» Roddie's water-cooling bottle for bench-runningby roddie Today at 7:38 pm
by rsv1cox Today at 6:28 pm
» Feed Station Zebra.. Spring 2022
by roddie Today at 5:59 pm
by rsv1cox Today at 12:26 pm
by GallopingGhostler Today at 11:12 am
by rsv1cox Today at 7:43 am
» Artwork for Otto Kuhni
by Mark Boesen Yesterday at 11:53 pm
» Baja Bug / Dune Buggy Recoil Starter
by vambrosini Yesterday at 8:57 pm
» Wanted: Pull Starter reapir kit for a Cox Dune Buggy.
by vambrosini Yesterday at 8:55 pm
» cox dune buggy/ baja bug
by vambrosini Yesterday at 8:49 pm
» Joe Wagners Sioux
by GallopingGhostler Yesterday at 7:37 pm
» B-25 Mitchell
by rdw777 Yesterday at 9:49 am
Contra vs Counter Rotating Props
Re: Contra vs Counter Rotating Props
Cz10 wrote:I just sent her an email for 2 - for the two Venom II I just received to go on my Sterling P-38 that will be in this paint
Guess I'll need a couple of red rubber spinners too.....
Wish I could source a pair of 3 bladed props that were the same shape in both rotations...
Surely you want contra rotating props on a twin?
John Goddard- Diamond Member
"Wish I could source a pair of 3 bladed props that were the same shape in both rotations"John Goddard wrote:Cz10 wrote:I just sent her an email for 2 - for the two Venom II I just received to go on my Sterling P-38 that will be in this paint
Yeah that's what he said lol.
I prefer counter rotating to contra rotating. Contra rotating is typically faster but counter rotating offers greater directional control if one engine tanks.
fit90- Diamond Member
fit90 wrote:I prefer counter rotating to contra rotating. Contra rotating is typically faster but counter rotating offers greater directional control if one engine tanks.
Either a prop spins left or right.... or is there more to this?
No one you have the you swap the LH and RH engines around and its different.Cox International wrote:fit90 wrote:I prefer counter rotating to contra rotating. Contra rotating is typically faster but counter rotating offers greater directional control if one engine tanks.
So both props spinning inwards or both spinning outwards.
On counter rotating props the props spin inward. On contra rotating props they spin outward. When they spin inward then if one engene fails the effective thrust line of the operating engine is on the inside of the engine. On contra rotating the effective thrust line is on the outside of the engine.
Sorry for the confusion. The props are either left or right handed. The direction they spin relative to the aircraft center line makes them either contra or counter rotating.
... um yes.... I misunderstood that
However, still one prop spinning left and the other right.
YesCox International wrote:... um yes.... I misunderstood that
I've never lost track of a thread so fast as this one! Surely "Contra" rotating and "Counter" rotating are simply two ways of saying the same thing?? i.e, the props rotate in opposite directions?
Or am I missing some deep technical point here??
Ivanhoe- Diamond Member
Counter is inward contra is outward.Ivanhoe wrote:I've never lost track of a thread so fast as this one! Surely "Contra" rotating and "Counter" rotating are simply two ways of saying the same thing?? i.e, the props rotate in opposite directions?
A picture is worth a thousand words.
Good job Indra,
Good job Indra,
Does the red 8cc stunt tank provide some Coriolis effect to the propellers?
nitroairplane wrote:Counter is inward contra is outward.
I don't think that's right Indra...
Contra-Rotating Props
http://en.wikipedia.org/wiki/Contra-rotating_propellers
http://en.wikipedia.org/wiki/Counter-rotating_propellers
For the Seminole in the second picture, and most conventional twin engine aircraft, counter rotating props spin inward and contr rotating props spin outward.
fit90 wrote:For the Seminole in the second picture, and most conventional twin engine aircraft, counter rotating props spin inward and contr rotating props spin outward.
That's not correct, contra is a counter rotating stacked props, as shown on the Spitfire.
Counter rotating, there are inward and outward couter rotating props. The Seminole has inward counter rotating props.
fit90 wrote:I don't know anything about the stacked props like those pictured on the Spitfire. On general aviation multi engine planes with the engines oriented left to right (or right to left) planes such as the Seminole and later Senecas have counter rotating props (they spin inward) to aid in single engine directional control while planes such as early P-38's had contra rotating props (spinning outward) to give an increase in speed, but at the expense of single engine contrability. I am not sure if counter rotating and contra rotating are listed in CFR 14.1 but they are definitely used in light general aviaton aircraft certified flight manuals. However, words and terms that are only a small step above "aviation slang" have found their way into flight manuals so this might just be different usages of the same terms.
Yes, but in those manuals or whatever, it is used incorrectly. Contra is not Outward Counter Rotating Props.
Help me out here...
By definition, counter rotating props are any pair (or more) of props that spin in different directions, either way, but spin on different shafts (points of rotation). Contra rotating propellers are two or more props that spin in different directions about the same point? Sounds simple enough once I unlearn decades of FAA lingo.
Kind of like the old FAA Advisory Circular AC 61 (I think) "The Flight Training Handbook" and its definition and description of lift and how it is created. That should be a whole new thread.
Thanks for the patience,
Cool!
Thank you
Thank you
nitroairplane wrote:Counter is inward contra is outward.Ivanhoe wrote:I've never lost track of a thread so fast as this one! Surely "Contra" rotating and "Counter" rotating are simply two ways of saying the same thing?? i.e, the props rotate in opposite directions?
Well, that's news to me!
Ivanhoe wrote:nitroairplane wrote:Counter is inward contra is outward.Ivanhoe wrote:I've never lost track of a thread so fast as this one! Surely "Contra" rotating and "Counter" rotating are simply two ways of saying the same thing?? i.e, the props rotate in opposite directions?
See my posts above...
Not all twins (or multi-engine aircraft) have counter rotating propellers.
» metal tank mount for the 049 td suggstion/ request
» Rotating needle valve
» TD .09 - Something interfering with the rotating assembly
» Crankshaft counter weight
» Anybody have atwood boat engine parts that you would part with???
