» TAPLIN TWIN 7ccmby OVERLORD Today at 4:43 am
by Kim Yesterday at 6:29 pm
Engine ID please
Canso07- Gold Member
Re: Engine ID please
ok I've figured it out, it's a Herkimer OK Cub .059R manufactured in 1960. Never seen it before.
Thanks Canso07.
Thanks Canso07.
I guess the Cox head that's fitted distracts from the easy identification of the Cub. It should have the original hex type head. These were a good running engine. Not sure about power output as I've never flown mine. Also never compared the Cox head.
This engine has been discussed with some interesting details . Gwilliefox aka Bill Mohrbacher has posted pics and details of this engine in the past. Neat stuff take a peak. Ken
The (c.'58) Cub glowhead and head/glowplug is the same size as a Cox ('56) head, likewise the early Cub head/glowplug fits the pre '56 Cox. Kinda neat as it gives you the option to run a short glow plug on a Cox.
Rumor has it Bill Atwood designed the reedie engines for Cub as they had very little R&D by the late fifties.
Thanks for the tip Mark. I've got a couple of SBJrs. in need of heads and a whole bunch of Cub .049B head/cylinder assemblies. Just tried a test fit on one. The Cub assembly came with one thin and one thick copper gasket factory installed. With just the one thin washer the SBJr. piston jams at TDC, with both no. Proceed with caution.
» *Cox Engine of The Month* Submit your pictures! -December 2016- *ENGINE GIVEAWAY*
» *Cox Engine of The Month* Submit your pictures! -December 2014- *ENGINE GIVEAWAY*
» **Black Lynx Engine Giveaway Jan-June 2021** Cox Engine of the Month
» *Cox Engine of The Month* Submit your pictures! -June 2014- *ENGINE GIVEAWAY*
» *Cox Engine of The Month* Submit your pictures! -June 2016- *ENGINE GIVEAWAY*
