» "Mining Precious Metals"...Well, Actually, Sorting Glow Plugs/Glow Heads by HalfaDave Today at 8:03 am
by rsv1cox Today at 8:02 am
by getback Today at 6:25 am
by HalfaDave Today at 5:39 am
by HalfaDave Today at 3:58 am
by GallopingGhostler Today at 2:48 am
» Garage Sale Finds......
by HalfaDave Yesterday at 9:41 pm
by HalfaDave Yesterday at 8:34 pm
by GallopingGhostler Yesterday at 3:57 pm
by GallopingGhostler Yesterday at 3:12 am
» Flying the Cox Models
by Jerry Wed Mar 29, 2023 4:58 pm
» TD 010 Crankshaft Find
by getback Wed Mar 29, 2023 4:23 pm
First time I have ever seen a disconnected connecting rod on the other side of the crank shaft
In the past ten years I have bought over 600 glow model engines, over half of them disaster's that I have disassembled that had been used, abused, and put away wet. I searched them out.
But I have never seen this:
I was wondering why the crank would turn but the piston would not move. Broken connecting rod I thought, rather common. Could still be broken, I have not fully taken it apart yet but there are no broken parts laying in the bottom of the case.
The upside of buying these old engines, you never know what you're going to get, and I have seen some doozies. Keeps life exciting.
And..............and it's just laying on the vice.
Re: First time I have ever seen a disconnected connecting rod on the other side of the crank shaft
Bob, with the backplate removed, even old and fairly used COX pistons allow the big end of the conrod to slip off the crankpin. With the balljoint loosened up and the bottom end worn slack, the piston on the TDC will allow this to happen and you can push the piston out through the cylinder top without removing the cylinder...seen that been there done that.
The COX crankcases have the groove machined in them around the track of the big end that keeps the rod on the pin - except where the cylinder screws in the case, as we know.
I wonder if the same groove is also there Bob in the engine you found with the rod off the pin.without the groove znd with a worn backplate the rid may have slipped off in a worn engine....or maybe the previous owner tampered with the rod when the backplate was removed, and replaced the backplate after the big end slipped off the pin, without puttong it back..?
balogh wrote:Bob, with the backplate removed, even old and fairly used COX pistons allow the big end of the conrod to slip off the crankpin. With the balljoint loosened up and the bottom end worn slack, the piston on the TDC will allow this to happen and you can push the piston out through the cylinder top without removing the cylinder...seen that been there done that
Your right Andras, but the backplate on this Wen Mac is snugged up tight to the cranks pin. no way it's coming off on its own. The piston is stuck at TDC, I'm soaking it in light oil. I'm betting the con rod is broken. Wiil know more tomorrow when I take it apart.
Maybe the P.O. tried to force the stuck piston.. and snapped the rod in the process? They may have removed the backplate and discarded the broken piece before reinstalling the backplate? It is strange though..
Even at TDC, you should still be able to see what's left of the rod.. if in fact; it broke at the crank-pin end.
I am gonna guess that you have a broken end on the con-rod. Here is a picture o one with the back-plate removed, the cylinder at TDC and the con-rod off of the pin on the crank. Doesn't leave much room for the round hole to hide in front of the crank as shown in your picture. The con-rod does fall off the connecting pin at any point inside the case, the threaded back-plate hold the rod on the pin. No groove like on the Cox's,
Yes, broken con rod right at the pin. What I couldn't understand was how the bulk of it got wedged behind the crank.
Pressed off the crank, no piston rod to worry about and dropped the piston out the bottom. Back in the parts cleaner and polished the cranks journal.
I had a spare piston. Pressed the roto-matic starter back on. Same problem as with the other one, wouldn't rotate in the clockwise direction. Parts cleaner and light oil cleaned it up.
Another very nice engine there. Good job, and very nice that you had a spare piston.
That is pretty wild you would not think it would happen , from the look of the CS web it has a lot of bevel to the back side and i would say at 10K or so Rs it could get back there at the right stroke . Did that sound like I know what I an talking about at 7:30 AM ?
getback wrote:That is pretty wild you would not think it would happen , from the look of the CS web it has a lot of bevel to the back side and i would say at 10K or so Rs it could get back there at the right stroke . Did that sound like I know what I an talking about at 7:30 AM ?![]()
You lost me at "CS web" Eric
Crank Shaft Web = CS webrsv1cox wrote:getback wrote:That is pretty wild you would not think it would happen , from the look of the CS web it has a lot of bevel to the back side and i would say at 10K or so Rs it could get back there at the right stroke . Did that sound like I know what I an talking about at 7:30 AM ?![]()
You lost me at "CS web" Eric, but the rest of it sounds great. I agree, probably turning RPM's pretty good and at the right moment got caught up behind the crank. The hole end was just demolished.
getback wrote:Crank Shaft Web = CS webrsv1cox wrote:getback wrote:That is pretty wild you would not think it would happen , from the look of the CS web it has a lot of bevel to the back side and i would say at 10K or so Rs it could get back there at the right stroke . Did that sound like I know what I an talking about at 7:30 AM ?![]()
Sounds like a new internet web-site Eric, if I can find it, I will have to log on.
The piston was out of an old Testors pipe-bomb, perfect pit and great compression. It will go back in the P-26. Wish I could find one with the throttle option as on my first one.
» Baby Cyclone .363 rebuilt of first american petrol engine production
» Parts for RR-1
» Crank shaft rotation
» .049 Medallion crank shaft
» Wanted: TD 020 crank shaft
» Parts for RR-1
