to-case fit good?
I set minimum at 3000 to get a finer read on the top end set at 19,000 max rpm.
Best steady read 16,472 rpm @ 8:44 mins. into the vid
If the perimeters are too far out it fudges the data numbers a bit.
Hi Dave, Thanks for posting this vid. As you may know; I recently did some work on a Tee Dee .09 that was given to me earlier in the Summer by a fella down the road a bit.. along with a boxful of various old C/L parts-engines.
If I can get mine running.. I also have a Jr. Ring which is built and almost ready to fly. I'd need to modify the bearers though. They're a bit too wide.
The APC 7 x 4 seemed to run pretty well on your engine. Maybe it wont be as cantankerous to start now that you have a needle-setting.. and knowing how much of a prime it needs?
Bob Dickerson sent me a Tee Dee head and Cox 7 x 3.5 prop.. so that's what I'll try to run it with. My last attempt was with an 8 x 4 woody... and a Medallion head. I also discovered that I had intermittent continuity with my Cox glow-clip.. so I too was flipping.. flipping and flipping to no joy. A pop and spit here and there.. but that was it.
I also have a "Rev-Up" Special Pro Series-3 7 x 2.8 that could be interesting. Its' hub-hole however is .187" diameter as compared to the .212" diameter boss on the .09's drive-plate. I'm not sure where that prop came from.. but maybe it was run on one of my hand-me-down Fox .15 steel-fins.
Priming the side of the piston helps a lot with the starting. It really should fire and run-out each prime and that will give you a "feel" for the engine. Once the priming is well under controlled, then connect the fuel tank and do the same. They should fire right up
Yeah it was doing the hula lol that's why it popped the prop loose. I straightened it out and tightened it and fixed it.balogh wrote:This is not the best rpm of the run..I checked again and it peaked around 16300 rpm. Pretty fast for an engine with a blow-by problem.
But yeah It suprized me too the crank to case fit is good, it's just the P/C that's wore out. BTW a good bit of the problem turned out to be my dang battery box, wasn't getting a hot glow. Fixed it and got a one flip start. (Bandit)
That Rev-Up would be interesting to see, I would also like to try one of those APC 7x3.5's as well and see what mine would do. I ran my other TD .09 which i've had since a kid has very little time on it and it wasn't getting any more than 15,300 RPM with the same prop and fuel but i'm guessing it's because it needs more breakin so I'm gonna put it through a good breakin and try again.roddie wrote:Hi Dave, Thanks for posting this vid. As you may know; I recently did some work on a Tee Dee .09 that was given to me earlier in the Summer by a fella down the road a bit.. along with a boxful of various old C/L parts-engines.
About the clip, it turns out most of my starting problem was the battery box itself (one of the old cox D-cell boxes). I pulled apart the box, cleaned the contacts, reassembled and tried again and bingo first flip start. Kinda helps to make that little element mad lol.
(Bandit)
There is also a Rev-up 7x3.5 prop that Brodak used to carry (I haven't checked lately). These wooden props have really nice and thin blades, much better than the ones from Zinger...
Here is a picture of the Rev-up props that are suitable. The 7x3.5 is close to the Cox one in terms of while load, while the 7x5 is also a very good prop if the engine can handle it. The blades of the 7x5 are a little smaller in area and the load isn't quite as much higher as the pitch indicates.
For a plane without a landing gear though, I would recommend wooden props. It only takes one landing where the prop doesn't quite stop in the right position and the prop will snap. APC is similar, but he MAS (the latest version) are quite good, smaller area and thinner blades than MAS used to have and they are a little better at taking a beating. You have to deburr all the edges though, or you'll cut your fingers...
