» Revivng Some Childhood Classicsby rsv1cox Today at 7:17 am
by getback Today at 6:20 am
by getback Today at 6:17 am
» Fox .35 Modifications
by Onelife Yesterday at 4:36 pm
» TD/Medallion .049 fuel draw issues
by Ken Cook Wed Apr 24, 2024 7:18 pm
Black Widow backplate question
OK, all you Black Widow experts out there! other than having no tank vents, what is the difference between a BW backplate and a Babe Bee?
In my quest for a cheap replacement I am contemplating filing off the vents on a BB backplate and filling the holes as a short term fix so I can at least continue to fly the engine, do I need to do anything else?, is the air inlet any larger on a BW, and are there any other differences?
Any advice appreciated
Wilf
Wilf
Ivanhoe- Diamond Member
Re: Black Widow backplate question
The inlet hole needs to be enlarged and the vents plugged, and that'll do it. Work fine last long time.
The inlet should be the same size as the venturi tube, .082". That's a little bigger than a 5/64" bit (.078), so just finger twist the bit through and ream it slightly so it is a loose fit. A bit crude, but it works for me anyway.
RknRusty wrote:The inlet hole needs to be enlarged and the vents plugged, and that'll do it. Work fine last long time.
Thanks, Rusty, that's what I needed to know
» Black widow backplate
» Cox Black Widow .049 Question?
» Modifying backplate for Black Widow
» [sold]looks like a black widow with a metal backplate
» (Found) Black Widow/Golden Bee Backplate
